#1 |
NASIOC Manufacturer
Member#: 4803
4/20/2010 -- Update at post #16
Location: COBB Tuning Surgeline Ambient Temp: 43.5 °F (daily mean) Elevation: Approx. Sea Level Weather: Indoors Car: 2004 Subaru Impreza WRX Wagon Tuner: Lance Lucas Dyno Info: Mustang AWD-500 Peak HP at RPM: 405whp @ 5740 rpm (uncorrected) Peak Torque at RPM: 388wtq @ 5160 rpm (uncorrected) Baseline hp/tq for a stock vehicle on same dyno: Most recent stock vehicle reference -- 2010 STi: 239 wtq, 228 whp Target Boost: ~22-19psi Target AFR: .75 lambda Fuel: E85 Engine/Power Modifications: - EJ257 STi Longblock - Perrin Performance/COBB Tuning GT35R Rotated Turbocharger Kit - CP 100mm Forged Pistons - Cosworth Rod and Main Bearings - Cosworth Headgaskets - Brian Crower 272/272 STi Cams - Brian Crower Valve Springs and Spring Retainers - Shotpeened Subaru STi Rods - JDM Subaru 12mm Oil Pump - ARP Head Stud Kit - Perrin Performance/COBB Tuning Front-Mount Intercooler Kit - Perrin Performance/COBB Tuning Topfeed Fuel Rails - Ported and Polished TGV Deletes - DeatschWerks 1000cc Injectors - Walbro 255LPH High-Flow Fuel Pump - Crawford Performance Air/Oil Separator - COBB Tuning MAP Sensor Adapter - COBB Tuning Lightweight Crank Pulley - COBB Tuning Battery Tiedown - COBB Tuning Oil Filler Cap - AEM Standalone Programmable EMS - AEM 3.5 Bar MAP Sensor - GrimmSpeed Boost Control Solenoid - Cosworth Cam Angle Sensor Bracket - GrimmSpeed Ported and Polished Exhaust Manifolds - DEI Exhaust Wraped Uppipe and Downpipe - Greddy EVO2 Catback Exhaust - COBB Tuning Hardened Exhaust Hangers - OEM Subaru Engine Block Heater Kit - Amsoil 20w-50 Driveline Modifications: - STi 6 Speed Transmission (2006) - STi Driveshaft - South Bend Stage 3 Clutch Kit - Redline Lightweight Shockproof Trans and Rear Diff Gear Oil I recently finished this rebuild on my personal car, a 2004 WRX Wagon I've owned for about 3.5 years. The last setup was a 2.5L hybrid with an 18G and EWG on E85 that I used, abused and eventually destroyed at the dragstrip I refused to let a broken OEM piston slow me down and immediately began the rebuild. We made the active decision to build the car using commonly available, proven products as a good example of what can be acheived with a "budget" build by Surgeline, without our normal touches -- no AN fittings, no V-Band flanges, no Tial exhaust housings, no rotated manifold, etc. Everything has turned out wonderfully and my car is a great example of the potential available using the good-ole K.I.S.S. principle. Stay tuned for another employee's recent build that is absolutely blinged-out bananas with commensurate dyno results ![]() These are the priliminary dyno tuning results, at both wastegate (16psi) and a couple days later at 22psi tapering to 19psi or so. At a very rich .75 lambda I am out of injector at ~21psi, so I kept boost low on top for the time being. Timing curve is extremely soft as well. My long-term plan is to add a second Walbro in-tank and raise base fuel pressure slightly, then tune to 450whp on E85 for daily driving and hopefully an easy 500whp on C16 for drag strip fun! ![]() ![]() Virtually all work was done on my car after work or on Sundays over a 3 month span as I'm currently juggling graduate school and work. I couldn't have finished without a LOT of help! Special thanks to COBB Tuning, Dustin Harris, Tim Bailey, Brandon Lumpkins, Nick Blake, Chris Fogg, Audio Integrations, my parents, and a lot of other people I am forgetting. Thanks for looking, Lance Lucas COBB Tuning Surgeline 16580 SW 72nd Ave Portland, OR 97224 (503) 670-9500 http://surgeline.cobbtuning.com
#2 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
great numbers for such a low boost and conservative tune, just get ID2000s and raise the boost...
