Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-18-2010, 05:57 PM   #1
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Default The Un-biased Best Subarus in the Utah portion of RMIC
Originally Posted by Touge86
I think the only way we will know the best Subaru is to have the cars that want to be on the list do a 3 part competition.
1.Drag Race
2.Road racing at miller
3. We can have a car show and people can vote what looks best
Then see who gets the most pts.
I think this would be a great idea! An un-biased pick of what Utah deems as the Top 10 Best Subaru's.
All of those that want to participate Post up.
Edit: this is not a "penile" comparo thread. Again, it is JUST FOR FUN!!!
Edit #2: How this is going to work. Post if you want to be in the competition. Post Model/Year, Mods and photo's of said car. I will edit this main post for easy reference of those willing to participate. Pts will be based on 1/4 mile time/speed, Lap battle and overall car appearance/taste. We will work out a point system later, but for the time being...
Most pts for lap battle
second for 1/4 mile
3rd for cosmetic and overall taste.
Not current standings, just those committed below.
1. Stames (James)
2. bhhamblin (Brody)
3. Medamullet (Jason)
4. PCSKiBum_21 (Brendon)
5. Wantsti (Dylan)
6. r8r4life (Les F***bomb)
7. gsxrguy (J Carver)
8. Down2earthsubie (Lance)
9. Ninefourteener (Matt)
10. Kwinskii (Kwin)
11. Circuitlife86 (Eric)
12. Subie-King (Tyler)
13
14
15
16
17
18
19
20
Stames_wiltz is offline   Reply With Quote
Old 01-18-2010, 06:30 PM   #2
Stames_wiltz
Member#: 143264
2006 WRX TR
2007 Crystal Grey Metallic STi
Power
APS 70mm Cold Air intake
APS 3" inlet pipe
Forced Performance HTA Green
APS DR525 Front mount intercooler
Deatschwerks 850cc injectors
TGV Delete
Gizmo Thermal Gasket
Raw Performance Stage 2.5 Block
Custom CP 9.1:1 Pistons
Kelford 272/272 cams with 11.3MM lift
Mild head work and complete valve job
Cobb Inconel Up-pipe
Cobb Turbo Back exhaust
Cobb Pulley
Cobb APv2
Prodrive EBCS
Suspension and Brakes
BC inverted Coilovers
StopTech SS brake lines w/ Super blue brake fluid
Hawk HP+ pads
Cobb Front and rear Sways
Cusco Rear Tower brace
Misc.
Glowshift Guages
Oil Temp., Oil Pressure, Water temp., EGT, AFR, Volt
Cobb Urethane Exhaust Hangers
rally Armor flaps
ACT Heavy Duty Clutch
07 STi Limited lip
Cobb Radiator shroud
Cusco/custom Dual IC spray
BOOST!!!!!!
Old 01-18-2010, 06:33 PM   #3
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Here is mine.
