Old 01-17-2010, 02:49 PM   #1
theboz32
Member#: 197221
2008 WRX VF48
EFI Logics Tuned!!!
Default Whiteline Sway bars and Kartboy endlink knocking noise
Hey guys to give you some background I recently received a set of front and rear sway bars for my 08 wrx. I also swapped out the endlinks at the same time early this year. The improvement is great and i love these sway bars but there is a problem. When i go over bumps in the road or speed bumps i hear a knocking noise. I checked this morning to see if there was any damage to the car or swaybars/endlinks but there is none. The only thing I can see is that there is about 3/4 inch of space total (1/4in left 1/2 in right) between the left and right bushing and the idk what the right term is for it but the safety notch on the bar on both sides. Could the noise be the bushings hitting that? but if so why not during hard cornering only over bumps? please help!!!!! do i need to send it back for another bar? I had it installed by a friend who is a machanice and he said it is all put in correctly after rechecking it today so thats not the issue PLEASE HELPP!!!!
theboz32 is offline   Reply With Quote
Old 01-17-2010, 03:06 PM   #2
theboz32
Member#: 197221
2008 WRX VF48
EFI Logics Tuned!!!
btw its 24mm front and 22mm rear with the kartboy endlinks and I've heard there is something going around about kartboy endlinks being to big true or not?
Old 01-17-2010, 03:07 PM   #3
Hokie-wrx wagon
Member#: 87194
Is the knocking coming from the front or rear of the car?
You should torque down the end links again (35 ft lbs). You may also want to re-grease the sway bar bushings.
If the noise is coming from the rear, which direction are the upper bolts pointed? If there's too much excess pointed towards the struts, those bolts could be coming in contact with the strut body.
Hokie-wrx wagon is offline   Reply With Quote
Old 01-17-2010, 03:12 PM   #4
theboz32
Member#: 197221
2008 WRX VF48
EFI Logics Tuned!!!
i think its coming from both but my friend who put them in says they are only coming from the front but i'll check it out for sure that could be something thanks
Old 01-17-2010, 05:04 PM   #5
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Post pics of the car on ramps. Shots of the swaybar, the endlinks, the bushings and their mounts, front and rear.
Arnie is offline   Reply With Quote
Old 01-17-2010, 07:48 PM   #6
theboz32
Member#: 197221
2008 WRX VF48
EFI Logics Tuned!!!
ok will do
Old 01-17-2010, 08:23 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Did you capture the bushings into the links with the washers?
Old 01-19-2010, 10:29 AM   #8
rexassian
Member#: 183717
1999 2.5RS
BRP
I'm having the same noises, same whiteline rear 22mm adjustable bar. I'll take pics tonight when I get back to my car but what's happening in the rear is that the links are too long and the bolt head is coming into contact with the lower spring perch on the strut. I had originally taken it into the dealer to check if it was noise related to something else, but once they got it up on the lift, the suspension droop was enough such that the bolt head from the endlinks was touching the spring perch. Pics coming tonight...
forgot to mention that I'm on cobb springs right now so there is a good 1.25" of drop in the back which definitely makes this worse. If you're stock ride height, maybe the Kartboy links are the right length...
rexassian is offline   Reply With Quote
Old 01-19-2010, 01:44 PM   #9
bzbuzz
Member#: 116052
2011 STI ( Sold )
35ft/lb is for the stock. I do about 45ft/lb. no issues for 2 years.
bzbuzz is offline   Reply With Quote
Old 01-19-2010, 02:14 PM   #10
ST0ICH
Member#: 120306
2005 年ワ
For the sway bar bushings I used white lithium grease and 2 + years with no issues... And when you tighten up the bolts, have some thread lock laying around so it wont loosen up again. I did have my endlinks loosen up front before, and when I applied some thread lock, it hasn't been a problem for more than a year. Hope this helps...
ST0ICH is offline   Reply With Quote
Old 01-19-2010, 08:19 PM   #11
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Another time honored install trick when using poly bushings with swaybars is to wrap the swaybar with teflon tape then lube. You won't get knocking for a good long while. If you drive in wet winter conditions, the lube can be washed away and you'll get some squeaking or knocking.
Old 01-21-2010, 01:08 AM   #12
rexassian
Member#: 183717
1999 2.5RS
BRP
Sorry for the delay, here are my pics, first with the car raised, suspension at full droop:
another angle
and at normal ride height showing the angle on the bar:
and yes, I double checked, the bar is centered...
Old 01-21-2010, 06:26 AM   #13
Hokie-wrx wagon
Member#: 87194
The endlink is making contact with the lower strut perch at full droop (possibly before full droop). Also your left rear spring doesn't look like it's seated correctly on the lower strut perch.
