Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-12-2010, 04:10 PM   #1
CenCali07sti
Member#: 144523
2007 Sti
Satin Pearl White
Default Need help with Zeitronix 3.5bar map sensor calibration
I have been searching as much as possible on how to calibrate it correctly after install. But I just cant seem to find a deffinite answer. I have the ATR tuning guide downloaded and read the formula to calibrate it. I have found conflicting threads about the numbers being correct for the sensor.
This is the answer I found which came from a excel paper supposable from this cobb. I found the link on this site.
3.50 BARa 700 +/- 10 Zeitronix 3.5 BAR MAP Sensor Multiplier
3.50 BARa -414.00 Zeitronix 3.5 BAR MAP Sensor Offset
Can anyone confirm these are the correct numbers for a 2007 sti. The excel sheet says for a 2004-2006
CenCali07sti is offline   Reply With Quote
Old 01-18-2010, 04:33 AM   #2
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
mmm.... ok here you go
http://forums.nasioc.com/forums/show...ight=Zeitronix
a6n6d6y is offline   Reply With Quote
Old 01-18-2010, 01:59 PM   #3
CenCali07sti
Member#: 144523
2007 Sti
Satin Pearl White
Thanks a6n6d6y. I actually did find that post but I must have been up to late at the time I never even read through your third post. So are those numbers still working out for you?
Brandon
Old 01-18-2010, 07:39 PM   #4
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
don't have the FXT anymore, but yes those numbers work
Old 01-19-2010, 03:20 AM   #5
CenCali07sti
Member#: 144523
2007 Sti
Satin Pearl White
Thanks for the info. I am going to install it tomorrow. I am looking at the wiring diagram for my sti and it looks as though factory map sensor is wired as the following.
Red = 5v
Black = Ground
Orange = Output
The wiring diagram shows the orange wire going back to the ECM
I am sure its right just want a second opinion
FS (NY): AEM 3.5Bar MAP Sensor w/ Cobb MAP Adapter Mac323 Engine/Power/Exhaust 3 02-22-2010 07:43 PM
gm 3.5bar map sensor where to find?? jonnies Newbies & FAQs 1 02-11-2009 06:17 PM
FS: 1000cc topfed injectors & 3.5bar map sensor DoctorNick MWSOC Private Classifieds 2 06-06-2008 03:55 PM
FS:NY: Forge MBC AEM 3.5bar Map Sensor + more spoolinsti05 Engine/Power/Exhaust 4 03-12-2008 09:56 PM
Help With GM 3 Bar MAP Sensor VWGrk1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-01-2005 06:36 PM
