Old 09-20-2010, 07:52 PM   #76
Drunkinchef
Member#: 145324
1991 MR2 T-Bar Turbo
Red
Originally Posted by choleaoum View Post
Any news for the bug eyes? Can anyone confirm if it's working and how?
I'm still having no luck. I'm going to try to use a laptop with windows xp.
Drunkinchef is offline   Reply With Quote
Old 11-24-2010, 02:54 AM   #77
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I purchased 4 VAG COMS from AlphaBid on ebay.....good presents for subie friends.
So far I pulled a LV and was able to log my 2006 STi no problems......
Cable is excellent quality and fits nice and snug into the OBD2 port. Has a way better feel than the Tactrix 2.0 cable.
Old 11-27-2010, 05:15 PM   #78
urban_s
Member#: 265238
So I'm just trying to make sure I undersand this right. So I can use a normal vag-com cable and a flash block to use romraider on my '04 sti? I don't need anything like tantrix openport? I just got the sti and I already have the vag-com cable from my wifes jetta(evil car)
urban_s is offline   Reply With Quote
Old 11-27-2010, 05:31 PM   #79
Phatron
Member#: 36033
CEO PhatBottiTuning
re-read the first post.....
cable
connect the green connectors (you dont have the separate flash white/blue connectors like the wrx)
old version of romraider or ecuexplorer
Old 11-27-2010, 08:36 PM   #80
MykuL
Member#: 122451
01 RSTI w/07 EJ257
6MT Brembos BBSs Interior
Has anyone ever gotten any generic Tactrix cable to connect to their '02/'03 WRX ECU using Ecuflash? Sadly, I'm starting to think it just isn't possible.
I've tried
  • Different drivers
  • Different ports
  • Different laptops
  • Different versions of Ecuflash
  • Turning the car on at every time interval imaginable
  • Different combinations of the test mode connectors and the flash block connector
It's extremely misleading when these cables are advertised to FLASH a bugeye ECU when it in fact CANNOT
RomRaider works great, Ecuflash does not.
EDIT:
Just received an e-mail from Cody with Busted Finger Motorsports (the vendor I purchased mine from).
He confirms he has tested this cable (VAG COM basically) with a bugeye, but that it's ALL about timing.
MykuL is offline   Reply With Quote
Old 12-14-2010, 05:03 AM   #81
piranha786
Member#: 144744
2007 Impreza 2.0R
Default SSCVFG-A10 ELM 327 Car Diagnostics USB to VAG-COM
Hi have any1 got this cable to work? or should it work.
I just need to read the fault codes, no flashing
SSCVFG-A10 ELM 327 Car Diagnostics USB to VAG-COM Fault Code Cable
I have a 2007 Impreza 2.0R
I can get it at a "local" online retailer
here
http://www.stopshop.co.za/1359-buy-e...cvfg-a10-.html
piranha786 is offline   Reply With Quote
Old 12-14-2010, 02:13 PM   #82
Phatron
Member#: 36033
CEO PhatBottiTuning
I've tried
  • Different drivers
  • Different ports
  • Different laptops
EDIT:
did you try this......from the first post in this thread?
Ecuexplorer available here: (I had to use this)
http://code.google.com/p/ecuexplorer/downloads/list
Old 12-22-2010, 08:57 AM   #83
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
I have a 2011 WRX, and all I want to do is log (not reflash).
Would I only need a Vag-Com cable from eBay, and the RomRaider software?
xluben is offline   Reply With Quote
Old 12-22-2010, 09:22 AM   #84
Bill in Mtl
Member#: 188357
2016 WRX 6MT
I have a 2007 WRX, and am basically doing what you posted below. Although, I am flashing as well.
the biggest hurdle is the drivers, the easiest way for me was to manually set them - not allowing RomRaider to automatically install the drivers.
Old vag-com cable bought on ebay used during my vw passat days....works like a charm
Good luck
Regards,
Bill in Mtl is online now   Reply With Quote
Old 12-24-2010, 11:02 PM   #85
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Well, I got the Vag Com cable from my brother's Audi days. It's just the $10 thing you get on eBay. I manually installed the drivers and set up Rom Raider Logger for my laptop. Once I had all that done, I didn't have an problem getting it to communicate with my car.
I logged for maybe 15 min and then it stopped communicating with my computer. I unplugged the USB from my computer and then reconnected it, and everything was fine again. I did a couple 3rd gear pulls and threw them in Virtual Dyno. Stage 2 line is from today. The other two runs are from my Stage 1 tune with my tuner (using a Tactrix cable).
Great for someone who only wants to log, and not tune. Very cheap and works well!
Old 01-05-2011, 08:41 PM   #86
trepetti
Member#: 138418
This is EXACTLY what I want to do with my 09 LGT. I have a Vag-Com rev 2.10 cable and I want to log to RomRaider. I see reference to drivers. What drivers do I need and where can I get them?
Thanks
trepetti is offline   Reply With Quote
Old 01-05-2011, 08:51 PM   #87
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Thanks
Here is a link to the "guide" I wrote up:
http://forums.nasioc.com/forums/show....php?t=2108996
Feel free to post in that thread. I'd love to get it referenced in this thread or at least keep it from disappearing due to a week of no posts.
