Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-11-2010, 07:15 PM   #1
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Default Rant!
Does anyone else have a problematic Subaru? It seems like it is never ending with mine.
Too begin with I have an 04 sti, green turbo, PE 850cc, FMIC, 38mm EWG and on.....tuned by Cobb.
So I rarely drive my car, it just barely rolled over 40k miles just last week on my trip that I did not want to take it on. I had to take it because I also have an 08 VW GLI with a DSG garbage transmission that has been in the shop for more recalls then oil changes.
So I took off to Oregon to see family and friends and the car was running perfect until about 200 miles into the trip the cruise control would just random start kicking off, no CELS, it really didnt bug me, my foot could use the exercise.
Well about about an hour later I went to pass a semi and about halfway past him I blow my intercooler hose and have to fade back behind him since the car just shut down. How safe is that? I dont get it, I can drive my car all the time around town and get on it all the time and never haven't blown any hoses in the last 8 months and then I blow it pushing a mere 10psi.
Then I ended up blowing it 2 more times before finally arriving in Eugene but never threw a CEL. As well as my Omori gauges started messing up, my oil temp shows 300 degrees and my O2 sensor just bounces around, evidently they didnt like the trip. So the next day after arriving I went out and pulled the cuppler and clamp to see what was going on, the clamp looked fine but I had a spare so I went ahead and put it on with everything looking gravy. Well after hitting my first stop sign and pulling out into traffic my hose blew again . After that was a quick trip to Walmart to pick up the strongest hairspray available and let me tell you I made sure that thing was stuck.
We turned the boost down to 18psi and took it for a run and it finally stayed in place. So I headed over to the coast for a day driving it super easy since I know the elevation change wasn't really healthy for it. As soon as I hit the coast my CEL was on, now I can under stand the change maybe messing with it but I was able to run a higher octane level in it and not going over 4k rpms, so I was surprised.
Since I had no way to check the code (laptop was left at home) I proceeded to drive it very easy. Then on the way home it started having a fluctuating (sp?) idle from 1k to 2k rpm's and when it finally idles down it idles like a 454. I have not checked the codes yet but I can guess its a misfire code which my car had a problem with last year but compression is good.
And now today I went out to start it around 12 degrees and it starts up and idles up high like normal for about 5 seconds and then idles down and dies. It did this about 4 times before i said **** it!
Now this is what makes me angry, I go to start my civic which has not been drove in about 2 weeks and has snow piled all around it. It starts up first time and idles perfect, now you think well yeah thats normal. Well my civic has over 270k miles on it, d16, gt28 turbo, 440cc injectors, swapped down to OBD1 with a basemap that has never been tuned for the car. How is it that this car can run like a champ and yet my STI that has been professionally tuned and had everything professionally installed run like a lop of ****? I have had over atleast 20 cars now, all modded and this one is the only one I have had everything professially set up on it and dyno tuned and has had the most problems, I guess its just the joys of having a Subaru?
Ok end of rant! I feel better now, any opinions?
skatevolcom06 is offline   Reply With Quote
Old 01-11-2010, 07:22 PM   #2
Not-EWRX
Member#: 158043
2013 Wrx Hatch
I'd rather be in a Highly Modified Subaru more than a highly modified anything else. You're lucky to have made it at all.
Not-EWRX is offline   Reply With Quote
Old 01-11-2010, 08:54 PM   #3
howitz
Member#: 212096
2005 Hella
stock
if i were the ranter/op, that reply would make me soo sad.
howitz is offline   Reply With Quote
Old 01-11-2010, 09:04 PM   #4
chicakms
Member#: 183449
2010 Impreza 2.5i
Camellia Red Pearl
My brothers car we were just saying this tonight his Leggy is cursed it's not modded. While he doesn't exactly take the best care of it I think he's been through 1-2 tranmissions also 1-2 head gaskets. Last month they just spent $5,000 to fix a bunch of other stuff. Tonight he came home and his drivers side door wont open and he can't get the window up so him or my dad had to tape plastic up in case it rains or snows. We had trouble with the back window falling down before too. Every time we turn around something is breaking down. It's an '02.
Here's the thread about all that was wrong with it
http://forums.nasioc.com/forums/show...4&postcount=34
chicakms is offline   Reply With Quote
Old 01-11-2010, 09:42 PM   #5
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
not-ewrx - I know what you mean, I love my subaru to death.....when it runs!
chicakms - That sucks to hear, I am surprised he has kept it after all of that work!
Old 01-11-2010, 09:52 PM   #6
chicakms
Member#: 183449
2010 Impreza 2.5i
Camellia Red Pearl
He can't afford anything else. He's made some bad judgments in the past speeding tickets and 2 dwis so his insurance is sky high we even had to take collision off the car to make the insurance affordable. I think he pays 3-4,000 a year and that's without the collision.
Back in Dec or whenever all the work was done my parents were trying to weigh the pros and cons of getting him another used car but again you don't know what you're getting if you buy used and at least if he kept the jinxed car we knew everything would be brand new. Also we couldn't find anything used with low miles under $8-10,000. So they are praying the car the car lasts a few more years.
It was my moms car originally she drove it for a few years. Prior to buying that car my mom had another leggy an '01 and she said she could feel the difference between the '01 and '02 in the way they handled and even the interiors the '02 was made cheaper it was a fleet car.
