Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 01-11-2010, 01:37 PM   #1
dalesalignment&brake
Vendor Sales Rating: (46)
Member#: 173316
Default Attn. Canadian Customers-'08+WRX RCE Yellow/GTWorx Bilstein will be here soon.
We are the Canadian Distributor for Racecomp Engineering
RCE Yellows/GTWorx Bilsteins for the '08+WRX and the long awaited RCE Yellows for the '08+STI will be in stock very soon. Email/pm for enquiries
1) RCE Yellows for the GRB('08+STI)-in stock very soon
2) '08+WRX GTWorx Bilsteins/Yellow springs-approx. 2-3wks landed at Dale's Alignmentemail/pm for pricing
3) I also have GD('04-06 STI, *'07 STI) and GRB('08+STI) swaybars-in stock
RCE swaybars are here!!!!!
Racecomp Engineering 25mm Swaybars for STi (2004-07)- pm for pricing
The Racecomp Engineering swaybar set will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm. The settings for the rear bar are adjustable from 25.5, 27.0 and 28.5mm. You can run these and not have to go to a bar that is actually 27mm thick. 25.5mm physical diameter. 4142 Chrome Moly Heat treated and cold finished. Ends are hot forged on a 125 ton press. Includes polyeurathane bushings and lube. Washer tabs on front and rear to prevent walking.
Racecomp Engineering GR Sway Bars-
pm for pricing
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
Pm/email for more info
Bilstein Struts-GH chassis '08+WRX
Finally something available for the '08 WRX where you don't have to break the bank.
Bilstein struts will transform your WRX into a cone eating monster when matched to a set of RCE Yellow springs.
Details:
Front:
Monotube, Gas, inverted struts.
NON DAMPING ADJUSTABLE.
For use with OEM springs or lowering springs and top hats.
Rear:
Monotube, Gas, shock absorber.
Adjustable sir CLIP for + 10 or -10mm rear height.
For use with OEM springs or lowering springs.
Shocks will come with dust covers and be powder coated.
Racecomp Engineering Parts List
Perfect time to order a set of RCE coilovers. I will be putting another order in very soon.
Coilovers
RCE Clubsports-GRB-in stock
RCE Tarmac II-GD('05+STI)-in stock - In stock as of July 1st
RCE Tarmac Zero-WRX('02-07) and STI('04+)-in stock
RCE Tarmac 1-Legacy(05+)-in stock
GR Chassis Clubsports- $2,370US pm for pricing.
GH/GE Chassis 08+ WRX non-STI-$1,995US pm for pricing
GD Chassis-$2,275US pm for pricing
Tarmac 1 Coilovers for 05-09 Legacy $1,675US pm for pricing
Tarmac 0 Coilovers for 02-07 Impreza $1,775US pm for pricing
Sway bar Solutions
04-07 STi Sway bars Front or Rear-$219US pm for pricing
08+ STI Sway bars Front or Rear-$229US pm for pricing
Spring Solutions
Yellow 04-07 STi $339US $375Can
Black 04-07 STi $339US $375Can
WRX Wagon 04-07 $339US $375Can
08+ Regular Guy STI $359US $395Can
Mounting Solutions
Introducing the first in an all new line of parts from GTWorx, the sister company of Racecomp Engineering. Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2008+ Subaru Impreza GR chassis and 2005+ Legacy. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
A fact worth noting is that the relatively straightforward and simple design means that these durable plates are available at a realistic price much cheaper than the popular Racecomp Engineering camber plates.
