Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-15-2010, 07:17 PM   #1
WRX SEX
Member#: 212171
08 SSM WRX
MSPT Tuned: 254whp/343wtq
Default MSPT Tuned: 2008 WRX (93 Oct, Stock Turbo) - 254 whp / 343 wtq [Dyno Dynamics]
Ambient Temp: ~40F
Elevation: ---
Car: 2008 Impreza WRX
Tuner: Dave Brown
Dyno Info: Dyno Dynamics
Peak HP at RPM: 254 whp @ 4600 rpm (1.12 CF)
Baseline HP for a stock car: ---
Target Boost: 18 psi tapering to ~11 psi
Target AFR: ---
Fuel: 93 Octance
Engine Modifications
Invidia N1 Race
ERZ Catted Downpipe
AVO Short Ram Intake
Grimmspeed EBCS
The car made more power than I was expecting and made good torque. It pulls very strong all the way until about redline although not really much point to take it there. I spiked to 21.5 psi a couple of times on the way home but im not worried about it. Still on the stock snail (TD04), I will be back soon with new BPV, FMIC, turbo inlet, and NGK 1 step colder plugs to see what it makes. Ultimate plan for this car is 330-350whp VF52 DD. Thanks for looking and feel free to comment on what you think.
Big shout out to Dave Brown and the guys at Metric Subaru for the results
Pics and video up shortly...
WRX SEX is offline   Reply With Quote
Old 01-15-2010, 07:25 PM   #2
gc8v6
Member#: 173164
1999 2.5rs 2dr
rally blue
NICE!! JUST GOT MINE PROTUNED TODAY ALSO! got 333tq/235whp on 15psi! wish he would've pushed it to 16 lol but I'm happy with the results! I really want to get a bigger top mount on my 08wrx to run more boost! hows the grimmspeed EBCS? How much did it cost you? I just want to settle around 350tq/250whp.
gc8v6 is offline   Reply With Quote
Old 01-15-2010, 07:30 PM   #3
WRX SEX
Member#: 212171
08 SSM WRX
congrats on your numbers! why only 15 psi? The Grimmspeed EBCS is like $113 and I think is definitely worth it.
Old 01-15-2010, 07:39 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Don't get too hung up on boost levels of a TD04. Peak boost will affect your torque at the lower midrange of RPMs, but by the time you get to 4k or so, the turbo is just not able to give anything more and is losing boost, rolling off naturally.
On a turbo setup like this, an MBC is really all the boost control you need. You're not 'controlling' boost so much as just setting the peak. You're peaking it and it's almost immediately starting to rolloff due to running out of breath.
Concillian is offline   Reply With Quote
Old 01-15-2010, 08:10 PM   #5
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
its a tranny killer!!! haha good numbers!
subaruNV is offline   Reply With Quote
Old 01-15-2010, 09:50 PM   #6
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
nice #'s, dave is good peoples! im sure some1 will ask, the cf of the DD is 1.12. btw i dont think colder plugs will do anything for your setup...
wrxtremeWGN is offline   Reply With Quote
Old 01-15-2010, 10:20 PM   #7
WRX SEX
Member#: 212171
08 SSM WRX
Why do you say that?
Old 01-16-2010, 02:49 AM   #8
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
because usually they are recommended for larger turbo upgrades if @ all. theyre are plenty of guys w/ 400+ hp setups and stock heat range plugs. there are also guys on here w/ basic stg2 setups like yourself w/ one step colder.. BUT the td04 and or vfXX turbos really wont benefit from it. id talk to dave and see what he recommends in the end though..
Originally Posted by Nasioc's Spark Plug FAQ
Do I need a colder spark plugs? A rule of thumb is one heat range colder for every 75100hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70C to 100C from the combustion chamber. The heat range numbers used by spark plug manufacturers are not universal, so a 10 heat range in Champion is not the same as a 10 heat range in NGK or in Autolite. When making the decision to change the heat range of your plugs, it is a wise idea to make changes in 1 heat range increments, checking all your plugs for suitability during your test. Vehicle modifications during the test phase of your plugs is not recommended as this may skew your results.
So really...do I need colder spark plugs? Probably not as in the end it won't make enough difference to be felt. But if you want the bling of saying you have iridium one step colder plugs and you enjoy the work, knock yourself out.