Old 01-11-2010, 10:22 PM   #7
soob noob
Member#: 220158
02 bugeye
medamullet tuned
thats a bummer man. i really hope that you can get it running "right". good luck to you man
soob noob is offline   Reply With Quote
Old 01-11-2010, 10:23 PM   #8
chicakms
Member#: 183449
2010 Impreza 2.5i
Camellia Red Pearl
Thanks
Old 01-11-2010, 10:46 PM   #9
axleon2
Member#: 154117
2003 Forester
Isn't every car like this? Just think it could be worse...my bro has taken his car to Mark Miller Subaru 6 times to rebuild/fix his engine and every time they say it's fixed it's not. They SUCK at what they do...just FYI.
axleon2 is offline   Reply With Quote
Old 01-12-2010, 12:11 AM   #10
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
Dang man, sorry to hear your still having issues with it I remember all the hell it was giving you that day i saw you at cobb
JokerDMX is offline   Reply With Quote
Old 01-12-2010, 12:20 AM   #11
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Sorry but it's the risk you take when modding a car. Well unless it's NA, simplicity is reliability. Now watch my car blow up tomorrow.
aclver1 is offline   Reply With Quote
Old 01-12-2010, 12:43 AM   #12
WRX N EFX
Member#: 157721
2003 WRX
i blew a hose off up in the mountains with no tools or phone reception and few times around town. i just put tbolt clamps on and ive never blown one since
WRX N EFX is offline   Reply With Quote
Old 01-12-2010, 03:07 AM   #13
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Yeah, one day she will work right. Hey I still need to send you those Wendover photo's. PM me your email some time.
See below, also my friend said he really like your car so don't blow it up tomorrow!
Yeah I understand the risk and the problems that come along for the ride, but in all the cars I have modded and built this one has been the worst. Even out of all the Volkswagens I have dealt with, which before I got my Subaru I thought VW were horrible just because of electrical problems. Eventually you will find the problem in a VW, my sti has been to 2 local mechanics, 1 dealer (never going to a dealer again!) and Solid, no one can figure out the misfire issue. I think I have spent over $2k alone in mechanics fee's trying to figure this out, not even counting random parts like new coilpacks, injectors, sensors, etc.
Wow, how did you get home? I always use tbolts, infact the one I replaced looked like I may have went a little to tight with it but still held perfectly. I always tend to carry a 10mm socket and ratchet in my door of all my cars, it is amazing how handy it is!
Old 01-12-2010, 03:16 AM   #14
WRX N EFX
Member#: 157721
2003 WRX
I waited for someone to come by with tools, finally a guy with motorcycle trailer came by. now i have a backpack full of tools i keep with me
Old 01-12-2010, 11:02 AM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
You wish! One good reason to swap that pretty motor you have sitting in the garage.
medamullet is offline   Reply With Quote
Old 01-12-2010, 04:48 PM   #16
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Yeah you should definitely swap that STI engine in now!
Old 01-12-2010, 04:51 PM   #17
nme187
Member#: 117763
Agreed.
nme187 is offline   Reply With Quote
Old 01-12-2010, 05:43 PM   #18
toddguy
Member#: 158534
99 2.5 Wagon
76 Datsun 280Z
yeah! NA FTW! my car sounds like **** when i start it in the cold... but it still runs like a champ at 11 years old. but my gas mileage kinda sucks preeeettttty bad lately.
oh and sorry bout your car OP... it'll work out.
toddguy is offline   Reply With Quote
Old 01-12-2010, 11:33 PM   #19
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Could be worse, you could have spent the $11,000 on modifications, blow the motor, buy a built motor and pay for install stuff which costs another $11,000. The built motor knocks all over the place yet everything looks, sounds, smells fine. You then have to ship your entire car to the engine builder who has been using your car as a Daily driver for a week now and has yet to find the problem.
Love my Subaru
Stames_wiltz is offline   Reply With Quote
Old 01-13-2010, 12:38 AM   #20
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Love my Subaru
or even worse you could have blown 2 transmissions and 3 motors....
bhhamblin is offline   Reply With Quote
Old 01-13-2010, 01:26 AM   #21
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
You know I would much rather blow the engine or a transmission right now, atleast I would know whats wrong with the damn thing. I am seriously thinking of starting over completely. I want to pull the current engine/turbo and junk it and start with a new longblock and go back to the TMIC with a Blouch 2.5 and meth.
Old 01-13-2010, 10:38 AM   #22
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Well i hope you figure it out, it sucks trying to hunt down ghosts. If you need a new block let me know, i still have one.
Old 01-13-2010, 12:33 PM   #23
Stames_wiltz
Member#: 143264
2006 WRX TR
I promise you don't want a blown motor. It is nice to know exactly what is going on with the car, which I have none.
Old 01-14-2010, 02:15 AM   #24
godfather2112
Papi Chulo
Member#: 53794
2005 BMW M3 - 6spd
2007 Denali Land Yacht
Dude its a modified car, what do you expect?
godfather2112 is offline   Reply With Quote
Old 01-14-2010, 02:37 AM   #25
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Dude, did you read anything above?? I know its a modified car and I know the consequences, what I am saying is I currently own 4 modded cars including 2 NA to Turbo and out of all of them the Subaru runs the worst. All the issues I ever have are with the Subaru, not any of the other cars.
Examples why it pisses me off if you missed it above. I run 15 psi daily in my d16y7 civic on meth with the original block with new oem pistons. That block has only been honed and has over 270k miles on it and not a single issue. I can drive this thing to SLC with out the check engine light ever coming on and get 35 mpg and never have an issue. My black 240sx has an s13 sr20det built bottom swap in it running a gti-r turbo, no problem with it besides being stuck in the snow at the moment. I just know from my experience from modding plenty of cars this one is the worst one yet! And this is coming from a background of volkswagens.