To be used with coilovers
GTWorx GR front camber plates $389US $428Can
GTWorx GD front camber plates $359US $396Can
GTWorx GD rear camber plates $359US $396Can
Brake Cooling Solutions
Kool Brake Kit GD STI $399US $449Can
Kool Brake Kit GR/2010 Leg.TBA
GTWORX by BILSTEIN
2008+ GH Impreza and WRX shocks $999US pm/email for pricing
We have Whiteline parts in stock for all make/model years of Subaru
Search here for your vehicles part#- http://www.whiteline.com.au/index.php
Strut top-camber/caster adj MOTOTSPORT KCA255M
Anti-lift/caster kit - lwr c/arm KCA359
Anti-lift/caster kit COMFORT KCA362
Anti-lift/caster kit RACE KCA359M
Brace-strut tower alloy adj KSB554
Brace-strut tower alloy adj KSB599
4 point Brace-Lower control arm KSB723
Brace-strut tower alloy adj KSB568
Subframe lock kit KSB750
Front of rear diff support lock KSB751
Gearbox positive shift kit W0584
Gearbox positive shift kit-MOTORSPORT W0584M
Heavy duty steer rack mounts KSR202
H/duty steer rack bushes KSR206
H/duty steer rack bushes KSR207
Roll-centre / bump-steer adjust kit KCA313
Camber adj kit-control arm upper bushes KCA326
Anti-lift/caster kit - lwr c/arm KCA334
Anti-lift/caster kit - lwr c/arm KCA334M Race
Strut top-camber/caster off-set KCA335
Sway bar link conv kit - extra h/d alloy KLC26
Sway bar link-bushed allow link KLC32
Swaybar link kit-spherical rod end KLC39
Swaybar link kit-spherical rod-end KLC066
Swaybar link kit-spherical rod end KLC047
Anti-roll link kit- h/duty adj ball link KLC139
Swaybar mount-h/duty kit KBR20-22
Swaybar mount-h/duty kit KBR20-24
Swaybar 22mm-h/duty Blade adjustable BSF12Z
Swaybar 22mm-h/duty Blade adjustable BSF30Z
Swaybar 22mm-heavy duty BSF30
Swaybar 24mm-X heavy duty Blade adjustab BSF30XZ
Swaybar 22mm-h/duty Blade adjustable BSF33Z
Swaybar 24mm-X h/duty Blade adjustable BSF33XZ
Swaybar 24mm-X heavy duty BSF33X
Swaybar 24mm-X h/duty Blade adjustable BSF36XZ
Swaybar 27mm-XX h/duty Blade adjustable BSF36XXZ
Swaybar 22mm-h/duty Blade adjustable BSF39Z
Swaybar 22mm-heavy duty BSF39
Swaybar 24mm-X heavy duty BSF39XZ
Swaybar 22mm-h/duty Blade adjustable BSR33Z
Swaybar 22mm-heavy duty BSR33
Swaybar 24mm-X h/duty Blade adjustable BSR33XZ
Swaybar 22mm-h/duty Blade adjustable BSR36Z
Swaybar 24mm-X h/duty Blade adjustable BSR36XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR37XZ
Swaybar 27mm-XX h/duty Blade adjustable BSR37XXZ
Swaybar 20mm-h/duty Blade adjustable BSR49Z
Swaybar 22mm-X heavy duty Blade adjustab BSR49XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR49XXZ
If you do not see a part # listed pm/email for availability
I will match price with any Canadian vendor-just forward me a valid quote
__________________
Service Center: 604 530 9160
Email-
"Surrey Board of Trade 2012 business of the year. Providing quality service since 1975!!!"
Last edited by dalesalignment&brake; 08-04-2010 at 04:37 AM. Reason: Updated the title
dalesalignment&brake is offline   Reply With Quote
Old 01-12-2010, 05:15 PM   #2
Member#: 173316
Many other suspension options:
1''drop frt/rr.
I installed a set in an '09 STI and the rideheight looked awesome and it was very comfortable, works well with the stock dampers.
Retail-pm for pricing
Spring and coilover applications
Bottomline pricing:
KW V1 '04+STI-pm for pricing
KW V3 '05+STI-pm for pricing
KW V3 '08+WRX-pm for pricing
KW V3 '08+STI-pm for pricing
Everything in stock
DMS coilovers available-more info here: http://www.dmshocks.com/
'08+STI Group N bushings in stock-every part #
Group n tophats, motor mounts and bushings also available for GD chassis
Coilover and shock options
Coilover andshock options
Brake Upgrades
All DBA and Hawk part # in stock.
