Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 01-16-2010, 07:12 PM   #1
chrisc75
Member#: 183729
07 sti
swp ///95 m3/ 94 supra tt
Default help with the dom 3xtr (with pics now)
okay so i was installing my tgv deletes back on today and about to put my 3in inlet on..weird enough i managed to get it on but im just curious if you guys running the 3in inlet if you have yours squished like mine is. im actually kind of scared of even running it like that or if it will even fit my intake manifold on. I wish i would of took sme pics but its about have way restricted and then again at the end..thinking about going blow thru im so tired of this
anyone have this issues
chrisc75 is offline   Reply With Quote
Old 01-16-2010, 07:41 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
did you take the motors off of the tgv's like should be done when modifiying them if not then the intake will fit like schitt.
john 1badSTI is offline   Reply With Quote
Old 01-16-2010, 08:05 PM   #3
chrisc75
Member#: 183729
07 sti
yes motors are gone
Old 01-16-2010, 08:15 PM   #4
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
It should fit kinda ok I don't know of any that don't push in here and there do to fitment issues but it should still function ok.
Old 01-16-2010, 10:14 PM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
My ATP fit rather well. I wish I'd taken a picture with the manifold off, but at the time I didn't realize it was abnormal for a 3" inlet to fit so well. It wasn't until after we did my install that I saw some pictures of Blouch and FP compressor covers practically banging into the TGV housings.
Old 01-17-2010, 12:34 PM   #6
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
stock location 3xtr?
3 inch inlet under the intake runner?
are you using a phenolic spacer?
i have the perrin rotated 3076r. perrin wants you to use a blow through on their set up for another 200$.
i opted to have dave weld a maf flange from ks tech on my cai. works well. ks told me they have made a mint selling those flanges for my application.
i'd like to see that...pm me the next meet you'll be at chris.
maxpowr is offline   Reply With Quote
Old 01-17-2010, 12:58 PM   #7
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
using the 3xtr w/ 2.5 inlet tgv delete and phenolic spacers aps inlet no problems. 3" inlet will rub and put a dent in the inlet on the tgv housing but should work w/o problems. fp fitment is so worse i went that route before getting the dom. imo the aps hard inlet is the better option w/ the silicone coupler. some work w/ rerouting fuel return and breather hoses but the fitment is much better.
krambte79 is offline   Reply With Quote
Old 01-17-2010, 08:31 PM   #8
chrisc75
Member#: 183729
07 sti
i still go to most of the meets i just go in other peoples or car or drive the m
ill take pictures tomorrow to show you guys how much im actually talking lol
Old 01-18-2010, 02:29 PM   #9
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Not to be a dck but what's this have to do with Proven Power Bragging?
JoeTX is offline   Reply With Quote
Old 01-18-2010, 04:11 PM   #10
chrisc75
Member#: 183729
07 sti
didn't even realize i put it on the power bragging section i guess i just hit new thread lol (mod you can move it if you'd like)
okay so i just took a few quick pics on my phone lmk what you guys think..the inlet isnt clamped on right now
Old 01-18-2010, 04:13 PM   #11
chrisc75
Member#: 183729
07 sti
what do you guys think the pictures dont seem too bad but it look horrible in person and i still have to squeeze it down some to get the intake manifold to fit over it
Old 01-18-2010, 04:47 PM   #12
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
10.1@138mph / JR Tuned
welcome to the problems of a stock location 3inch inlet turbo my friend.. best bet buy a fmic and go blow thru! silicone inlet will prob crush under high boost in the first place my friend.. avoid the problem
OVeRBOOSTn is offline   Reply With Quote
Old 01-18-2010, 05:12 PM   #13
chrisc75
Member#: 183729
07 sti
i have the perrin fmic right now..i was thinking of blow thru..any downsides and how do u think a screen will just be fine to cover the turbo compressor wheel itself
Old 01-18-2010, 08:09 PM   #14
chrisc75
Member#: 183729
07 sti
anyone else?
Old 01-18-2010, 08:14 PM   #15
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Even the 2.4 inlets are a little squished with these larger stock mounts.
What screens are you talking about?
The new perrin silicone inlets are reinforced with metal rings, they won't crush under maximum suck!
Louie is offline   Reply With Quote
Old 01-18-2010, 08:20 PM   #16
chrisc75
Member#: 183729
07 sti
i was thinking if i went blow thru louie id just put a mesh screen over the trubo inlet so i wouldnt get rocks up in there...i cant remember right but did u run the 2.4 or 3in on your setup?
Old 01-18-2010, 09:00 PM   #17
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
2.4, I already had the aforementioned inlet, so I stayed with a 2.4. To do it over again, I would've went rotated... would've cost the same, and the benies are grander
Old 01-18-2010, 09:12 PM   #18
chrisc75
Member#: 183729
07 sti
yaa i know me too but im stuck now lol any cons to blowthru setup?
Old 01-18-2010, 09:55 PM   #19
k mier
Member#: 98000
05 sti e85@420hp
Just asking. While it's still apart can you match the tgv closer to the head intake? Is there enough metal? Curious...if the intakes are hogged out that big and the tgvs can't be made to match is their any/much gain going that big on the intake?
k mier is offline   Reply With Quote
Old 01-18-2010, 10:50 PM   #20
AkumaMotorsports
Member#: 214570
Might want to ditch that T Bolt clamp too. Absolutely no need for that much clamping force.
John
AkumaMotorsports is offline   Reply With Quote
Old 01-18-2010, 11:27 PM   #21
chrisc75
Member#: 183729
07 sti
never want it to come off lol and what do u all think...squash it and make it fit or blowthru set up?
Old 01-19-2010, 12:07 AM   #22
CatfaceType-R
Member#: 81102
looks like another "had to get a aps hard inlet"
CatfaceType-R is online now   Reply With Quote
Old 01-19-2010, 12:15 AM   #23
chrisc75
Member#: 183729
07 sti
when i was searching to get a silicone or hard inlet everyone kept saying silicone was the way to go now its going backward on me..fml
Old 01-19-2010, 12:50 AM   #24
socalLGT
Member#: 89752
08 STI
That is fitting about as well as it's going to. As someone mentioned before, don't use the t-bolt clamp. The snout on the comp cover is very short and if you use a t-bolt, there won't be any silicone past the edge of the clamp. That will make the hose want to worm off after time. We use a really nice, thick surface worm drive clamp on those connections and have found it to be by far the most reliable and secure way to go.
socalLGT is offline   Reply With Quote
Old 01-19-2010, 01:07 AM   #25
chrisc75
Member#: 183729
07 sti
soo you think it will be okay as it sits..**** worried me lol seems to pinched
Out with the 2.0 and in with the 2.7 w/pics Adrenalin Rush Built Motor Discussion 459 11-07-2014 01:53 PM
Out with the RS. In with with the Legacy LTD jdOgg3355 North West Impreza Club Forum -- NWIC 38 05-15-2009 05:48 PM
Out with the old, in with the new (non-subaru), lots of pics Ziggyrama New England Impreza Club Forum -- NESIC 29 05-11-2007 10:25 PM
help with the part in this pic Drive4Ever Newbies & FAQs 10 10-19-2005 09:28 AM
Had a blast with the GF in Vegas *pics* Kinsbane Off-Topic 47 06-09-2004 12:22 PM
