Old 01-13-2010, 05:39 PM   #1
SoobZero
Member#: 157226
02 Zukati
Default What's up with this Alignment? Fix needed?
I recently purchased new tires and noticed two weeks ago during a brake pad change that the inside shoulders of the rear tires are wearing heavily.
I'm running RCE yellows and the accompanying bumpstops, and I also added rear Whiteline endlinks after I bent the originals due to a flipped sway.
I waited a couple of weeks after the spring install for them to settle, and got the initial alignment done back in April '09. That alignment generated -1.3 LR and -1.7 RR. Took it to get an alignment today and the rears are showing the below:
What do I need to do here? Rear camber bolts? Does this look normal? I really don't want to have to buy 4 new tires after only a few months.
And...
What would make the rears like that? I have not been in any accidents. Granted I have bumped a pole only very slightly with my rear bumper, but that doesn't explain an extra degree of camber.
SoobZero is offline   Reply With Quote
Old 01-13-2010, 05:42 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
The camber wouldn't be a problem if the toe was fine, but that's more camber in the rear than you probably want to run.
chazly413 is offline   Reply With Quote
Old 01-13-2010, 06:23 PM   #3
Web Foot STi
Member#: 39086
2004 STi
Rear and front toe should be 0. What you have now is OK. It's that initial -1.09 deg that was burning out the edges.
The camber gain is due to the lowering springs. Rear camber bolts should solvve that little problem and let you balance it better.
Web Foot STi is offline   Reply With Quote
Old 11-08-2014, 10:22 PM   #4
Scoobycharlieuk
Member#: 405866
1997 Subaru impreza
Green
Web foot sti is right
Scoobycharlieuk is offline   Reply With Quote
Old 11-08-2014, 11:40 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
somebody who spent a few minutes could even out that rear camber without doing anything but loosening the bolts and pushing a lil bit
Old 11-09-2014, 12:52 AM   #6
Bikelok
Member#: 254851
2002 WRX wagon 5mt
4 year old post.
I think the OP figured it out by now.
Sent from the twilight zone.
Bikelok is offline   Reply With Quote
What's up with this guy? silvercharged Off-Topic 22 11-08-2014 10:25 PM
what's up with this "carbon fiber" non-sense? extraducksauce Interior & Exterior Modification 40 10-23-2002 04:08 AM
KYB/AGX Warranty? What's up with this? hayscoob Brakes, Steering & Suspension 8 06-23-2001 09:39 PM
huh?!? what's up with this weather? efoo New England Impreza Club Forum -- NESIC 11 03-17-2000 01:20 PM
