Old 01-12-2010, 04:26 PM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default Removing the heater core...
I'll be stripping the heater core out of my car when I do the diet. Removing it isn't my question. If you've removed your heater core, what did you do with the coolant lines on the block? I have to leave mine in because the turbo is water cooled. I need to bridge the lines on the driver side rear of the block. I'd prefer using fittings, but there's nothing to tap. A little semi-circle piece of coolant hose would look sloppy and might create potential for leaks.
Suggestions?
HamFist is offline   Reply With Quote
Old 01-12-2010, 04:48 PM   #2
nme187
Member#: 117763
You can buy rubber caps and hose clamps from an industrial supplier.
Marshall's Industrial Hardware, LLC
2210 West California, Ave.
Salt Lake City, UT 84104
Phone: (801) 978-0555
nme187 is offline   Reply With Quote
Old 01-12-2010, 05:20 PM   #3
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
(Take this with a grain of salt. I only looked once.)
From the looks of things, it has to remain a complete circuit. I'll check again to make sure. The rotated turbo's return is tapped into the heater core inlet line on the top of the block. It doesn't go into the coolant "crossbar." The turbo coolant is routed into the external coolant line on the Driver side, from the rear. My thought process was that the coolant all needs to still return to the bottom of the block, thus remaining a complete circuit. The turbo returns to the driver side of the head. But, starving the inlet return on the driver side of the head would make it run hot and pop, wouldn't it?
An EJ22T block has the coolant routed externally with lines to the thermostat from the heater core. I think all turbo blocks are like that. I looked at removing these altogether, but the turbo needs it's coolant for the water cooled center section. That drains into the back of the cylinder head. Supply comes from these external lines.
I'm pretty sure the lines need to be connected and rerouted. There's about 3 inches of space to work with right there on the back of the DS head. Making it look pretty and neat is where I'm a little stuck. Little details like this are where I get hung up due to having a the same n/a block for 10 years.
Old 01-12-2010, 06:00 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Having the lines connected allows a constant coolant flow out of the block and right back behind the thermostat. As the engine warms, the coolant warms and this constant cycle helps open the thermostat as well. That's one of the benefits I see. I do notice that the thermostat has a little hold with a pill/plug thingy on it. Allows for coolant cycle from the radiator???
When straight up track car.. I would cycle all coolant out to the radiator.
FuJi K is online now   Reply With Quote
Old 01-12-2010, 08:36 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
just wondering other than weight, why remove the heater? It has MANY uses. IE defog your windows( unless its a stripped drag car I dont see the point) and also it your engine is running hot you can turn the heater on and help bring temps down.
scby rex is offline   Reply With Quote
Old 01-13-2010, 12:53 AM   #6
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It is a straight up track only car. E85 runs really cool to the point of having trouble building heat some times. I'm being careful about managing heat. An trans + oil cooler might be a good idea. I'll have a huge WAIC unit on the car as well. I'm dropping weight as close to 2000lbs as possible. Any and all interior will be notoriously absent anyway. I'm gonna put Kate Moss to shame .
Space is still kinda precious under there. Just routing the coolant lines in a short space is what I need to do.
Old 01-13-2010, 06:29 AM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
There are some nice coolant flow diagrams in various FSM. I'd say that capping the heater connections would be a bad idea. The circuit allows continuous flow to stabilize coolant temperature otherwise the temperature would go very high in certain areas (inside the the left head specifically).
I can't say for sure but I think blocking off the heater passages caused a recent engine failure of mine. My heater core was leaking and I just took one of the hoses and routed it back to the other port. The hose was kinked so water wasn't flowing. The car ran fine for 150 miles and then suddenly the temperature started to rise and even dropping to neutral didn't stop it from pegging.
Edit: Here is the Legacy Turbo layout (which is essentially the same as all the current setups)
See how blocking the heater would keep the water from flowing through the left head when the thermostat is closed, except for a tiny amount through the throttle body? It explains why when I poored water on the engine it did basically nothing on the block but sizzled like mad on the heads.
I'd argue that a higher flowing heater core (or a U shaped piece of bypass hose) would actually improve coolant temperature stability!
Old 01-13-2010, 03:15 PM   #8
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Ciper, you confirmed my fear! It would be a bad temperature rise on only part of the block.