2006 WRX
ENGINE:
Cosworth EJ25 long block w/ STD crankshaft. fully balanced and blueprinted
Cosworth 9.2:1 CR pistons
Cosworth rods
Cosworth main/rod bearings
Cosworth high pressure/ high volume oil pump
Cosworth big port cylinder heads
Cosworth 1mm over sized intake and exhaust valves
Cosworth shimless buckets
Cosworth CNC machined/ knife edged
Cosworth 278 intake cams
Cosworth 274 exhaust cams
Cosworth high RPM valve springs and retainers
Cosworth billet timing belt guide
APS TSR70 (GT35r) turbo kit
APS 3.5 inch turbo back exhaust
APS twin scroll exhaust manifold
APS exhaust manifold shielding
APS TGV deletes
APS 85mm rotated mount intake
APS top feed fuel rails
APS DR525 front mount inter cooler
Tial 44mm waste gate
Moroso aluminum oil pan/ pick-up (6 quarts)
JDM STi timing belt
Forge Evo BPV 100% recirc
Gizzmo intake manifold spacer gaskets
Air pump removed
AC removed
Denso 2 step colder spark plugs
Odyssey lightweight battery
Cobb tuning crank pulley
Crawford air/ oil seperator
Mobil 1 20w50 motor oil
FUELING:
Aeromotive fuel pressure regulator
Aeromotive fuel pressure gauge
Deatschwerks 1100cc injectors
SARD 5L fuel surge tank
2x Walbro 255lph fuel pumps (in surge tank)
Denso 280lph fuel pump (in gas tank)
Jegs -6 AN fuel lines
Jegs fuel filter and "Y" fitting
Earls -6 AN fittings
COOLING:
Koyo aluminum radiator
Setrab oil cooler
Mocal sandwich adapter w/ thermostat
Crucial Racing 160* thermostat
Full ducting to radiator/ oil cooler
Modified radiator support for more ducting/ airflow
STi high pressure cap
TRANSMISSION/ DRIVE TRAIN:
PPG 1-4 straight cut gear set
PPG billet shift forks
Cusco 1 way front LSD
Cusco 1.5 way rear LSD
Cusco solid engine mounts
Cusco solid transmission mount
Carbonetic 1300 twin plated clutch
Beatrush propeller shaft mounts
ARP extended wheel studs
Redline 75w90 lightweight shockproof gear oil
Redline friction modifier for front LSD
Kazz 80w90 for rear LSD
BRAKES/ SUSPENSION/ CHASSIS:
Stoptech 332mm brake kit
Stoptech SS front brake lines
Stoptech 2 piece slotted front rotors
OEM STi rear brembo brakes
DBA 4000 slotted rear rotors
Techna fit SS rear brake lines
Cusco master cylinder brace
RCE front brake ducts
Porterfield R4 front and rear brake pads
Removed front and rear dust shields
Tein monoflex coilovers 10k front 7k rear
Tein super racing rear camber plates
Hotchkis lateral links
Whiteline 24mm front sway bar/ stock rear
Whiteline steering rack bushings
Whiteline race anti lift kit
Whiteline rear end links
Whiteline rear sub frame lock bolts
TIC outrigger bushings
TIC rear cross member bushings
TIC rear differential bushings
Kartboy front and rear shifter bushings
Kartboy short shifter
Kartboy front end links
Kartboy exhaust hangers
GT Spec 14 point sub frame brace
Cusco rear chassis brace
Autopower 6 point bolt in roll cage
AERODYNAMICS/ EXTERIOR/ INTERIOR
APR GTC300 carbon spoiler
APR EVO X front carbon canards
APR splitter turnbuckles
ARC Honda civic front wind splitters
ARC alternator cover
CTS front splitter
OEM STi rear diffuser
OEM STi roof vane spoiler
Chargespeed carbon trunk
KS Tech hood scoop delete
Some radical stickers, dents, scratches, stitches
Nukabe infamous tow hooks
Sparco Pro200 driver/ passenger seat
Sparco slider on the passenger side (for comfort )
Sparco bases
Sparco 6 point harness (driver)
Sparco Prodrive edition steering wheel
Custom made by Phil shift knob and shift lever extender
STi door panels
Beatrush bulkhead division plate
Varis carbon exhaust shield
Rear gutted interior
Sound deadening removed
ELECTRONICS:
Defi boost gauge
Defi oil pressure gauge
Defi oil temp gauge
Defi water temp gauge
Defi EGT gauge
Defi link controller
Innovate wide band gauge
Apexi AVCR electronic boost controller + more
Apexi auto timer/ volts
Pioneer CD/Ipod player
WHEELS/ TIRES:
Work Emotion CR Kai 17x9 +44
Yokohama Advan 255-40-17
Toyo Proxis RA-1 255-40-17
Enkei RPF1 18x9.5 +38
Hoosier r6 275-35-18
POWER:
468whp 393tq on 97oct 25psi
Some pics (most recent that I have)
bhhamblin is offline   Reply With Quote
Old 01-18-2010, 06:36 PM   #4
ashergrey
Member#: 174533
0694 WRXLtd/LegWagon
WRB/Pure White
"Cosmetic" and "overall taste" are inherently subjective, meaning there's no such thing as an unbiased metric in that category.
