Old 01-18-2010, 10:47 AM   #1
BKscooby
Member#: 163601
Default Is my rear diff shot?
Hi,
I began having an issue about 5 days ago, when I fully depress the clutch, pop it into first at a standstill, I hear a thud coming from the rear of the car, mind you the clutch pedal is still depressed. It happens randomly and in order to replicate the sound I would have do disengage, engage the clutch and stick it into the first. My thought on this was either the differential bushing, like a perrins lockout bushing set would be able to cure it, or maybe the my diff is just shot, and is on it's way out. Any input will be greatly appreciated.
Thanks,
BKscooby is offline   Reply With Quote
Old 01-18-2010, 10:50 AM   #2
IIdiceII
Member#: 90438
diff bushings should cure the clunk.
IIdiceII is offline   Reply With Quote
Old 01-18-2010, 11:26 AM   #3
BKscooby
Member#: 163601
The problem that I am experiencing is more of a thud than a clunk though. 2 of my buddies who have STIs, had the clunk once in the 1st gear, and as soon as they let go off the clutch and press the gas pedal you could've heard the clunk. My problem is that I hear a thud with the clutch pushed in when I stick it in the first gear. I am just not sure if the diff bushings will cure the problem, opposite to just buying a used R160 for like $150 bucks. Also do all 02-07wrx come with R160 diffs/ readily interchangeable?
Old 01-18-2010, 04:30 PM   #4
BKscooby
Member#: 163601
bumpppp
Old 01-18-2010, 06:43 PM   #5
steep
Member#: 90890
2011 Brocoma
Silverstreak
What part of the clunk makes you think its a shot lsd? Have you put the car up on jackstands and looked around for some loose parts yet?
steep is offline   Reply With Quote
Old 01-18-2010, 07:48 PM   #6
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
could be a bad u-joint in the driveshaft perhaps?
irish44j is offline   Reply With Quote
Old 01-19-2010, 10:36 AM   #7
BKscooby
Member#: 163601
Yea, no loose parts. Still trying to figure out if it might be something else before getting the diff lockout bushing kit.
Ok, What REALLY Is My Rear Diff Ratio? Tranny Gurus ONLY! 02CWRX Transmission (AT/MT) & Driveline 31 08-28-2012 03:45 AM
is my rear diff done? jeraljay Transmission (AT/MT) & Driveline 6 12-18-2008 05:14 PM
Is my rear diff shot? arf80 Transmission (AT/MT) & Driveline 3 09-30-2008 08:32 PM
Is my rear diff going south? WRX Bamboo Steamer Transmission (AT/MT) & Driveline 5 03-17-2004 05:21 PM
what gearing is my rear diff? supermoose Subaru Conversions 1 09-04-2003 05:07 PM