How to reconnect this without kinking anything is the tricky part. I don't want a "loop" of line hanging loose that could get caught on anything or kink up.
Old 01-13-2010, 03:27 PM   #9
RexRexRex
Member#: 37389
2003 gt35r wrx
Built not bought
when I removed my heater core i just looped the coolant lines. will try to get pics up tonight.
RexRexRex is offline   Reply With Quote
Old 01-13-2010, 05:25 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
In my latest engine build I bent the hard lines so they were farther away from each other. I then grabbed a random piece of heater hose with a few 90 degree bends (volvo i think) and made a U shaped adapter that is probably three inches long. Its literally the hard line, a short section of 90 degree bend hose, small male to male adapter, another short 90 and the hard line.
The only interference was between this loop and the auto transmission cooling lines. I bent them down slightly and all is good.
edit: Here is a picture
Old 01-13-2010, 11:33 PM   #11
555ideways
Member#: 36652
I learned this the hard way on my STi track car. If you insist on removing the heater core you must keep the circuit. If you cap it you WILL have problems with the thermostat in certain situations.
We had a dyno rented for the day and we were stuck in the garage trying to get the water temps to stabilize. It was really frustrating. Sometimes you just don't mess with oem systems.
-Paddy
555ideways is offline   Reply With Quote
Old 01-13-2010, 11:59 PM   #12
piddster
Member#: 144285
1993 UHEV Legacy
Removing the heater core saves you minimal weight while sacrificing any way to defog your windshield. It is one thing to remove the evaporator core and all the associated AC stuff, but removing the heater core for ten pounds is borderline. Race car or not.
piddster is offline   Reply With Quote
Old 12-19-2010, 04:38 AM   #13
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
This thread has gone quiet, so I'm going to hijack it for a bit, on a similar note.
Anyone have any views on disconnecting the water lines to the Throttle body and IAC? It is for a track only car and ambient temps anything from 60 deg F to 100 deg F.
I just want to get rid of hoses if I can.
renhoek is offline   Reply With Quote
Old 01-10-2012, 05:02 PM   #14
MaxMendez
Member#: 108493
04 WRX
Hybrid RI GT30
I bypassed the throttle body heater lines and the heater core. I made this fitting to make things a little neater. So there is just one hose going down to the water pump pick up...
MaxMendez is offline   Reply With Quote
Old 01-16-2012, 09:25 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
Personally I'd bypass the coolant passage on the throttle plate. Its only purpose is to keep the throttle plate from freezing open which could cause you to have no vacuum and if you pumped the brakes you would loose brake assist. In other words its unlikely, even though remotely possible, to kill yourself.
MaxMendez Nice piece
Old 07-28-2015, 12:28 AM   #16
choi0706
Member#: 126548
got anymore?
choi0706 is offline   Reply With Quote
Old 09-16-2015, 02:29 AM   #17
choi0706
Member#: 126548
bump..
Old 09-16-2015, 11:22 AM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by choi0706 View Post
bump..
According to his profile page, MaxMendez hasn't been active on the forum since a couple days before you posted 6 or 7 weeks ago. Try sending him a PM rather than fruitlessly bumping a thread from 3-1/2 years ago that he may have never been subscribed to.
As for the heater bypass loop, I went to the local auto parts place and asked to look through their heater hoses to find a U-shaped hose to connect the heater supply/return hard lines together at the back of the engine. Dayco 87617 turned out to do the trick - it's actually J-shaped, but I just cut the longer leg off to make it a U.
The shadow makes it look like it's kinked, but it's really not.
Old 10-04-2015, 01:45 AM   #19
choi0706
Member#: 126548
mine aren't that close together.
83 GL wagon heater core removal - WTF?! Sickly 'Old School' Subaru Forum 2 04-24-2007 12:41 AM
How to get at the heater core mavrick Service & Maintenance 1 10-28-2006 10:48 AM
would it be feasible/possible to take out the heater core? DoinkMobb Normally Aspirated Powertrain 7 05-30-2002 07:39 PM
Heater core removal mts3 Normally Aspirated Powertrain 7 11-09-2001 04:50 PM
('93-'01) where is the heater core located? smokey Impreza Forum 1 04-29-2001 06:47 PM