Old 01-05-2011, 09:15 PM   #88
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Still waiting for VagCom and MegaSquirt to merge into one company for maximum laughs.
XanRules is offline   Reply With Quote
Old 01-05-2011, 11:47 PM   #89
trepetti
Member#: 138418
Originally Posted by cooleys04 View Post
Iirc, your car is dbw, which would make a difference. It was a serious PITA trying to get ecuflash to read my cable. You got lucky, from what I've read, it can be easy or a nightmare just depending on your car/cable/computer etc. I got my cable from alpha-bid and recieved it on the 3rd day, I would recommend them.
I have an 09 LegacyGT which is DBW/CAN bus and I want to buy a Vag-Com cable just to do logging. I know it will not work for flashing, but it looks like there are numerous success stories using it for logging.
I am looking at cables from ebay from Alpha-bid (mentioned a few times in the post) and he has $18.00 cables and $63.00 CAN Bus cables. So my question is: Do I need a CAN Bus cable just to do logging?
If anyone has purchased a cable, I would appreciate your input.
Thanks
Old 01-05-2011, 11:52 PM   #90
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Mine is the non CAN BUS type. Shouldn't matter for logging only. It was $10 shipped. Not sure where he got it from though.
Old 01-06-2011, 05:48 PM   #91
trepetti
Member#: 138418
Just gave it a whirl and could not connect to the ECU with either RomRaider or LearningView. I only have com3 listed as a connect option. When I installed the cable Win7x64 found a driver for the Ross-Tek cable. I didn't need to install the FTDI drivers.....wondering if that is the problem.
I am thinking about rebuilding the laptop with 32 bit XP and trying the FTDI drivers.
Old 01-06-2011, 06:04 PM   #92
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Responded here:
Old 01-22-2011, 10:46 PM   #93
doored454
Member#: 240550
04 WRX
Does anyone know how well the actual ross-tech vag-com cable works compared to the cheap ones? I have a brand new hex-can+bus cable and just bought it along with vag-com last month to do some scanning on my gti and my dads jetta, along with doing some coding for a bunch of friends' mk5's. I was all set on getting a UTEC and was told about opensource tuning and found this which is awesome.
doored454 is offline   Reply With Quote
Old 01-23-2011, 09:03 PM   #94
no1v2
Member#: 263771
I've tried
  • Different drivers
  • Different ports
  • Different laptops
EDIT:
I know your post is old now, but in case you're still looking for data points...
I had a 2005 LGT and an eBay VAG-COM KKL cable that worked perfectly for logging (RomRaider & Learning View), reading the ECU image (latest at the time version of EcuFlash), and writing the ECU image (EcuFlash).
I tried logging (RomRaider & Learning View) on two different 2002 WRX's, and that same cable worked just fine. But I could not get ECU reading or reflashing to work on those WRX's.
I too tried tons of driver/EcuFlash version combinations, including a very old school EcuFlash version that let you pick a COM port. I tried multiple laptops (always Windows XP 32-bit). I even tried ecuExplorer. No go.
A little while later an OpenPort 2.0 read the ECU image off one of those WRX's on the first try.
In short, if you want to reflash a 16-bit Subaru ECU, you need a real OpenPort cable/adapter. Why, I do not know
no1v2 is offline   Reply With Quote
Old 01-24-2011, 08:38 AM   #95
MykuL
Member#: 122451
01 RSTI w/07 EJ257
Thanks for the info! I did end up getting a Tactrix 1.3, works every time
Old 02-08-2011, 01:19 PM   #96
MattPersman
Member#: 139385
I am using a 9 dollar and some change shipped to me from china cable off ebay and was able do learning view, and flash using an older version of ECUFLASH. this thing looks the same as the cable that busted finger is selling. I am sure i will be told its completely customized and not a 10 dollar cable
MattPersman is offline   Reply With Quote
Old 02-10-2011, 03:01 PM   #97
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I don't think people with 32-bit ecu's are having as much trouble as people with the 16-bit ecu's (02-05wrx)
Subian is offline   Reply With Quote
Old 02-14-2011, 08:08 PM   #98
cooleys04
Member#: 145027
2004 WRX FP Green
MFactory/2Tone/built 205
I added your thread to the 1st post.
cooleys04 is offline   Reply With Quote
Old 02-19-2011, 09:29 PM   #99
subie3429
Member#: 216668
00 Legacy
04 Yamaha r6
I just bought the vagcom cable, learning view worked, download the newest version of ecuflash along with the drivers that ecuflash came with, and i was able to pull the map off.
I cannot get a full log from romraider though, It cuts out halfway everytime.
I have even had this issue with a tactrix 2.0 cable.
Anyone else have this issue?
subie3429 is offline   Reply With Quote
Old 02-22-2011, 11:45 PM   #100
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
For you guys trying to get the Vag to work with 02/03 and maybe 04/05, I posted this in the BFM cable thread:
http://forums.nasioc.com/forums/show...3#post33377543
robtmc is offline   Reply With Quote
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 148 06-24-2015 09:36 PM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 09:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 05:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 01:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 08:10 PM
