Old 01-12-2010, 11:04 AM   #1
enjoiwrx
Member#: 109362
2005 Impreza WRX HYB
World Rally Blue
Default Want to change Trans. Fluid & Diff. fluid what should i use?
Hello all!! I have a 2005 WRX 2.5L Hybrid, 3inch Invidia bellmouth DP, SPT Catback, Invidia uppipe. Tuned by DPS.
Want to change those fluids and i have some AmsOil Severe Gear (synthetic extreme pressude lubricant)75w90 that a shop recommended i use on my car. I would think this is ok for the diff. but for 5spd manny trans do i use the same thing? Want to know if this is ok or what else should i use to do these services. Thank you!
P.S. its says formulated for severe duty applications...
enjoiwrx is offline   Reply With Quote
Old 01-12-2010, 12:36 PM   #2
BumbleBeeTuna
Member#: 234879
2003 WRX WAGON
I just swapped my trans fluid to Subaru Extra S and love it!! Shifts so smooth, I had Redline in it before and had problems going into first, now shifts in like butter.
Diff will take that 75w90 AmsOil youve got just fine. I just run Regular cheap 75W90 in my diff with no problems so far.
BumbleBeeTuna is offline   Reply With Quote
Old 01-12-2010, 01:02 PM   #3
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
+1 for Extra S
thrasher is offline   Reply With Quote
Old 01-12-2010, 01:27 PM   #4
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
i did my tranny and went Lucas. Lucas all the way. not sure on the diff but i dont think it will make a difference what you use
crash60068 is offline   Reply With Quote
Old 01-12-2010, 02:58 PM   #5
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
You can put Colavita Extra Virgin Olive oil into your rear diff and it'd work fine . But use good stuff for the tranny....Extra S or Motul 300.
09rexwagon is offline   Reply With Quote
Old 01-12-2010, 08:36 PM   #6
sonic03rex
Member#: 40534
2016 WRX
Yeah don't use anything in the rear(STI) other than Subaru LSD fluid.. I learned the hard way..
sonic03rex is offline   Reply With Quote
Old 01-12-2010, 09:17 PM   #7
jetski247
Member#: 188171
04 sti baby
wrb
how often should you change your drivetrain fluids
jetski247 is offline   Reply With Quote
Old 01-12-2010, 09:31 PM   #8
bluesubie
Member#: 767
04 FXT
I liked the Amsoil Severe Gear 75W-90 for the first 20k miles and then it started to grind. This was actually the first time I had grinding from a synthetic gear oil (driving manual subes since 97). Some folks are satisfied with it. I switched to Extra-S and I'm very happy with it.
Congrats on the 14th gear oil post for the week.
As often as the manual says.
-Dennis
bluesubie is online now   Reply With Quote
Old 01-13-2010, 11:22 AM   #9
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
I prefer oils I can buy locally.
I just changed my tranny & diff fluid this weekend.
This will be my second change running 1 qt 75w-90 valvoline synpower and the rest 75w-90 valvoline dino oil in the tranny. This seems to work a little better in the cold which is what I wanted. It is still tough to downshift into second when cold, but the gearbox doesn't feel like sludge on a cold morning.
I use M1 75w-90 in the rear diff. Definetly use a syn oil in the rear diff.
If Extra-S was sold in qts at a reasonable price I would try it.
WRXSleeper is offline   Reply With Quote
Old 01-13-2010, 11:54 AM   #10
09rexwagon
Member#: 216135
2011 Civic SI
No need to use synthetic in a R160....anything with an inkling of lubricity will work in that rear diff .
You can get a 20L bucket of Extra S shipped from Chaplins for a cost per unit quart of about $8/qt.
Old 01-13-2010, 12:15 PM   #11
thrasher
Member#: 40579
2002 WRX Stage 2+
Yeah, the best thing to do is find one or two other locals who need Extra S too, have one person order it, and then divide it up and split the cost. Or if you change it every 15K and you rack up miles quickly, just hang onto it. I chose to sell my extra because it takes me 5 years to drive 15K miles.
Old 01-13-2010, 08:59 PM   #12
bluesubie
Member#: 767
04 FXT
Or, if you're lazy like me just order it from Fred Beans parts.com .
-Dennis
Old 01-14-2010, 09:22 AM   #13
gundamwrx
Member#: 103947
2003 WRX
I am using Motul in my trans and rear diff. for my 03 wrx. It works well, but it is a bit pricey.
Extra S should be fine, too. It is OEM after all.
gundamwrx is offline   Reply With Quote
Old 01-27-2010, 02:58 PM   #14
meccjoo
Member#: 97522
+1 for extra s in tranny and diff
meccjoo is offline   Reply With Quote
Old 01-27-2010, 03:14 PM   #15
Boxer_Boy
Member#: 199872
07 STI
SWP 387 WHP
What should I use in my 07 sti rear? I think its a R180???
Boxer_Boy is offline   Reply With Quote
Old 01-27-2010, 03:48 PM   #16
steverx05
Member#: 128269
I hope you're not using LSD fluid in your 08's rear diff.
steverx05 is offline   Reply With Quote
Old 08-18-2010, 04:07 PM   #17
AeroWRX
Member#: 199026
2004 WRX Wagon
-Dennis
Just noticed the site change, does Fred Beans not sell Subaru Extra S oil anymore?
AeroWRX is offline   Reply With Quote
How difficult to change transmission and rear diff. fluids? big_dog Service & Maintenance 20 01-08-2009 01:53 AM
Time to change tranny and rear diff fluid - what to use?? madmax02 Transmission (AT/MT) & Driveline 6 06-27-2008 01:51 PM
Want to re-invent myself and my life. What should I be when I grow up? Davenow Off-Topic 70 02-13-2006 11:23 PM
How to change rear and front diff. fluids? skyredrex Service & Maintenance 1 01-05-2004 04:30 PM
I`m changing my Diff fluid what should i use Wheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-11-2001 07:45 AM
