Welcome to the North American Subaru Impreza Owners Club Thursday October 2, 2014
Old 01-10-2010, 10:11 PM   #1
emsfd125
Member#: 226975
2005 STi FULLY BUILT
Jr Tuned yo!
Default Tactrix and AP question
can i upload a map with a tactrix cable onto my 05 wrx when there is a stage 2 ap map on there already?
emsfd125 is offline   Reply With Quote
Old 01-10-2010, 10:14 PM   #2
narcispy
Member#: 202473
2004 Impreza WRX
World Rally Blue
From what I've heard the ecu is locked when it is married to the AP, so you would need to unmarry it, then you could upload a map with the tactrix.
narcispy is offline   Reply With Quote
Old 01-10-2010, 10:14 PM   #3
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
no you cannot. as he said, the AP locks the ECU. you need to unmarry it first by either using the AP or sending the ECU to cobb
Jncominco2 is offline   Reply With Quote
Old 01-10-2010, 10:19 PM   #4
emsfd125
Member#: 226975
Jr Tuned yo!
i have the AP, in order to UNMARRY the accessport, do u need the little white initialization connector because that is what is giving me a problem, evertime i try to flash a map it says that the connector isnt connected when it is
Old 01-10-2010, 10:23 PM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
That will present a problem with the Opensource flashing as well.
Byzantium is offline   Reply With Quote
Old 01-10-2010, 10:25 PM   #6
emsfd125
Member#: 226975
Jr Tuned yo!
yeah but i think it is the connector that came with the accessport, i do not think it is the one attached to the car
Old 01-10-2010, 10:27 PM   #7
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
are you connecting that loopback connector, and the two test connectors? (the other connectors in my car are green, not sure about the 05)
Old 01-10-2010, 10:28 PM   #8
fl4tsc
Member#: 177247
2005 WRB WRX
16GXT + 44mm EWG = wahhh!
it depends on whether or not your problem is with the ap or with the white connector...
if your problem is the ap and you can unmarry it without the white connector (don't know if you can) then the os flash should work fine.
if the problem is the white connector then you'll have the same problem with the os flash
fl4tsc is offline   Reply With Quote
Old 01-10-2010, 10:28 PM   #9
emsfd125
Member#: 226975
Jr Tuned yo!
yes the loopback connectors and the 2 green test connectors, it will flash a REALTIME map but it will not reflash the ecu, and i need the reflash to get my car to a tuning shop, it keeps telling me there is a problem with the initialization connector (loopback)
Old 01-10-2010, 10:30 PM   #10
fl4tsc
Member#: 177247
2005 WRB WRX
try and find a local with a connector and see if it works with theirs...
Old 01-10-2010, 11:27 PM   #11
emsfd125
Member#: 226975
Jr Tuned yo!
i cant get this little test connector to work man, it keeps telling me connect the white initialization connecter when it is already connected
Old 01-10-2010, 11:42 PM   #12
emsfd125
Member#: 226975
Jr Tuned yo!
anyone?
Old 01-10-2010, 11:59 PM   #13
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
do as tallterror said, find a local that has one and just borrow it to see if theirs works
Old 01-11-2010, 12:09 AM   #14
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
Call Cobb? 801.713.0035
Carter is offline   Reply With Quote
2008 STI w/ Nav and AP question yakkosmurf Car Audio, Video & Security 2 06-24-2008 09:55 AM
Bigger turbo and AP question dumpstercrusher Mid Atlantic Impreza Club -- MAIC 14 02-26-2007 01:03 PM
PDX and AP questions. base, real? Poodie AccessPort 1 07-30-2006 10:52 PM
UP/DP install time and AP questions dogfrndnew Factory 2.0L Turbo Powertrain 1 11-15-2005 12:05 PM
Accident and ap question vinithing Engine Management & Tuning 6 01-27-2005 01:13 PM
