Old 01-18-2010, 05:53 PM   #1
hobbesnapoli
Member#: 221436
02 WRX vf39
Default Hybrid Gasket Set
Did some searching- seems like if you're building a Hybrid you definitely want the 10105AA590 / EJ257 gasket set. Putting EJ205 heads on an EJ257- will I need any other gaskets? - Basically I have an EJ257 SB and all small parts / heads / intake / etc. are EJ205 parts.
Only thing that jumps out from my reading is the oil cooler gaskets- which may be different.
Thanks
hobbesnapoli is offline   Reply With Quote
Old 01-18-2010, 06:32 PM   #2
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
sti head gasket ftw!
vanillajuice is offline   Reply With Quote
Old 01-18-2010, 09:04 PM   #3
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
you want the ej205 complete gasket set then STI 2.5 head gaskets. the only thing i noticed i didnt get with my complete gasket set is the rubber gasket for the breather thing on each head. shrugs.
ownnij is offline   Reply With Quote
Old 01-18-2010, 09:48 PM   #4
MrSlowbaru
Member#: 129231
2005 wrx
cgm
if you are building a hybrid motor and want to use an oem headgasket, i would suggest the 98-99 legacy outback, 2.5 twin cam N/A head gasket. it is much thicker than the oem sti headgasket and will bring your CR down a little.
MrSlowbaru is offline   Reply With Quote
Old 01-18-2010, 10:52 PM   #5
hobbesnapoli
Member#: 221436
02 WRX vf39
So the EJ205 gasket set has different top end gaskets than then EJ257 gasket kit? Those are the only ones I can't compare (no sti top end) -although I'm assuming it's all basically the same...? since most of the block gaskets are
(I know I need STI head gaskets)
Old 01-18-2010, 11:18 PM   #6
ownnij
Member#: 70459
yeah your going to need the gasket set for the ej205 because i believe some of the gaskets on the head are different between the ej205 and ej257. i forgot what it was but it worked out fine for me but like i said. it didnt come with the gasket for that breather thing on each side of the heads.
Old 01-19-2010, 07:11 AM   #7
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
i used the 257 gakset kit. doesnt really matter. if you buy 257 you need vc and cam gaskets. or you can but the 205 set and buy headgasket seperate. either way, you end up buy a couple extra gaskets. also, you dont NEED to use STi hg, many use cometic and they work just fine too.
AWDWRXLOVER is offline   Reply With Quote
Old 01-19-2010, 01:46 PM   #8
hobbesnapoli
Member#: 221436
02 WRX vf39
Yea i'll just buy the 205 kit and then pick HGs based off which pistons I end up with / compression I want
Thanks for the help guys
Old 01-19-2010, 02:07 PM   #9
vanillajuice
Member#: 139321
2004 WRX 2.5 Hybrid
Java Black Pearl
higher compresson ftw!
Old 02-25-2010, 08:56 AM   #10
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
I know im bringing this back up,but id rather,than add a new thread.
If im running an ej257 block,and 05 sti heads,should i should just go with the 05 sti gasket set?
I just want to make sure im going to get everything i need in there.
jsnm is offline   Reply With Quote
Old 02-25-2010, 09:08 AM   #11
ownnij
Member#: 70459
Yes of course but what other gasket set would you consider? this thread is about gasket sets for hybrid motors. if you have a oem assembled motor then you'll use the gasket set that corresponds with your motor. like ej205/ej205 gaskets, ej257/ej257 gaskets, ej255/ej255 gaskets. if you give the dealer your vin number they can pull your parts easy.
Old 02-25-2010, 02:07 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Well, there are like half a dozen different ways to do the intake cam gears and pickup sensors if you're swapping in the heads too.
You'll get the 257 gasket set, but if you're using one of the permutations that uses the ej205 cam gears, you need to pick up an extra set of the smaller ID cam seals. These are the same size as 05 exhaust cam seals or any year ej205 intake or exhaust seal.
If you're using a permutation with the ej257 AVCS cam gear, then what's in the ej257 set will obviously fit great.
Concillian is offline   Reply With Quote
Old 02-25-2010, 04:07 PM   #13
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
well ill be using aftermarket camshafts,and matching sti cam gears with the heads.
thanks for all the help though
Which gasket set for hybrid block swap? 240sxguy Built Motor Discussion 2 11-25-2009 02:52 PM
Gasket set, timing/water pump set EJ25D styng88 Private 'Wanted' Classifieds 1 08-22-2009 10:17 AM
What gasket set on a hybrid swap sgiord86 Built Motor Discussion 3 08-21-2009 05:18 PM
Hybrid gasket questions rpm_nick Built Motor Discussion 4 08-09-2007 03:58 PM