Its been proven on EVOM that there is not really a good reason to run C16 if E85 is available; there is almost no power difference. Fastest street evo is E85 powered and Buschur is switching Bad Bish to E85 full time...no more race gas ![]() Another car with BC cams, how do you guys like them? |
#3 |
Member#: 162790
NWIC
Very nice ride!
#4 |
Member#: 125529
Vehicle:02 WRX 18G EJ205 1/4 mi stock block record |
Nicely done I like your approach
How do you like the South Bend Clutch? |
#5 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
It ceases to amaze me like someone from COBB would decide to run c16 and e85... e85 > c16 all day long. Why waste the money???
Car looks good though. |
#6 |
Member#: 2818
Vehicle:2000 2.5RS |
Looking good! Was the slower spoolup on the higher power run was due to boost control issues or did you get on the throttle earlier or use a lower gear? Are you using the AEM for boost control? After years of fiddling with my AVCR and dealing with temperature changes, spool up issues and overboost, I switched to a Hallman Pro MBC (very K.I.S.S.) and I couldn't be happier.
![]() Good luck and nice car. |
#7 | ||||
NASIOC Manufacturer
Member#: 4803
E85 is great stuff, no doubt! Tihis car has been on E85 100% full-time since August 2008. Corn booze baby ![]() There is one good reason for me to run C16 over E85 at the track -- I can't afford to build a fuel system that is big enough to support over 500whp on E85 Achieving 500whp on E85 the sustainable way means at least a surge tank and external 044 with -8 feed and -6 return. In a nutshell, using gas (C16) means I get ~30% more capability out of my current fuel system setup. I'll put a fuel system in the car next winter and then get bonkers on E85. Quote:
I am using the AEM for boost control, so far I've had decent luck with the controller. It's more or less just a duty cycle controller with some simple feedback corrections for me right now. May stick with it, may go Hallman Pro. We shall see what happens when the winter finally breaks. Thank you to all for the questions and the kind words! Regards, Lance |
#8 |
Member#: 224913
Vehicle:1098 desmodromic s |
Good #'s. I like the Honda battery!
#9 |
Member#: 197567
Great numbers tho
#10 |
Member#: 128760
RMIC
Vehicle:2012 Ruckus/WRX Red&White/Gray |
Nice work Lance!
So what does the Cobb/Perrin combo mean on the turbo and intercooler kits, I'm assuming they are modified in some way, what is that? |
#11 |
Member#: 119718
NWIC
Vehicle:2008 STI DGM |
Wow.... your car changed so much after the last time I seen it Lance! Did you tune it or tim and did you use a AP2 or are you still tuning it with open source?
Congrats on the awsome power..... Can't wait until I can reach 450ish on my car. |
#12 |
Member#: 114999
NWIC
Vehicle:05 Dom3 Powah STi OBP |
Yea whats the deal with the Honda battery? I saw it on Brandon's car as well. What size is that and how much?
#13 | |||
NASIOC Manufacturer
Member#: 4803
The 02-05 ECU has enough limitations that using a standalone made the most sense to get all of the features I'm looking for.Quote:
![]() Thanks for positive feedback guys! Regards, Lance |
#14 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
Hmmm, guess I didn't realize you worked for Surgeline Lance.
Good job! post up your results once the C16 is done! In the mean time, Enjoy your car! |
#15 |
Member#: 187128
I like the fact that its a wagon and a weekend (meh when I find the time)
Cobb FTW NIce build! |
#16 |
NASIOC Manufacturer
Member#: 4803
Update!