'04-09 STI-DTC 30, HP+ and HPS
HB453W.585 Hawk Brake Pad
HB180W.560 Hawk Brake Pad
HB453N.585 Hawk Brake Pad
HB180N.560 Hawk Brake Pad
HB453F.585 Hawk Brake Pad
HB180F.560 Hawk Brake Pad
'02-07 WRX-HPS and HP+
HB352F.665 Hawk Brake Pad
HB434F.543 Hawk Brake Pad
HB432F.661 Hawk Brake Pad
HB452F.545 Hawk Brake Pad
HB178F.564 Hawk Brake Pad
HB179F.630 Hawk Brake Pad
HB432N.661 Hawk Brake Pad
HB452N.545 Hawk Brake Pad
HB178N.564 Hawk Brake Pad
HB179N.630 Hawk Brake Pad
DBA Standard Slotted Rotors
STI-'04
654SL DBA Brake Rotor
654SR DBA Brake Rotor
655SL DBA Brake Rotor
655SR DBA Brake Rotor
WRX-'02-07
650SL DBA Brake Rotor
650SR DBA Brake Rotor
644SL DBA Brake Rotor
644SR DBA Brake Rotor
653SL DBA Brake Rotor
653SR DBA Brake Rotor
DBA 4000 Slotted Rotors
'02-07 WRX('06-07 rears only)
4650SL DBA Brake Rotor
4650SR DBA Brake Rotor
4653SL DBA Brake Rotor
4653SR DBA Brake Rotor
'05+ STI DBA 4000 slotted
42654SL DBA Brake Rotor
42654SR DBA Brake Rotor
42655SL DBA Brake Rotor
42655SR DBA Brake Rotor
05+ Legacy GT Front DBA slotted
42650SL DBA Brake Rotor
42650SR DBA Brake Rotor
DBA 5000 and Performance Friction 2-piece Slotted Rotors
Many options available
Steel braided brake hoses
ATE brake fluid(Blue and Clear)
Ferodo 2500/3500 in stock for STI.
PM for rotor, pad, fluid and steel braided hose combos. This will save you $$$$$.
For a quicker response email sales@dalesmotorsport.com
Last edited by dalesalignment&brake; 03-25-2010 at 06:53 PM. Reason: Updated the title
Old 01-14-2010, 07:22 PM   #3
Member#: 173316
RCE swaybars will be here soon!!!!!
Racecomp Engineering 25mm Swaybars for STi (2004-07)- $235ea
$245ea
Pm/email for pricing
GTWorx Camber Plates for GD ('02-'07) and GRB STI (2008+)
__________________
Email-
Old 01-14-2010, 08:38 PM   #4
sniper913
Member Sales Rating: (7)
Member#: 164943
Hi Jason,
Does the Whiteline KTA125 or KTA126 be used to adjust camber in the rear or simply what are the benefits for these two parts?
THanks
sniper913 is offline   Reply With Quote
Old 01-14-2010, 09:19 PM   #5
Member#: 173316
Camber adj. affects toe and depending on how much camber adj. you make sometimes the factory toe adj. will not be able to achieve factory spec or even close to it. Whiteline offers a toe-adjusting arm so we will never run into this problem.
This problem is very common in the 350z/G35 platform.
__________________
Email-
Old 01-15-2010, 04:17 PM   #6
Member#: 173316
Friday bump
__________________
Email-
Old 01-18-2010, 01:27 PM   #7
Member#: 173316
Monday bump
__________________
Email-
Old 01-19-2010, 01:28 PM   #8
steve
Member Sales Rating: (50)
Member#: 4718
~ too
many to list
I loved my Ohlins that I bought from you.
But then you introduced me to the uber sexy RCE/KW collaboration, and I fell in love again.
my wife does not thank you.
although my lap times do.
steve is offline   Reply With Quote
Old 01-20-2010, 07:21 PM   #9
Member#: 173316
I like your Ferrari, Steve. Have you changed the intermediate shaft yet?
__________________
Email-
Old 01-22-2010, 11:24 AM   #10
slowguy
Member Sales Rating: (20)
Member#: 4326
2010 turdle
Bump for a very knowledgeable vendor!
