#1 |
Member#: 230425
RMIC
Vehicle:2000 Impreza RS silver |
I don't know what its called but it just looks way good
#2 |
Member#: 230425
RMIC
#3 |
Member#: 35276
RMIC
Vehicle:dust collector |
you need to cook them in the oven
#4 |
Member#: 199522
RMIC
Vehicle:2004 Impreza STi PsM |
Yes what he said, haha But to be more clear. You take them off the car and remove the bulbs, then throw them in your oven that has been preheated to 200 degrees. Let them sit in there for about 3 or 4 minutes Then pull them out and very carefully with a flat head screw driver pry the clear lens away from the housing. Once you have the clear lens off the housing mask off the areas you don't want black and then hit it with some spray paint. Then when you are done heat them up again enough to be able to push the clear lens back on the housing and maybe ad an extra touch of sealant around them. |
#5 |
Member#: 230425
RMIC
cool thanks
#6 |
Member#: 117763
RMIC
If yours are clear then I'll trade you my "blacked" head lights. From 00 RS btw
#7 |
Member#: 158534
RMIC
Vehicle:99 2.5 Wagon |
do this ^^^^ do it justin. depending on what shape the lenses are in i guess... but i'd for sure go take a look.
#8 |
Member#: 204690
RMIC
Vehicle:1992 Turbo Wagon dead red |
#9 |
Member#: 117763
RMIC
Let me know if so. I can take pictures also.
#10 |
Member#: 230425
RMIC
well one of mine is cracked a little bit but if you still want them i you can send pictures
#11 |
Member#: 230425
RMIC
it is on the left one and the crack is only like the size of a quarter
#12 |
Member#: 214872
South East
Vehicle:04 Sti WRB |
#13 |
Member#: 85327
RMIC
Vehicle:More projects than you can shake a stick at. |
search Koji Mod
#14 |
Member#: 199522
RMIC
I believe it was just a black RTV sealant found at any autoparts store.
| Thread Tools | |
| Display Modes | |
| How do I make my AVN 5435 switch to the reverse cam when i select reverse gear? | jigga | Car Audio, Video & Security | 7 | 07-09-2006 01:44 PM |
| How Do I Make My Outlet Work When the Car is Off? | BoardRider | Electrical & Lighting | 11 | 10-06-2005 04:14 PM |
| How do I make my headlights look like this? | 992.5RS | Electrical & Lighting | 8 | 02-08-2005 11:41 PM |
| how do i make my stainless steel exhaust look new again? | Keirik | Interior & Exterior Modification | 20 | 05-13-2001 11:53 AM |
| How do I make my own decals on my printer? | Andrew | General Forum Archive | 2 | 12-14-2000 04:44 AM |