Location: COBB Tuning Surgeline Ambient Temp: ~60 °F Elevation: Approx. Sea Level Weather: Indoors Car: 2004 Subaru Impreza WRX Wagon Tuner: Lance Lucas Dyno Info: Mustang AWD-500 Peak HP at RPM: 454whp (uncorrected) Peak Torque at RPM: 437wtq (uncorrected) Baseline hp/tq for a stock vehicle on same dyno: Most recent stock vehicle reference -- 2010 STi: 239 wtq, 228 whp Target Boost: ~23-22psi Target AFR: .75 lambda Fuel: E85 The car has undergone some minor mechanical changes over the past few months: - Dual Walbro Fuel Pumps In-Tank - Injector Dynamics ID2000 Injectors - Perrin Equal-Length Header - COBB Tuning XLE Blowoff Valve - C&L v2 3" Speed Density Intake ![]() - Koyo Aluminum Radiator - Amsoil 15w-50 Fully Synthetic Oil The results have been great! Here are the new power numbers (wastegate vs. 23-22psi): Excuse the wavy boost lines, the dyno sensor seems to have gotten a bit shaky. The boost curves are nice and smooth in reality (as seen by the torque curves). Comparing wastegate vs. wastegate before an after shows a nice incremental power increase from the Perrin EL Header: Thanks for looking ![]() Regards, Lance COBB Tuning Surgeline |
#17 |
Member#: 158313
Vehicle:2003 WRX PSM |
Nice results. Sorry to sidetrack, but do you have anything from the 18g for comparison?
#18 |
Member#: 6675
NWIC
Vehicle:98 SF5 some mods 01 allroad |
Looks like fun Lance, nice work!!!
#19 |
Member#: 95840
NWIC
Lance, have you run across the perrin header blowing apart?
#20 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Get it to the track this weekend!!!!!
#21 |
NASIOC Manufacturer
Member#: 4803
Update time!
Carnage Final score for this engine: 500 whp = 1, stock connecting rod = 0.Fastener failure on #1 connecting rod. All is trashed! It happened during the 2nd pass of qualifying at our Race Against Cancer event on July 4th. First pass was 12.4 @ 120.75 ![]() ![]() ![]() ![]() ![]() ![]() Will be starting the new engine build this week! Regards, Lance COBB Tuning |
#22 |
Member#: 133146
ouch.... weird it wasn't making a lot power and the motor was not pushed at all, did the shotpeening on the rod had anything to do with the failure?
again ouch ![]() |
#23 |
Member#: 75129
Vehicle:09 WRX stg 2+ Lost the boxer rumble |
man that is so painful to look at...But i'm sure you guys will build it up better then ever.
#24 |
Member#: 153880
RMIC
Holy smokes. That is not a pretty looking failure, it looks like it fell from the sky lol.
I'd say 437wtq on a MD is quite a bit of torque for stock rod. Sucks to hear about the failure. |
#25 |
Member#: 140643
South East
Vehicle:04' PSM Limited Wrx 371whp/344wtq E85 |
carnage
it's like your proud of it!! i'm suprised too it failed with not really pushing it that hard! think it had to do with what juan mentioned?? ^^ |
| Thread Tools | |
| Display Modes | |
| Dyno Tune: 2.5L, GT35R, E85-Tuned STI Makes 540whp! | Cobb Tuning | Proven Power Bragging | 45 | 04-25-2013 04:42 AM |
| Dyno results- Cobb Tuned 2005 Outback XT -Cobb/Watt Built 2.5L- AVO380 (2871R) | gregnauman | Proven Power Bragging | 102 | 06-10-2012 12:23 PM |
| 2004 WRX hybrid - 2.5L 9:1 CR GT35R Topspeed tuned | CoolRex | Proven Power Bragging | 61 | 02-16-2011 09:23 PM |
| 2002 WRX wagon 2.5L hybrid w/ Blouch 2.5R turbo | triguy | Proven Power Bragging | 12 | 10-18-2008 03:09 PM |
| FS: 2004 WRX JDM 2.5L motor 10k miles - TN | aaronkuschel | Private Vehicle 'For Sale' Classifieds | 1 | 03-17-2006 02:08 PM |