Do I need to consult with my tuner about spark plugs? Yes. Items in your car that can be tuner specific: manual boost controllers, electronic boost controllers, upgraded wastegates, restrictor pills, wastegate helper springs, external wastegates (type/size/brand), spark plug types/brands/gaps, and injector types/brands/sizes. ALWAYS take your tuner's advice on these matters no matter what the internet tells you!
Old 01-16-2010, 01:52 PM   #9
gc8v6
Member#: 173164
1999 2.5rs 2dr
rally blue
i was told that the intercooler can't take anymore boost safely...
Old 01-16-2010, 03:05 PM   #10
khyree05
Member#: 220877
03 20g hybrid wrx
I like that color
Ambient Temp: ~40F
Elevation: ---
Tuner: Dave Brown
Target AFR: ---
Fuel: 93 Octance
Invidia N1 Race
ERZ Catted Downpipe
Grimmspeed EBCS
I don't know about pulling strong to redline?
Since your whp starts falling off at 5300-5600rpms.
Sorry to say it.
Just being honest.
khyree05 is offline   Reply With Quote
Old 01-16-2010, 06:43 PM   #11
WRX SEX
Member#: 212171
08 SSM WRX
Sorry to say it.
Just being honest.
I know thats what the graph shows, i should have said "it pulls much stronger to' redline than before"
Old 05-19-2010, 02:03 AM   #12
STI SE
Member#: 245077
2010 STI SE
Nice numbers.. going to need some more upgrades soon to keep up
STI SE is offline   Reply With Quote
Old 05-19-2010, 01:30 PM   #13
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
man and I thought my numbers were good for being on the stock snail. but we also used two diffrent dynos so my numbers on that dyno could be close to yours. all I know is that my car is a monster compaired to the day I drove it home. just with intake and exhaust. 236/316. cant wait to get home from this deployment and toss in my LGT turbo and see what we can do.
Black07STiGuy is offline   Reply With Quote
Old 05-19-2010, 11:25 PM   #14
WRX SEX
Member#: 212171
08 SSM WRX
its a dyno dynamics plus with the cf theres no doubt its a lil high reading but damn its so much faster than when i picked it up from the dealer... i honestly dont know what i want to do turbo wise, its between vf52, 18g-xt, 68hta, or even a 19t upgrade...
Old 05-19-2010, 11:39 PM   #15
IIdiceII
Member#: 90438
the dynos not super high reading. I saw a couple fp green setups (350-370whp) and an hta green at 400. the high reading dynos you see are the 360whp vf39's
IIdiceII is offline   Reply With Quote
Old 05-20-2010, 11:20 AM   #16
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Yea, I would say that dyno is right in the middle. Not a super low reading dyno but def not on the higher side either...
Nice numbers BTW...
Cards2323 is offline   Reply With Quote
Old 05-20-2010, 02:56 PM   #17
WRX SEX
Member#: 212171
08 SSM WRX
Nice numbers BTW...
thanks, im really enjoying it
Old 05-22-2010, 12:44 PM   #18
mtarr07
Member#: 246990
2010 Wrx
pick up a used vf52 and have some real fun! good numbers tho.
mtarr07 is offline   Reply With Quote
Old 05-26-2010, 01:01 AM   #19
STI SE
Member#: 245077
2010 STI SE
yea and a larger intercooler
Siegal Tuned: 05 STi, VF39 on E85 - 293 HP, 386 TQ on Dyno Dynamics! NaiveRapture Proven Power Bragging 14 05-23-2010 12:28 PM
09 WRX stock turbo 312 whp, 352 wtq Innovative Tuning Proven Power Bragging 5 05-20-2010 08:43 PM
09 WRX stock turbo 293 whp, 304 wtq Innovative Tuning Proven Power Bragging 20 03-14-2010 09:43 PM
2006 wrx 22k miles WR BLUE 427 whp 426 wtq ryanviola Private Vehicle 'For Sale' Classifieds 5 09-21-2009 01:04 AM
STOCK TURBO 312 WHP 375 on dyno jet SeanCuttaz Proven Power Bragging 70 09-11-2006 11:38 AM
