Mid Atlantic Impreza Club
Old 01-12-2010, 01:11 PM   #1
infinite012
Member#: 74392
2015 Forester
Default Oil gallery plug or sandwich adapter?
Who wants to help?!!
I just picked up a sandwich adapter from Mach V, but I'm having second thoughts about using it for my oil pressure sender. I removed the Prosport oil temp sender from the oil gallery plug next to the PCV valve because the Defi sender has such an awkward shape.
So... which should I use? The oil gallery plug or the sandwich adapter?
In either case, who wants to help me get this sender installed? Free beer!
Falls Church, VA.
infinite012 is offline   Reply With Quote
Old 01-12-2010, 01:33 PM   #2
paintballjunky
Member#: 95953
2004 WRX Wagon
2013 Aprilia Shiver
I had the sandwhich adapter on my last wrx, worked great. Used for prosport pressure and temp sensor. Never used the oil gallery sensor, but the sandwhich was very easy to install, just make sure you teflon the sensor threads, and do your oil change at the same time Let me know if you have any questions if you decide to put it in!
paintballjunky is offline   Reply With Quote
Old 01-12-2010, 02:59 PM   #3
steverx05
Member#: 128269
'15 STi
[CWP]
You're readings won't be as accurate using a sandwich adapter. The place you already had your probe mounted for oil temp was ideal. I had a Defi temperature sensor in my oil gallery on my old WRX with no issues.
steverx05 is offline   Reply With Quote
Old 01-12-2010, 03:08 PM   #4
Ceez3607
Member#: 138243
07 WRX STI 3076
Oil gallery plug gets my vote, I can help you when it's warm out
Ceez3607 is offline   Reply With Quote
Old 01-12-2010, 03:20 PM   #5
goldshuscooby
Member#: 177641
2011 STi
SWP and Stage 1
I'm using the sandwich adapter for my prosport guages and I have no issues, but IDK what the defi sender that you're calling akward looks like... SO I would do what seems best (fitment wise and possibly easier )
I can help you down in richmond if you don't have it done yet by next week. My car is down until my coilovers get in and there seems to be a problem with customs so WHO KNOWS how long it's gonna take. I was supposed to have them last wednesday.....
goldshuscooby is offline   Reply With Quote
Old 01-12-2010, 04:00 PM   #6
infinite012
Member#: 74392
2015 Forester
So that's 2 for oil gallery and 2 for sandwich adapter.
I'm personally getting very good at getting the intercooler off. Working on getting the intercooler on quicker lol
Old 01-12-2010, 04:25 PM   #7
mla163
Member#: 104922
2016 WRX
I had sti robot halp with mine. He knows gauges. I asked the same question. He said he had tried both, and the most idiotproof is the gallery plug.
You will need to get the relocator. I think machv sells it too.
mla163 is offline   Reply With Quote
Old 01-12-2010, 05:14 PM   #8
infinite012
Member#: 74392
2015 Forester
Screw! I just forced the bitch into the gallery plug. That was an awkward 30 minutes with needle nose pliers and a light attached to my forehead
I'll be going back to Mach V tomorrow to return the sandwich adapter.
Here's to hoping it doesn't leak
Old 01-12-2010, 05:30 PM   #9
PSM_02_WRX
Member#: 197108
2003 Ford Mustang GT
I have the sandwich adaptor. Just make sure if you ever do it, to wrap with the silicone tape so no leaks.
PSM_02_WRX is offline   Reply With Quote
Old 01-12-2010, 06:02 PM   #10
SEEK
Member#: 143040
2008 WRX
SWP with some gold
i have the blt sandwich.
SEEK is offline   Reply With Quote
Old 01-12-2010, 06:11 PM   #11
steverx05
Member#: 128269
'15 STi
[CWP]
Good job
A sandwich adapter is basically useless on our motors so you will be happy with your sender in this location.
Old 01-12-2010, 06:20 PM   #12
goob_os101
Member#: 173185
2005 Saabaru
use the galley and get a sender relocation kit to mount the unit up near the stock alarm to avoid the unit being vibrated out of place
goob_os101 is offline   Reply With Quote
Old 01-12-2010, 06:26 PM   #13
infinite012
Member#: 74392
2015 Forester
Will that happen? I've had the oil temp sensor in the same location for about 2 years and it didn't leak.
Old 01-12-2010, 07:43 PM   #14
goob_os101
Member#: 173185
2005 Saabaru
I don't think it's for the leaks but more for the unit itself getting messed up by the vibrations. Cnat speak from experience since I have yet to install I...
Old 01-13-2010, 11:31 AM   #15
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Good pick on the galley plug sandwich adapters ftl
LeeC is offline   Reply With Quote
Old 01-13-2010, 03:31 PM   #16
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
details in this please, and also i know i may be dumb for asking this, but where exactly is this galley plug at, that i can replace with a threaded one for the sensor
rllyrckt is offline   Reply With Quote
Old 01-13-2010, 03:33 PM   #17
paintballjunky
Member#: 95953
2004 WRX Wagon
2013 Aprilia Shiver
Originally Posted by steverx05 View Post
Good job
^can you explain this
Old 03-06-2010, 09:45 AM   #18
anon_az
Member#: 160782
2004 Impreza WRX STi
Has anyone ever tested this? I'd be interested in seeing two gauges hooked up simultaneously (one reading the galley plug and the other reading a sandwich plate) to one motor to see if there's any real difference.
anon_az is offline   Reply With Quote
Old 03-06-2010, 12:36 PM   #19
steverx05
Member#: 128269
'15 STi
[CWP]
Yes, it has been proven before...just do a search on Scoobymods. Peaty was getting readings about 20-30 degrees hotter by using the galley plug location. Basically, the oil passes through the stock oil cooler before it reaches the sandwich adapter, so the temp reading comes out a lot less than if you had a sensor in the galley spot. A sandwich adapter also makes the oil filter sit down lower, which some people might not care about, but I wouldn't be comfortable with it.
Old 03-06-2010, 01:04 PM   #20
Girion47
Member#: 240113
2010 WRB WRX 5dr
2013 DGM WRX 4dr
I'm thinking about installing a "Make a sandwich" adapter on my wife, does anyone know how well these perform?
Girion47 is offline   Reply With Quote
Old 03-06-2010, 05:22 PM   #21
anon_az
Member#: 160782
How about pressure readings?
Old 03-06-2010, 06:43 PM   #22
steverx05
Member#: 128269
'15 STi
[CWP]
I don't know about pressure readings, I would assume it would at least be similar in difference between the two locations, possibly not as much of a difference as temp but still different. To me, it makes the most sense to tap a sensor into the location of the stock oil pressure sensor, which is in the galley plug underneath the alternator.
Old 03-11-2010, 02:56 PM   #23
sourcandy
Member#: 212410
let me know if your installation is successful!
sourcandy is offline   Reply With Quote
Oil Pressure/Oil Temp/Oil Gallery plug WRenXhaven Electrical & Lighting 28 05-28-2009 01:54 PM
subaru oil gallery plug adapter $15 Wannascooby Accessories & Misc 0 11-30-2006 02:12 AM
Oil Galley plug or Sandwich adapter? audiophil2 Interior & Exterior Modification 10 08-18-2005 02:26 AM
Wanted: the plug you remove to put in an oil gallery plug North Ursalia New England Impreza Club Forum -- NESIC 15 07-01-2005 02:41 PM
oil gallery plug adapter size? subaruisme Electrical & Lighting 6 03-08-2004 01:11 PM