Old 01-21-2010, 10:00 AM   #14
rexassian
Member#: 183717
1999 2.5RS
BRP
yea, that's exactly the point of the thread and the point I was trying to make. That the kartboy endlinks are too long for a car with drop springs. I'd switch the cobb springs out for better ones but I'm waiting on the blingsteins to show up and then hopefully that will fix the being dropped too much issue. I'm worried that there will still be a bit of contact though as, again, I think the endlinks are too long.
Yep, that's what you get with aftermarket springs and stock struts, they don't work together perfectly. See above about waiting to fix it.
Old 01-21-2010, 07:04 PM   #15
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Have you tried putting on the stock endlinks to see how they compare?
Old 01-21-2010, 07:57 PM   #16
rexassian
Member#: 183717
1999 2.5RS
BRP
I had rallitek (same style/dimensions as stock just more beefy) links on before these. I could only get to the middle hole but didn't have any noises. The Kartboy links were about 1/2" longer than rallitek.
Old 01-21-2010, 08:32 PM   #17
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
My endlinks nuts loosened after 2 days of autocrossing (AVO adjustable) on my FSB. Made an annoying rattled going over uneven bumps. Put locktite on the treads and it hasn't happened since.
09rexwagon is offline   Reply With Quote
Old 01-21-2010, 08:36 PM   #18
Turn in Concepts
Member#: 93646
Many Track Records
That's really weird as we tested those, and clearances were good at full droop. let me drop this over to Tom so we can get started on figuring it out.
-Clint
edit: OP, I know you said the bar is centered, but I want to ask this - are you seeing contact on both sides with it a full droop?
Old 01-21-2010, 08:51 PM   #19
rexassian
Member#: 183717
1999 2.5RS
BRP
-Clint
Thanks Clint for adding some traction to this. I sent a mail over to Tom about this but I'm sure he's really busy and hasn't seen it yet.
I'm not the OP but my bar is centered. However, I did try to move it so that it wouldn't contact on the driver's side which resulted in contact on the passenger's side.
I can take more pics if it would help. Just let us know what you and Tom think. Thanks again.
Old 01-21-2010, 08:54 PM   #20
Member#: 67
1999 Outlasting
the competition.
I replied to who ever sent the email. let me take some measurements tomorrow morning. We did a lot of different setup testing before releasing this.
We'll figure something out.
Tom
Old 01-21-2010, 09:22 PM   #21
dur4ce
Member#: 213449
2009 WRX Prem 5-door
WR Blue Mica
+1 I've got Kartboy endlinks about to install on my whiteline bars. Keep us updated!
dur4ce is offline   Reply With Quote
Old 01-21-2010, 10:07 PM   #22
Hokie-wrx wagon
Member#: 87194
Probably a dumb question, but this is the correct sway bar for your car (BSR49XZ))? Do you have the part # of yours?
Also, it appears that if you rotated the left strut 180 degrees (mounted the opposite direction), there would be more clearance on the endlink side.
Old 01-21-2010, 10:13 PM   #23
rexassian
Member#: 183717
1999 2.5RS
BRP
Tom
Hoping that was me. Let me know if you need any info from me. Thanks.
BTW, I foolishly had email off from other members so I didn't get your reply. Sorry, I should have checked that first before sending through the board.
Hokie: WRX/STi are the same model numbers, same bar. Here's Whiteline's page showing applications for BSR49XZ
Old 01-21-2010, 10:15 PM   #24
09rexwagon
Member#: 216135
2011 Civic SI
Probably a dumb question, but this is the correct sway bar for your car? Are the WRX and STI rear sway bars interchangeable? Do you have the part # of yours?
The rear on the GE/GH is the same as the rear on the GR. The fronts are different though.
And we don't have struts in the rear but yes the shock can be rotated 180 degrees due to the 2 bolt top hat.
Old 01-21-2010, 10:18 PM   #25
rexassian
Member#: 183717
1999 2.5RS
BRP
True, but this is stock fitment. I'm positive because I was unable to remove that side from the lower mount even with my 700 lb-ft impact.
But I do see your point. I'll take a look at the other side and see if I installed it back the same way...
WTB: 04 STi Rear Sway Bar and Kartboy endlinks bulldog8567 Private 'Wanted' Classifieds 4 11-21-2009 05:29 AM
F/S Hotchkis Sway Bars and Kartboy Endlinks legacyvt286 Suspension/Brakes/Handling 20 11-18-2008 07:58 PM
Whiteline sway bar and Perrin endlinks skiman1 RMIC Private Classifieds 2 07-17-2007 01:15 AM
FS: Cusco Rear Sway Bar and Kartboy Endlinks iloveturbos Bay Area Impreza Club Forum -- BAIC 3 02-26-2004 06:09 PM
FS: Whiteline Sway bar and Kartboy endlinks TooBlueRoo Private 'For Sale' Classifieds 1 10-13-2003 10:13 AM
