Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-09-2010, 12:50 PM   #1
BGC
Member#: 231992
2005 Baja Turbo/Lthr
white and silver
Unhappy Prewired for Sports Lights
2005 Baja turbo with leather option: I have a factory set of Sports Lights. I have read that the car is prewired for these lights.
I have the factory switch, relay, etc., all that is needed. What is prewired or anything?
Sorry if I missed an earlier thread on this. I want to install the lights. I do have a complete wiring diagram.
Any simple bumper brackets for these lights as I have two extra lights?
BGC is offline   Reply With Quote
Old 01-10-2010, 03:58 AM   #2
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
not sure what you're asking here..
Yes all Bajas are pre-wired for the sport lights. That is all you'll need to do is install the switch, possibly a relay and then remove some trim from the bedliner on the right side I think, and the trim that goes around the rear window and brake light to run a wire up there. Then mount lights on crossbars, connect plugs, tada. Not hard, time consuming. You instructions should detail all of this.
moonzie is offline   Reply With Quote
Old 01-10-2010, 01:48 PM   #3
BGC
Member#: 231992
white and silver
Default Pre Wired
Thanks, the instructions I have show me as running all the wires!
You answered my question regarding the prewire.
Old 07-13-2010, 12:01 PM   #4
bilway69
Member#: 133302
2002 WRX Wagon
Platinum Silver
Hello,
I went thru all the installation but... I do not have a plug behind the radio.
I have a 2003 baja. Canadian version
here how my center console look like
Looks like the plug I need is for the cargo light... I do have th plug in the back on my 3rd brake light.
Also the relay is already there. I have try to install the light switch insted of the cargo switch but still not working.
Anyone has the same problem?
thanks for your help.
JEFF
bilway69 is offline   Reply With Quote
Old 07-13-2010, 03:49 PM   #5
steven765
Member#: 105920
2006 Baja 5 Speed
The wiring diagram shows the connector hidden back there for the sport lights. Look for blue tape, that's what they wrap optional connectors in. It might just be hard to find, you'll have pull that whole console radio/hvac and cargo lights.
steven765 is offline   Reply With Quote
Old 07-13-2010, 04:35 PM   #6
bilway69
Member#: 133302
2002 WRX Wagon
Platinum Silver
I will look again but that cargo switch did have some blue tape on the wire. but it also had a different connector with kind of a extender cord that was plug to the CARGO SWITCH..
I will try to add picture tommorow.
Old 07-13-2010, 08:51 PM   #7
Ti Pit
Member#: 146009
2005 Legacy GT Wagon
If I'm not mistaken the 2003 are NOT pre-wired, the Baja became pre-wired in 2004 for the activity light kit!
Hey bilway, It's nice to see another Quebec Baja! is your's yellow?
Ti Pit is offline   Reply With Quote
Old 07-13-2010, 09:43 PM   #8
bilway69
Member#: 133302
2002 WRX Wagon
Platinum Silver
Black baja in quebec city where are you?
are you a MSC member?
Well the kit that I bought was for 2003. Same for all the instructions.
I have the cable to connect the light near the 3rd break light. so I assume that it is prewire...
What year is yours? do you have the cargo switch located at the same spot in the dash?
Jeff
Old 07-14-2010, 12:32 AM   #9
steven765
Member#: 105920
2006 Baja 5 Speed
cargo light switch in the U.S. is over by the fog light, you lucky canadians have the wiring for the heated windshield.
also frogive me my wiring manual is for the 2006
Old 07-14-2010, 12:28 PM   #10
Ti Pit
Member#: 146009
Jeff
Hey I'm in Montreal and Yes I am a member of MSC.
My Baja is Monterrey Grey on silver. It's a 2005 Turbo. I love it! Baja's are really rare around here. I believe I've seen 4 since last year. 1 black/silver, 1 red/silver, 1 yellow/silver and a silver/silver at the dealership this winter.
My cargo lamp switch is not at the same place as yours, mine is near the cruise control and fog lamp switch.
Post come pictures when you have the lights up!
Old 07-14-2010, 03:02 PM   #11
bilway69
Member#: 133302
2002 WRX Wagon
Platinum Silver
Here some picture...
I had to modified the bracket that hold the light on the light bar as it's not fitting on our bar model.
I also have the tonneau cover made from Snuglid..
Old 07-15-2010, 07:59 AM   #12
bilway69
Member#: 133302
2002 WRX Wagon
Platinum Silver
Ok...
did open up everything again last night..... I do not have that plug in the center console...
Does anyone has a wiring diagram of the baja so I can trace this wire from the back to the front....
Also I try to direct plug the light and guess what... they are not working..
@ Steven will I see you for the NEFR this week-end?
Old 07-15-2010, 05:30 PM   #13
Ti Pit
Member#: 146009
Sorry it took so long. I knew I saw the info somewhere on Scoobytruck.com however it seemed down yesterday. Here are the instructions for the installation on a 2003 Baja. Enjoy et bonne chance!
http://scoobytruck.com/pdf/2003MY_Ba...Lamp_rev_B.pdf
J'adore le look en pasant et je suis j'alou de ton bed cover!
Old 07-15-2010, 06:43 PM   #14
steven765
Member#: 105920
2006 Baja 5 Speed
NEFR? what's that?... And I just looked, looks like fun, school is pricy, though I really want an advanced driving school.. Sadly however I'm on active duty this weekend so I can't go
Old 07-15-2010, 06:44 PM   #15
steven765
Member#: 105920
2006 Baja 5 Speed
btw you may not have to notch the housing as the instructions say, mine had enough clearance in the design already. Just an fyi, check before you cut.
Old 07-15-2010, 07:30 PM   #16
Emsanon
Member#: 152508
2003 Baja
Good ol' Classic Yellow!
Yeah, that's interesting. My 2003 Baja has the Cargo lamp next to the foglights/cruise control etc off to the left. It had the sport activity lights already installed with the button below the radio. Almost seems like there were different versions of Baja's out there.
Emsanon is offline   Reply With Quote
Old 07-15-2010, 08:10 PM   #17
Ti Pit
Member#: 146009
maybe it's the difference between the sport and the classic models? That or it's a Canadian thing...
Old 07-16-2010, 10:53 AM   #18
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
For '03 the biggest difference between the sport and the classic model were the classic got leather (like) seats, painted mirrors, and differnet bulbs in the headlights. On a black Baja the mirrors matched so it was harder to tell the difference without looking closely at the head lights.
braveit1 is offline   Reply With Quote
2005 sti prewired for stock sub? mike okisbig Car Audio, Video & Security 1 06-28-2004 02:47 PM
gauges prewired for '04 STI? HOOPT Newbies & FAQs 5 10-15-2003 07:08 PM
prewired for sub/amp? BlackWRX STi Forum Archive 1 07-03-2003 09:37 AM
Are the TS's prewired for heated seats Scoobie Newbie Canada Region Forum 6 02-20-2003 10:58 AM
Can anyone tell me if the TS's is prewired for heated seats Scoobie Newbie Electrical & Lighting 7 02-20-2003 10:46 AM
