Old 01-13-2010, 08:51 PM   #1
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Default STI Coils on Phase I Heads
Does anyone know if STI coil over plug coils will fit Phase I DOHC cylinder heads? I simply couldn't tell if the boot was engauging the plug or not. It is awful close. I have heard that the STI and WRX COP coils might differ slightly in length but I am looking for confirmation one way or another.
STI coils have built in ignitors correct?
Thanks guys
hustleshark206 is offline   Reply With Quote
Old 01-13-2010, 09:32 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Which STI? Which phase 1 heads?
Old 01-13-2010, 10:46 PM   #3
dr3w
Member#: 222318
1993 RHD GC8
Post this is the stickyed coil conversion thread in the pre 2002 section of forum.
But if i remember right yes you can.
dr3w is offline   Reply With Quote
Old 01-13-2010, 10:51 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
So I could take the coils from a 98 STI and put them on some Legacy Turbo heads?
Old 01-13-2010, 10:57 PM   #5
sense of nature
Member#: 112759
02 Srp STi...Yup!
R ur Boltz to long????
Good luck getting them to fire correctly tho
sense of nature is offline   Reply With Quote
Old 01-14-2010, 01:11 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
Igniter bypass mod
Old 01-14-2010, 01:44 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
wouldnt a 98 STI be a EJ20K with a single coil pack?
if he is talking about a USDM trubo legacy this may work. but not sure. but deff. not the same as the coil mod for the phase I DOHC and USDM STI coil packs...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 01-14-2010, 02:44 AM   #8
hustleshark206
Member#: 182227
2000 MPS Built RS
Thanks guys. I am talking about USDM STI coils from a 2005. The cylinder Heads are DOHC from a 98 2.5RS. I am going stand alone with a haltech platinum sport 1000. Haltech told me I could wire them straight to the ECU no problems but then again they are Aussy.
Old 01-14-2010, 03:00 AM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
I actually knew you meant EJ257 style heads and EJ25D heads but decided to take a big dump on your thread for being unclear
EJ25D heads are actually the same as EJ20G heads. It would probably helped you more if you searched about EJ20G heads with EJ257 coils.
edit: Ok I am feeling generous - this thread may help you http://forums.nasioc.com/forums/show....php?t=1192028
Old 01-14-2010, 03:07 AM   #10
hustleshark206
Member#: 182227
2000 MPS Built RS
Ok I will try searching for that. Or you could just tell me since I don't know **** and you are the man.
Old 01-14-2010, 12:16 PM   #11
hustleshark206
Member#: 182227
2000 MPS Built RS
HAHA thanks Ciper.
Old 01-14-2010, 03:04 PM   #12
hustleshark206
Member#: 182227
2000 MPS Built RS
One more quick question. Ciper told me EJ25D and EJ20G heads are the same thing. Is there any difference in the spark plugs used? I am sure the gap will be different one being N/A and one turbo but is the plug itself different?
Old 01-14-2010, 03:09 PM   #13
DSM_Outback
Member#: 56345
93 Swapped L
Green
Heat range will be different. EJ25D=BKR5ES EJ20G=BKR6ES (factory)
DSM_Outback is offline   Reply With Quote
Old 01-14-2010, 03:48 PM   #14
hustleshark206
Member#: 182227
2000 MPS Built RS
Perfect. Thanks guys!
Old 01-14-2010, 04:27 PM   #15
dr3w
Member#: 222318
1993 RHD GC8
Factory oem for ej20g is actually pfr6g's but brk6e's also work.
Old 01-14-2010, 08:13 PM   #16
hustleshark206
Member#: 182227
2000 MPS Built RS
After reading about cylinder heads all day it seems that the EJ20G heads are the same as MY96 EJ25D heads. MY98 EJ25D heads are more like EJ20K or EJ20H. All these numbers are getting confusing LOL! All I want to know is will the STI coils engauge the spark plug in MY98 EJ25 DOHC heads. Everything I have read suggests they will but when I test fitted them I couln't tell. Could the EJ20 spark plug be physically longer I wonder?
Fuji Where you at bro?
Old 01-14-2010, 08:36 PM   #17
jamal
Member#: 71875
98 2.5GT
my wheels fit
wrx coil packs should fit but the sti ones are a different length. You can pull the ends off and swap them though.
jamal is offline   Reply With Quote
Old 01-14-2010, 11:29 PM   #18
DSM_Outback
Member#: 56345
93 Swapped L
Green
Platinum sucks.
Old 01-15-2010, 12:42 AM   #19
suberdave
Member#: 101865
88 GL-10 STi
i have heard this many times. however i have been using STI coil packs on my EJ20G for 12K and they seem to work just fine...
does someone have a pic of an STI coilpack next to a WRX coilpack?
-=Suberdave=-
Old 01-15-2010, 11:27 AM   #20
hustleshark206
Member#: 182227
2000 MPS Built RS
^ yeah this would really help. I have read that they are different lengths but then everyone says they are interchangable. I don't get it.....
Old 01-15-2010, 08:07 PM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
I've seen my02 WRX coils next to my05 STI coils and they looked the same to me other than the colors. I didn't specifically measure them though.
This thread originally peaked my interest because I plan to use coil on plugs with my DOHC NA engine which has the EJ25D heads.
Old 01-16-2010, 04:05 PM   #22
hustleshark206
Member#: 182227
2000 MPS Built RS
Bmxpunk confirmed that they will work because he is currently using EJ22t block MY98 DOHC heads and STI coils. I am trying to find out what plugs he is using.
Old 01-17-2010, 01:26 AM   #23
bmxpunk
Member#: 89599
1995 almost 22B:)
red
NGK Bkr6es (vf37turbo, 14psi, 8.5:1CR) I will switch to 7's someday when I make more power
bmxpunk is offline   Reply With Quote
Old 01-18-2010, 03:41 PM   #24
hustleshark206
Member#: 182227
2000 MPS Built RS
Thanks BMX! I will try those plugs and see if that helps
Old 01-28-2010, 12:45 AM   #25
jamal
Member#: 71875
98 2.5GT
my wheels fit
-=Suberdave=-
been awhile but I grabbed two coilpacks the other day and took a picture:
sti coilpack is the short one.
Has anyone done STI cams on a wrx heads w/ before/after verc Factory 2.0L Turbo Powertrain 9 02-19-2009 07:35 PM
Ignition Coils - WRX / Sti coil on plug type - $30 each all four available Fongers Engine/Power/Exhaust 1 04-03-2008 08:47 PM
Igntion Colis - WRX / Sti coil on plug type | Full Set Available Fongers Engine/Power/Exhaust 0 03-27-2008 03:20 PM
sti cams on 2.0 heads wrx2k4 Built Motor Discussion 28 02-10-2008 08:17 PM
05 STI coils on a 97 Bri???? dome24 Brakes, Steering & Suspension 4 06-17-2006 01:15 AM
Message Board Statistics All times are GMT -4. The time now is 09:11 AM.
