Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 04-15-2011, 11:16 AM   #126
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
TH motorsports is offline   Reply With Quote
Old 04-20-2011, 02:50 PM   #127
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Old 04-26-2011, 01:34 PM   #128
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Old 04-29-2011, 04:24 PM   #129
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Official Circuit Battles Viewing Party - Saturday April, 30 2011
Moes Cantina - Wrigleyville - 12pm-4pm
**All Ages**
$5 4-Rebels Vodka Drinks
Hosted by Moes Cantina and your favorite THMotorsports staff!
THMotorsports is celebrating the official airing of the first circuit battles episode on the VERSUS network and we want to watch it with YOU! Over the past few months we have been traveling all over the west coast, taking on some of the biggest names in racing. This landmark event is being televised by the VERSUS network, and will prove to be some of the most intense motorsports action on television!
Come hang out with staff and drivers from 12-4PM @ Moes Cantina - 3518 North Clark St. in Chicago. There will be food and drinks as well socializing. If would mean the world to our staff if you would come join us!
See you all SATURDAY
Old 05-09-2011, 01:52 PM   #130
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Old 05-23-2011, 11:49 AM   #131
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Old 05-26-2011, 01:31 PM   #132
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Checkout our Facebook for updates on our race car!
THMRacing STi Facebook
Old 06-10-2011, 03:42 PM   #133
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
I had a few PMs asking about our hood...figure I post up what we did.
Well we adapted a 2011 Shelby gt 500 hood vent into our Seibon hood. worked out very well....very cheap...nice air flow.
Old 06-10-2011, 04:06 PM   #134
Crazy650
Member#: 109498
05 Wrx turned STI
were can you buy them hood pins?
Crazy650 is offline   Reply With Quote
Old 06-10-2011, 05:31 PM   #135
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
look up aero catch pins. They are a bit of work to make em happen, but they are very nice indeed.
LMK I can get em for you
-Adam
Old 06-20-2011, 08:17 PM   #136
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Some updates:
Engine is being torn apart and rebuilt. We blew the head gaskets again...
Old 07-01-2011, 12:46 PM   #137
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Back on Mr. Church's Dyno making more power earlier, and with less boost. Should be an awesome weekend @ RTA Round 4 Willow Springs.
more updates on FB
http://www.facebook.com/pages/THMRacing/317648202327
Old 07-02-2011, 03:44 PM   #138
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Redline time attack Roun 4 from Willow Springs CA.
Cheer on the THMotorsports racing team!
Streaming Live:
http://www.livestream.com/redlinetrackevents
and or THMracing FB
Old 07-07-2011, 01:39 PM   #139
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
We had a good deal of new issues at Willow Springs. Most were overcomed with hard work and dedication. Racing and development is a fun battle!!!
Issue 1. Low than zero oil pressure. Oil pump went down due to bad machining/shimming than damaged the piston inside.
Issue 2. no fuel pressure. One of the walbros in the tank died. We replaced it.
Issue 3. Knocking, hesitation. It was 105-110 degrees outside and track temps @ 165 degrees. Decreased the timing a tad and changed the spark plugs we were good to go.
Issue 4. Electrical failure. Car died while we had 6 car lengths over the K&N G35.
STi is in Nebraska right now. Cruising back to Chicago and prepping it up for all the local events, including but not limited to the GTA @ Autobahn later this year.
More updates soon.
[email protected]
Old 07-07-2011, 05:17 PM   #140
apsdsmracer
Member#: 139131
2003 WRX Wagon
Nice car!!
What kind of transmission are you guys running?
apsdsmracer is offline   Reply With Quote
Old 07-07-2011, 07:06 PM   #141
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Originally Posted by apsdsmracer View Post
Nice car!!
Thank you
We are running the stock 04 STi tranny.
Old 07-07-2011, 07:54 PM   #142
jockeygolfs
Member#: 260868
2011 STI
Stroker Kit and pistons running strong? Or is the motor being torn down after each event?
jockeygolfs is offline   Reply With Quote
Old 07-08-2011, 10:28 AM   #143
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
Pistons, rods, stroker kit are all good. Very strong stuff.
We did tare apart the motor due to head gaskets twice, but never needed to tare down the bottom end. Compression and leakdown tests were done after every track day and stayed solid.
However this time around because of the oil pump being killed do to improper machining, we will rebuild since we had some shavings.
Old 07-08-2011, 10:48 AM   #144
jockeygolfs
Member#: 260868
2011 STI
To install the stroker kit is there machining required beyond boring for sleeves?
Old 07-12-2011, 11:04 AM   #145
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
BC stroker kits are balanced and blueprinted...as long as you or machine shop knows what you are doing just bolt it right in.
Old 08-20-2011, 08:11 AM   #146
subaruperformance
Member#: 274765
What head gaskets did you use those two times and what using now?
subaruperformance is offline   Reply With Quote
Old 08-21-2011, 06:15 PM   #147
gr8
Member#: 163375
mls Cometic every time since we need a custom size only they can make quickly. It seems that we might have had a dropped sleeve for some time that went unchecked, so I can't blame the gasket for going do to them being poorly made. Last time around they held up completely fine with higher torque and stronger studs with more power than we ever made before.
gr8 is offline   Reply With Quote
Old 11-06-2011, 11:37 AM   #148
EE06STI
Member#: 124580
This looks like a fun project.
How much does this car weight?
What kind of oil pump are you running that you had to have machine work done?
EE06STI is offline   Reply With Quote
Old 11-07-2011, 01:48 PM   #149
TH motorsports
Member#: 145643
95 Impreza L-ish
Blueish Green
I believe we are at about 2900 lbs wet w/o the driver...
08 STi pump, shimmed.
Old 04-03-2012, 08:19 AM   #150
EE06STI
Member#: 124580
Any updates for 2012?
FS : (LA) 2006 Subaru WRX STi Aspen White PRICE DROP $19000 obo More Pics page 3 Dustin77 Private Vehicle 'For Sale' Classifieds 68 06-16-2010 02:43 PM
Zero/sports 06 STi - Time Attack Car - For Sale! EAT Motorsports Vehicle Sales 10 04-23-2010 11:32 PM
Any updates on COBB's full carbon body Time Attack car? WRblueX_Guy Motorsports 31 07-07-2009 04:05 PM
SoCal: FS: 2004 WRX STi gauge cluster, in great condition, with shift light & buzzer jcu1276 Private 'For Sale' Classifieds 27 05-05-2006 05:54 PM
