Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 01-11-2010, 02:08 AM   #1
rexblake
Member#: 178426
2010 S4
Gray
Default AP won't log, power dropping off after 6800rpm
Two issues, heavily modified 02 WRX. Mod list here: http://forums.nasioc.com/forums/show....php?t=1883576
First, every time I go full throttle the AP says it lost connection with ECU. Therefore, I can't log. This is not launching the car, rolling into boost it does the same thing.
Also, the power drops off after 6800rpm. I'm told thats where the stock ecu timing tables end and am curious if the AP allows changing this table. Specifically by elongating the timing to higher rpms. If you can change that, how do you go about it. If you can't change it, can you simply add in massive amounts of timing up top to compensate?
Dyno plot in question:
Clearly boost holds the whole way, even upping boost in the problem area doesn't help.
rexblake is offline   Reply With Quote
Old 01-11-2010, 09:13 AM   #2
MRX WRX
Member#: 114566
2005 STI
aspen white
post your setup, why are the tq curves so different on thse pulls? could be alot of things a stock TMIC will do that too, especially on a dyno. bumping up the timing will help alot but without knowing your complete setup i am just guessing.
MRX WRX is offline   Reply With Quote
Old 01-11-2010, 12:23 PM   #3
rexblake
Member#: 178426
2010 S4
Gray
ej207 short block:
JE pistons
Eagle Rods
crank drilled
balanced
nitride coated crank
ej205 heads with BC:
Valves +1mm over
Springs
Retainers
272 Cams
Perrin Big maf, APS 525, grimmspeed everything, tial 38mm ewg, invidia dp, borla hush, zeitronix map, samco turbo inlet, DW 1000, walbro 255, APS 50/50 bov, ATI damper, hta68
The first graph is tq curve, the second is PSI.
Old 01-11-2010, 05:44 PM   #4
Cobb Tuning
Member#: 4803
Yes, you can scale the tables to accomodate a higher-revving engine so you can adjust timing at higher-than-stock rev-ranges. It would appear that your timing tables have not been scaled to accomodate these higher rev-limits.
Travis
COBB Tuning
Old 01-11-2010, 06:08 PM   #5
rexblake
Member#: 178426
2010 S4
Gray
That's what I needed to know, thank you Travis.
edit: I talked to my tuner and he did rescale the timing/rpm table so that's not issue. Any other ideas?
My lights won't turn off after I turn the car off. need HELP sillyme Newbies & FAQs 8 12-18-2008 08:41 PM
problem with power drop at 4k rpm after injector/vf34 install. please help! ansonb505 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 02-21-2008 05:10 PM
AP won't connect to ST or AP drfrink24 Engine Management & Tuning 7 04-03-2006 10:53 AM
where does power drop off at? SoCal ScoobieNewbie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-23-2005 12:02 AM
Why does power drop off at 6K? TypeC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-06-2001 02:35 PM
