Old 01-12-2010, 12:17 PM   #1
krazy
Member#: 56400
2004 Subaru STi-SOLD
custom roofrack brackets!
Question Does your AC compressor clutch ALWAYS spin freely?
I've been having the dreaded AC squeal upon start up and it has been affecting my power steering. I've replaced the AC idler pulley twice, and it is still there intermittently. Without the AC belt the car is PERFECT. No steering wheel shudder, no squeak, squeal or hiss. So the culprit is the AC compressor. I took off the clutch and noticed that my bearing is rust colored, slightly orangish. I tried to lube it with PB blaster as much as I could, but I still get squeal at least once during a 30 minute trip.
Steering shudder is the there only at certain times, and when the AC clutch engages there is a hiss or grinding noise. AC still blows cold.
My theory: Air pocket in the refrigerant lines causing the compressor difficulty to engage at certain times (i.e. morning when the refrigerant has been sitting in the lines over night, or when the car is compressing the AC).
Or it could be that the bearing is just failing, and causing intermittent squeals.
So, does the clutch ALWAYS spin free when its not engaged? or does it have spots where it seems like its having trouble compressing liquid?
Thanks!
krazy is offline   Reply With Quote
Old 01-12-2010, 12:32 PM   #2
BumbleBeeTuna
Member#: 234879
2003 WRX WAGON
Your AC compressor should spin freely without the AC clutch engaged, for example with the defrost and A/C switches turned off. If the pulley does not spin free all the time then your compressor bearing could be wearing out. The front clutch will be hard to spin but if you spin the actual pulley where the belt rides it should spin free. Hope this helps.
BumbleBeeTuna is offline   Reply With Quote
Old 01-12-2010, 12:41 PM   #3
krazy
Member#: 56400
Yea, I've noticed that the front clutch is hard to spin. I dont think theres a way to check if the compressor spins freely if the belt is on though. I wonder if anyone has attempted to rebuild the clutch housing.
Old 01-22-2010, 11:52 PM   #4
BumbleBeeTuna
Member#: 234879
2003 WRX WAGON
I know on some domestics the front clutch is available, then you have to set the gap between the too, not sure if you can find one for a Subie though.
AC Compressor Clutch Replacement? DriftinS14 Service & Maintenance 32 11-20-2013 11:48 AM
WTB: 1995 AC Compressor Clutch awaken101 Private 'Wanted' Classifieds 1 04-25-2009 09:04 AM
AC compressor clutch / compressor smeghead Private 'Wanted' Classifieds 11 10-01-2007 12:53 PM
AC compressor has trouble spinning.. BlackPearlX Service & Maintenance 12 08-02-2007 02:29 PM
Can you "oil" your AC compressor? geepondy Service & Maintenance 3 07-22-2004 09:44 PM
