Old 01-15-2010, 11:30 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default 3 bad wheel bearings in 2 months...
Car mileage 95k miles
Driving style: mild
Wheel bearing history:
2 months ago: replaced front right wheel bearing
1 month ago: replaced rear left wheel bearing
today: rear right wheel bearing started to make grinding noise
Mods: F/R Perrin swaybar / Kartboy F/R endlinks / AGX struts/ Eibach prokit springs / STI BBS wheels / 225/45/17 PS2
I understand it's about time to replace wheel bearing on my car, but it's kind of tiring to do 3 wheel bearing work in 2 months including one axle.
Is it common for bearing to go bad all at the same time (~within 2 months)?
Old 01-16-2010, 12:49 AM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Were all the bad wheel bearings on the same wheel or different ones?
chazly413 is offline   Reply With Quote
Old 01-16-2010, 12:51 AM   #3
H8R
Member#: 186932
00 2.5RS, 03 M5,
95 Open Light Impreza
H8R is offline   Reply With Quote
Old 01-16-2010, 01:26 AM   #4
chazly413
Member#: 151079
2005 2.5RS RBP
That's me for not reading and assuming lol
Old 01-16-2010, 11:56 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Axle nut torque. Check it.
Old 01-16-2010, 12:06 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
and when it's time
it's time
Old 01-16-2010, 12:10 PM   #7
Bootleg
Member#: 76173
2006 WRX Limited
Steel Grey
good suggestion. it could also just be due to milage. your suspension setup doesn't have anything that should put added stress on the wheel bearings. if you had wheels with the wrong offset or something like that i'd say that could be a contributing factor but you've got the STi BBS'.
you're not running any crazy camber or caster settings are you? given the suspension theres only so much you can do with either one but it never hurts to ask.
Bootleg is offline   Reply With Quote
Old 01-16-2010, 12:52 PM   #8
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
I don't think it is very strange.
All the wheels covered almost the same milage, so when one bearing is EOL, the others are going to be almost done as well.
Do the FRont left one at the same time, as it will be going out shortly as well.
Dutch Scooby lover is offline   Reply With Quote
Old 01-16-2010, 03:35 PM   #9
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Originally Posted by Dutch Scooby lover View Post
Do the front left one at the same time, as it will be going out shortly as well.
+1. If they were all loaded the same and saw the same mileage they should all wear out at the same time.
Check your alignment and make sure you put high quality grease in when you put the new bearings in.
speedyHAM is offline   Reply With Quote
Old 01-16-2010, 06:44 PM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
loose or over-tightened axle nut? Will re-tightened axle nut with 140/F and 160/R torque spec again...
Old 01-16-2010, 07:05 PM   #11
zeroflat
Member#: 208696
2004 Subaru WRX STi
ive never seen axle nut torque wipe out a wheel bearing. i just hammer them home. my guess would be there is a common denomiator causing them to go bad. be it your wheels or the suspension set up. just replace all 4 (which you have almost accomplished already) and you should be good to go
zeroflat is offline   Reply With Quote
Old 01-16-2010, 09:36 PM   #12
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
LOL, just thinking about my old bug axle nut wrench. You literally HAMMERED them home.
bushflyr is offline   Reply With Quote
unbalanced wheels or bad wheel bearings mxpunk Tire & Wheel 16 12-16-2008 02:04 PM
3rd wheel bearing in 3 months, same wheel, what gives? sick1.8t Brakes, Steering & Suspension 53 02-06-2007 10:04 AM
Clicking noise from front right wheel- Bad wheel bearing? DrBoy01 Service & Maintenance 7 08-22-2003 12:30 AM
possible bad wheel bearing? wagman01 Brakes, Steering & Suspension 2 06-15-2001 11:12 PM
Noise: Bad wheel bearing or bad aligment? Flashboy Brakes, Steering & Suspension 6 03-05-2001 07:18 PM
