Old 01-17-2010, 09:38 PM   #1
fizzak
Member#: 84968
2005 WRX
Default Cobb stg2...Just need an AP and dp right?
Do you need a full turboback or just the Accessport and a downpipe for Cobb stage 2. I'd like to keep the stock catback for stealth and dont care if I lose a few hp.
Looking at the invidia divorced catted.
Thanks
fizzak is offline   Reply With Quote
Old 01-17-2010, 09:46 PM   #2
Fast03Wagon
Member#: 142375
2003 WRX Wagon
Midnight Blue
just a downpipe and ap will suffice for stage 2. i ran that setup for a bit. however, you should get an adapter for a 3" dp to stock catback so you dont have a nasty exhaust leak.
Fast03Wagon is offline   Reply With Quote
Old 01-22-2010, 12:00 PM   #3
98outbacksprt
Member#: 130263
2004 Fxt
its not entirely needed but a turbo back wouldn't hurt...i helix catless dp and spt cat back and no problems.
98outbacksprt is offline   Reply With Quote
Old 01-27-2010, 05:13 AM   #4
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
eaither one of those setups would work for a stage 2. full turbo back or just DP is fine
crash60068 is offline   Reply With Quote
Old 02-02-2010, 08:05 PM   #5
dvinales
Member#: 237227
2006 Imprezza WRX
What map should i use for my 06 wrx? I have a spt intake and a cat back exhaust.
dvinales is offline   Reply With Quote
Old 02-02-2010, 08:47 PM   #6
AeolusWRX
Member#: 120949
2011 Forester XT
Gray
I have my cobb 3" DP mated up to the stock wrx exhaust with no adapter. No problems. I think the stock exhaust is 2". Mated up just fine. Just make sure you buy new gaskets and spring loaded bolts. Those bolts rust out and there is nothing like having a replacement set when you snap those babies in half removing them!
AeolusWRX is offline   Reply With Quote
Old 02-02-2010, 10:34 PM   #7
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
umm a stage 1 map that for the v1 AP i think the Rev calibrated number is 101 for yours. which AP are you getting or have???
Old 02-02-2010, 10:46 PM   #8
AeolusWRX
Member#: 120949
2011 Forester XT
Gray
Originally Posted by crash60068 View Post
umm a stage 2 map that for the v1 AP i think the Rev calibrated number is 101 for yours. which AP are you getting or have???
Um . . . I'm pretty sure you need a downpipe for stage 2 buddy :
"Description: Stage 2 for 2006 WRX MT vehicles with STOCK INTAKE
SYSTEM ONLY and a turbo-back exhaust system with high-flow catalytic
converter running 93 or 94 octane.
Hardware Requirements: Otherwise stock vehicle with a STOCK INTAKE
SYSTEM ONLY, tested with a Cobb Tuning turbo-back exhaust system
with high-flow catalytic converter. An equivalent turbo-back exhaust
system could be used. If the turbo-back exhaust system relieves
back-pressure to an excessive point boost creep is possible. If a
lesser flowing turbo-back exhaust system is used then boost targets
may not be achievable. The addition of any other hardware may make
the vehicle perform poorly."
Don't reflash to stage 2 unless you have a downpipe installed. The catback is insufficient for this map. The exhaust needs to be either a turboback or a high flow downpipe mated to the stock catback.
All of this information is available in the map notes section on the cobb website:
http://cobbtuning.com/products/?id=4503
This one is free. The next time I am going to charge you for being lazy and not researching yourself.
Old 02-02-2010, 11:05 PM   #9
crash60068
Member#: 209218
2005 WRB WRX 4EAT
93 MR2, 2008 Yaris
opps sorry i drop the ball on that one. i know thats a stage 2 that what my car is.
So I just ordered an AP, AVO DP, and AVO intake, what should I watch out for? lateralus1082 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-20-2008 11:00 PM
Do I NEED an AP with a high flow DP? Sheehan Newbies & FAQs 16 01-02-2008 11:03 PM
Ok so My Cobb CBE just arrived but is it the right one??? 1337Impreza Normally Aspirated Powertrain 11 12-13-2007 04:14 PM
Cobb stg2 users w/an EGT gauge. What are normal temps? Drew888 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-12-2005 04:34 PM
Is the STi catback free enough for just an Accessport and DP? Hollidark Engine Management & Tuning 3 12-15-2004 08:15 PM
