Old 05-09-2013, 10:14 PM   #251
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Originally Posted by Dori Ninja View Post
Ppl were saying u needed the older version for the 06+...
Good for them. I use 1.42.2592 on my 07.
Black94Snake is offline   Reply With Quote
Old 05-09-2013, 10:37 PM   #252
Dori Ninja
Member#: 73974
04 RSTi
Don't gotta be a dick about it...but thanks
Dori Ninja is offline   Reply With Quote
Old 05-09-2013, 10:46 PM   #253
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
so running with my 06 WRX motor i can log...dont get anything from romraider ecu editor though...i dont know what im doing and dont want to try to tune, just looking around...but i would like to set me launch control cause that sounds simple enough...but i cant get my ECUFlash 1.28 i downloaded to work...anyone have a known good file for me to download?? im also not runnign XP but Win 7 32bit...can i use that or no?? see couple ppl having sucess...really i want to be able to re flash on my own so i can get my big power map made and still have my safe map availible cause i cant get 93 everywhere and dont wanna be stuck some where.... :/
Windows 7 is a no go with a vagcom cable for flashing. DO NOT USE A NEWER VERSION OF ECUflash. Use the version recommended for a vag com cable.
Read up on the how to's of a vag com cable before trying to use things that do not work. I tune both my 05 baja and 05 sti with vag com cables and windows xp.
2.5 turbo hyped is online now   Reply With Quote
Old 05-10-2013, 08:36 PM   #254
bnio
Member#: 259531
Windows 7 is a go with flashing. It does does work with ECU flash. I, first hand have used it on an 04 WRX ECU and an 05 STI ECU and this was with ECU Flash 1.29 on Win 7 32 & 64 bit system. Please be more careful with blanket statements so we don't have misinformation confusing people.
bnio is offline   Reply With Quote
Old 05-11-2013, 10:38 AM   #255
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
NOT WITH A VAG COM CABLE!!! Tactrix=yes VAGCOM=no
Get back under the blanket.
Old 05-12-2013, 09:49 AM   #256
killacam661
Member#: 341930
o3 wrx
Psm
so what version of ecuflash do i need to use?i just got my vag com cable in the mail yesterday. im scared to brick my ecu. can someone chime in and set me on the riht track please. ive been doing ninstop researching dor the past few weeks and have a general idea but want to be more sure somi dont brick me ecu.
killacam661 is offline   Reply With Quote
Old 05-12-2013, 07:45 PM   #257
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Why not just buy the tactrix cable? Safe and be done with it.
cosseywrx is offline   Reply With Quote
Old 05-13-2013, 04:56 PM   #258
Dori Ninja
Member#: 73974
04 RSTi
cause its like $240 more than the VAG-COM.....
Old 05-13-2013, 05:12 PM   #259
JonnyV2889
Member#: 197384
2006 WRX Ltd
Not sure where you pulled that quote outta your ass but my tactrix was $160 and they're currently listing for $169...
But yes a vag-com is cheaper...
JonnyV2889 is offline   Reply With Quote
Old 05-13-2013, 07:20 PM   #260
Dori Ninja
Member#: 73974
04 RSTi
Idk I just remember they were more...like 200-250 something like that...been a while since I've looked though...
Old 05-13-2013, 11:23 PM   #261
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
I bought my tactrix 2.0 used on this forum for $ 125 shipped. Most of the time a used cable can be had for $100 to $150 shipped. It seems like it definitely would cut out the frustration that some of you guys can get into trying to make the vag-com work. Time is money.
nmlittlebigman is offline   Reply With Quote
Old 05-14-2013, 10:53 PM   #262
Beauch
Member#: 224241
2004 Impreza wrx
platinum silver
you can definitely do it with a vag-com... windows 7, tactrix drivers, romraider, and ecuflash.
no problems here..... ferrite cores. clean grounds are your friend..
mind you its a 04 wrx, 16 bit
Beauch is offline   Reply With Quote
Old 05-15-2013, 09:16 AM   #263
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Of course you can WITH 16BIT!
Old 05-15-2013, 05:11 PM   #264
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
never had any issues doing it on my 32 bit ECU
Old 05-15-2013, 07:30 PM   #265
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
And windows xp.
Old 05-15-2013, 10:01 PM   #266
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
And windows xp.
how wrong you are bah-rag breath. stop ASSuming and shut the **** up.
I use an XP machine as my primary as it is my 10" netbook and is super portable. However, while trying to hep people figure out their windows 7 problems I was able to read and write to my car with my 64bit windows 7 laptop. I can't anymore though, because I smashed it on my living room floor while arguing with my Mrs.
