Old 01-12-2010, 10:29 AM   #1
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Default Any problems Cobb stg 2 stealthback?
I have an 07 wrx that's going stage 2 this weekend. Running a Cobb catless downpipe into a stock catback. I'll be changing out the vacuum line with the restrictor pill to avoid boost creep/spike. I'm just curious if anyone is running the same setup and what issues if any you guys are having.
My old 02 wrx was stage 2 but I as I'm learning, the 2.5 motor is a whole new animal.
Pearly_Whites is offline   Reply With Quote
Old 01-12-2010, 04:07 PM   #2
RayN
Member#: 135789
2005 STi
CGM
unless you are installing a aftermarket boost solinoid or a MBC, leave the restrictor pill alone.
RayN is offline   Reply With Quote
Old 01-12-2010, 06:13 PM   #3
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Direct from cobbs website... It says to change the pill because 06-07 wrxs don't like being catless. They supply the new recomended vacuum line free of charge. It's supposed to stop the boost creep. Something to do with my motor using a smaller restrictor pill and the boost control system being mechanically over run.
Old 01-16-2010, 05:26 AM   #4
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Bummp... Install is tomorrow..
Old 01-17-2010, 09:36 PM   #5
RayN
Member#: 135789
2005 STi
CGM
here is your map notes..
http://www.accessecu.com/accessport/...3%20MTv103.pdf
it dont state to remove your restrictor pill. and i would follow what it says on the map your going to be using. also cobb states that you should try it with the restrictor in place first to make sure that it will work and if not to remove it.
http://www.cobbforums.com/forums/sho...highlight=pill
Old 01-18-2010, 12:09 PM   #6
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
From what I understood, Cobb was saying if you are using a free flowing exhaust, to replace the restrictor pill with the larger diameter one they provide.
To save everyone time, here's what i did and my current setup.
I'm used cobbs catless downpipe mated to the stock wrx midpipe with resonator and muffler. Replaced the vacuum line with the new one Cobb sent me. Took it for a ride and was only hitting about 8lbs of boost after the stage 2 reflash.
I then took out cobbs vacuum line and put the stock one back in. Boost was immediately better. Running strong at 15.3lbs and peaking at 17 or so.
The car feels great now and I hardly have any increased noise over stock. Just a nice low burble and some noticable turbo spooling sound.
I haven't encountered any overboost yet but this could be because my exhaust isn't exactly free flowing. Possibly the added back pressure of the stock catback is preventing the overboost conditions Cobb is warning about
Old 01-18-2010, 07:57 PM   #7
RayN
Member#: 135789
2005 STi
CGM
not really. as i am running 19 psi on my car now and will still hit target boost even if im running my stock catback. your not running enough power for any catback to be restrictive. at this point a aftermarket catback is more of a noise maker. the downpipe is the biggest restriction factor. if your not spiking now, you wont in the future and your boost control set up is working just fine.
Old 01-19-2010, 07:27 AM   #8
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
I don't see how my downpipe is restrictive if it's a 3in catless. Either way things are running great and I'm really pleased with the stage 2 results. I might try to find an sti catback to replace my stocker
Old 01-19-2010, 04:29 PM   #9
RayN
Member#: 135789
2005 STi
CGM
sorry i meant as your stock downpipe being the restriction.
Old 01-21-2010, 02:32 PM   #10
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
Ahh ok. I figured maybe I missed something lol I know I'm losing a couple ponies but the sleeper factor is incredible. Nobody even looks twice at it. The girlfriend just
thinks it smells funny haha
CA smog testing - full Cobb Stg 2 - problems? MaxSTi05 AccessPort 4 02-17-2007 09:49 AM
Cobb Stg 2 vs Vishnu Stg 0... SilverE2 AccessPort 23 04-05-2006 11:48 PM
Has any cobb stg 2.5 wrx raced a cobb stg 1 sti? cheese tits Proven Power Bragging 41 12-22-2005 04:25 AM
Change from Cobb Stg 1 to Cobb Stg 2? cool555 Engine Management & Tuning 5 04-17-2005 12:53 PM
COBB Stg 2 power package + Stg 2 heads + reflash = ??? Teh Legacy Normally Aspirated Powertrain 11 10-17-2003 03:09 PM
