Old 05-23-2002, 07:39 AM   #1
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
Default VF23 Boost issues...
I (well, Dubyarx and Scoob) just installed a VF23 last weekend...my mods are TurboXS turboback exhaust, godspeed uppipe, Samco IC hoses, TCG Motorsports intake, and a Blitz SBC-id controlling boost. Stock fuel system and stock injectors.
Everything was running fine (running 15psi) (a bit rich, but fine)...until last night. I did a WOT 3rd gear pulll up to redline. Then afterwards the boost came on very slowly and would hit over 7psi. I pulled over, shut the car off....restarted and was back on my way...no boost issues.
This morning the car started exhibiting the same behavior, but this time the boost would creep up to about 13psi (very slowly)...any ideas?
lbk16 is offline   Reply With Quote
Old 05-23-2002, 08:43 AM   #2
FuZZyLoGiC
Member#: 5970
2004 \/\/|2>< STi
Bp]V[ 97 |_||\|1<|-|1p2.0
Check your hoes connections, my just be that simple..
FuZZyLoGiC is offline   Reply With Quote
Old 05-23-2002, 08:51 AM   #3
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
That's my first step. I didn't check last night b/c it was running fine. I might run out a lunch to check things out.
Anybody else want to chime in?
Old 05-23-2002, 09:42 AM   #4
TurboRex
Member#: 8635
04 STI, 07 FXT
I agree. There is something wrong with your hoses.
Greg
TurboRex is offline   Reply With Quote
Old 05-23-2002, 09:45 AM   #5
Godspeed
Member#: 7860
2002 WRX Wagon
Sounds like a selenoid hose problem.
Godspeed is offline   Reply With Quote
Old 05-23-2002, 10:08 AM   #6
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
Looks like I'm goin out to the car to check some hoses.
Old 05-23-2002, 01:58 PM   #7
lbk16
Member#: 4195
2007 WRX Ltd. Wagon
2005 350Z
Well, I checked and it looks like the hose to the wastegate actuator was loose...I need to put a hose clamp on it, as the stock pressure clamp is on there loosely.
idle issues and boost issues jdgrimm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-05-2006 09:45 PM
Boost issues or Gauge Issues? IwantONE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-12-2006 05:18 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 12:22 AM
Weird boost issue... Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-05-2002 10:16 PM
Boost issues with the AVCR... Need help. AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-02-2002 03:58 PM