So do us all a favor. If you arent going to help... please go **** yourself.
Old 05-15-2013, 10:08 PM   #267
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Sorry, never happened.
Old 05-16-2013, 06:18 AM   #268
quazimoto
Member#: 70395
All you have to do is run it in XP capability mode. And uncheck auto assign com ports
quazimoto is offline   Reply With Quote
Old 05-16-2013, 09:41 AM   #269
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
This is EXACTLY what I was saying. It will not run directly in windows 7 because of the drivers.
Old 03-30-2014, 02:55 PM   #270
daslog
Member#: 314410
2004 WRX
Originally Posted by japanesestar View Post
I hope that pic works. I used the pic from another thread. I do not own the photo. This is what I did to fix the low voltage problem.
Not to revive an old thread, but I was able to get this working.
2004 WRX
The cable is 8 dollars.
Amazon.com: DHSHOP USB OBD-II-2 KKL 409.1 OBD2 Cable VAG-COM for VW/AUDI: Car ElectronicsAmazon.com: DHSHOP USB OBD-II-2 KKL 409.1 OBD2 Cable VAG-COM for VW/AUDI: Car Electronics
I used ECU explorer to extract read from the ECU. I modified it slightly with RomRaider, and got the low voltage error. Jumping the pins like above solved that issue.
daslog is offline   Reply With Quote
Old 03-31-2014, 05:49 PM   #271
Mattman57
Member#: 346692
2004 WRX
Same thing as above ^ for me.
Only difference is I soldered a wire directly to the flash block wire, and run the wire directly to my battery. Haven't had an issue since...thus far.
Mattman57 is offline   Reply With Quote
Old 03-26-2015, 02:13 PM   #272
GuitsBoy
Member#: 61721
2006 WRX
Steel Grey Metallic
Sorry to drag this up from the dead, but has anyone found a way to get the WCH chipsets to work with this yet? Seems that none of the newer vag-com cables come with anything buy winchiphead.
GuitsBoy is offline   Reply With Quote
Old 05-08-2015, 02:59 AM   #273
D.Johnson
Member#: 209439
2002 Bugeye WRX
Flat Black
Anyone have one of these cables that already have the mad mod they are wanting to sell?
Preferably with the ft232bl chipset
D.Johnson is offline   Reply With Quote
Old 02-10-2016, 08:06 PM   #274
Ninja007
Member#: 150637
02 WRX Wagon
96 Impreza, 06 STI
Since the above item in the link is no longer available, I just purchased the cable in the link below. I am trying to diagnose DCCD Issues in a 2000 2.5RS with full 2006 STI swap including the harness. The DCCD diagnostic is notorious for throwing bad codes, so I am hoping this will let me log data using FreeSSM to view DCCD sensor inputs. I have heard there are various driver problems and system incompatibilities with this cable. Can anyone verify plug and play, or did they have to download FTDI Drivers? Anyone used this with freeSSM? I am on Windows 7, so I am definately going to try the compatibility mode and manual assignment of Ports and check back in a couple days.
Amazon.com: AUTOS-FAMILY VAG409.1 vag 409 kkl VAG KKL 409.1 Auto Scanner Scan Tool for Audi Volkswagen: AutomotiveAmazon.com: AUTOS-FAMILY VAG409.1 vag 409 kkl VAG KKL 409.1 Auto Scanner Scan Tool for Audi Volkswagen: Automotive
Late edit: Cable gets here tomorrow, but since purchasing it looks like that connector most likely uses a fake FTDI chipset. I will try it out, but if it doesn't work, I will probably purchase a cable with a real FTDI chipset to avoid having to do all kinds of work arounds.... a cable like this:
Amazon.com: USB Cable for Triumph Motorcycle TuneECU Program: AutomotiveAmazon.com: USB Cable for Triumph Motorcycle TuneECU Program: Automotive
Ninja007 is offline   Reply With Quote
Old 02-12-2016, 11:14 PM   #275
Ninja007
Member#: 150637
02 WRX Wagon
96 Impreza, 06 STI
Got my cable today and connected it to my Windows 7 PC. Windows tried to automatically try to install drivers and failed. I found a Youtube video of a Arduino guy that provided a link to CH340 drivers(the CH340 is the chipset that this cable uses since it is a cheapo knockoff of a real FTDI chip). See pic of that here:
Then I made sure that my COM port was set to something that FreeSSM would recognise - Com1. Pic of that here:
After these two steps, success, it connects to FreeSSM!
Next step is to plug it into the car and try it out, but i'm out of time tonight
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 148 06-24-2015 08:36 PM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 08:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 04:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 12:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 07:10 PM