Helped set up my car on T2s purchased through him and everyone who's sat in my car (friends, instructors @ track) all have nothing but compliments on the set up on my car.
slowguy is offline   Reply With Quote
Old 01-23-2010, 05:17 PM   #11
cordeiroa
Member Sales Rating: (3)
Member#: 209412
2005 subaru STi
World Rally Blue
Great Vendor!
Set me up with my KW V'3 purchesed from him. My buddy liked them so much that he went and bought a set from Dales and got them to do the install.
cordeiroa is offline   Reply With Quote
Old 01-25-2010, 12:52 PM   #12
Member#: 173316
monday bump
__________________
Email-
Old 01-26-2010, 12:38 PM   #13
Member#: 173316
UGLY bump
Poor '09 STI
__________________
Email-
Old 01-29-2010, 10:57 AM   #14
Member#: 173316
Bump for oldschool bug-eye. Should have kept it.
__________________
Email-
Old 01-30-2010, 09:02 PM   #15
C Branch
Member Sales Rating: (8)
Member#: 222120
2003 WRX
Bump for good people! Jason, say HI to Gord for me
C Branch is offline   Reply With Quote
Old 02-02-2010, 01:43 PM   #16
Member#: 173316
Bump for Feb 2
__________________
Email-
Old 02-03-2010, 01:09 AM   #17
Member#: 173316
Default RCE Yellow for GRB and GH chassis intro pricing
I'am now taking deposits on RCE Yellows for the GRB('08+STI) and GH('08+WRX)* chassis.
I will honor RCE intro pricing of $349US+shipping(Can. address), free shipping to the lower 48 if you have a US address. Exchange rate will be calculated day of shipping from RCE. I will dropship from RCE to my Eastern based customers to save on shipping costs.
*recommend upgrading struts on WRX chassis. PM for details
__________________
Email-
Old 02-12-2010, 09:35 AM   #18
Member#: 173316
Only a 3 sets of GRB and 2 sets of GH Yellow springs remaining at intro-pricing.
I also have GD Yellow and Black(Regular Guy) in stock.
''Saggy Butt" spacers for GD also in stock.
Young Subie dude loves these parts(my kid when he was younger)
__________________
Email-
Old 02-16-2010, 10:52 AM   #19
slowguy
Member#: 4326
2010 turdle
bump for my man who loves posting random pictures. (but helps that he's the local suspension guru!)
Old 02-18-2010, 03:22 AM   #20
Member#: 173316
KW pricing update in post #2
__________________
Email-
Old 02-22-2010, 11:23 AM   #21
Member#: 173316
Monday bump for awesome parts
__________________
Email-
Old 02-25-2010, 09:56 PM   #22
Member#: 173316
DMS added and '08+STI grp.N bushings in stock.
__________________
Email-
Old 02-28-2010, 12:58 PM   #23
Member#: 173316
Go Canada Go!!!!!
bump
__________________
Email-
Old 03-10-2010, 11:43 PM   #24
Member#: 173316
wednesday bump
__________________
Email-
Old 03-12-2010, 07:35 AM   #25
Member#: 173316
I have one set of '08+STI RCE T2 in stock. PM me for DISCOUNT pricing.
I also have GD('04-06 STI, *'07 STI) and GRB('08+STI) swaybars coming-pm or email to pre-order, these swaybars are very popular.
* '07 STI use a different front lower c/arm, RCE swaybar can be fitted with adjustable endlinks. PM for more info.
__________________
Email-
Racecomp Engineering updated pricing and parts list-Canada only dalesalignment&brake Suspension/Brakes/Handling 0 12-10-2009 12:43 PM
Race Comp Engineering, Whiteline, DBA, Goodridge, Hawk, Motul FlyingPerformance Suspension/Brakes/Handling 10 07-08-2009 10:02 AM
NEW Suspension parts from Racecomp Engineering! RCE Tarmac Zeroes and RCE Swaybars!!! RaceComp Engineering Suspension/Brakes/Handling 10 05-27-2008 10:25 PM
For Canadian Customers...GB on ANY Whiteline!!! Pole Position Vendor 'Group Buy' Classifieds 9 06-27-2006 06:09 AM
Message Board Statistics All times are GMT -4. The time now is 09:00 PM.