ashergrey is offline   Reply With Quote
Old 01-18-2010, 06:38 PM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Damn brody, what DOESN'T your car have?
medamullet is offline   Reply With Quote
Old 01-18-2010, 06:42 PM   #6
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Some bushings, trailing arms, i think i could use some more gauges on the dash aslo... oh and 5x114
Old 01-18-2010, 06:55 PM   #7
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
2006 Steel (real) Grey Metallic STi
Power 312WHP 371WTQ (cobb's dyno)
APS 65mm Cold Air intake
APS 3" inlet pipe
VF39
20x7.5x4 BIG top mount intercooler PC tanks gloss white
830cc injectors
TGV Delete Powder coated 10% gloss black
8mm Grimmspeed phonelic Thermal Gasket
Grimmspeed EWG uppipe Ceramic Coated and heat wrapped
Tial 38mm WG
Grimmspeed ported stock collectors Ceramic coated and heat wrapped
Grimmspeed Crossoverpipe Ceramic coated and heat wrapped
APS 3" Turbo Back exhaust
Grimmspeed EBC
Grimmspeed MBC
RPF1 17x8 +45 DD wheels PC 100%gloss black
stock enkei PC gloss white
255 40R 17 NITTO 01 Track tires
CORN
Tanabe GF210 springs
DBA 2 piece front rotors
Hawk Blue pads
Whiteline 27mm Front Sway PC gloss white
Whiteline 22mm Rear Sway PC gloss white
Whiteline spherical front and rear endlinks.
Front and rear strut bars PC 10% gloss
H Brace PC 100% Gloss black
Misc.
Defi Boost Guages
Innovative LC-1 with Gauge
ATI column gauge pod
2 Custom Oil Catch Cans
Custom Airsplitter to fit huge TMIC
Custom CT Splitter
Gimmicks hood dampers
Old 01-18-2010, 07:00 PM   #8
Lil' Biggie
Member#: 93992
'06 EVO MR,
'89 240SX, '07 Yaris
No more gauges!!! Next you need to get a digital dash with data acquisition!
Lil' Biggie is offline   Reply With Quote
Old 01-18-2010, 07:07 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
biggie, I would love that. It has been on my list for 3 years now, I am no closer to buiying it than I was then
Old 01-18-2010, 07:16 PM   #10
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
James, are you thinking most points for the 3 lap battles, a specified day at RMR and a specified "car show" date?
That's how I was thinking it should go.
Old 01-18-2010, 10:21 PM   #11
Stames_wiltz
Member#: 143264
2006 WRX TR
I was thinking 1 lap battle day as those that may be interested would be more than likely to participate if it is only one time.
I am also thinking a test and tune day for the drag races. That way we get a guaranteed 5 passes and we can take our best one.
The "show" will be subjective to those rating it. We can't rate our own cars and we need to be honest with those cars that are running against ours.
Old 01-18-2010, 10:37 PM   #12
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
That sounds good. We should hold the show at a CnC or a TT where we will get a good turn out of people. The problem is people like brody will have to drive it. We should plan dates, mid to late summer then.
Old 01-18-2010, 11:00 PM   #13
SkiWrex
Member#: 142559
02 PSM Wagon VF39d
05 PSM Fozz 2.5xs
too poor to compete.
SkiWrex is offline   Reply With Quote
Old 01-18-2010, 11:18 PM   #14
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
the cost will be about 150 for the lap battle and 10 for the RMR. RMR midnight drags are that much, but I am not sure if the test and tune is as well.
Old 01-18-2010, 11:20 PM   #15
Stames_wiltz
Member#: 143264
2006 WRX TR
FYI Test and tune is $20. Midnights are $10, but you'll have a disadvantage as you won't get 5 runs.
Sounds good to me. For those actually racing, I was thinking of a point system. Obviously if you win you get the most points and if you suck you still get some pts. For example;
1. 15 pts
2. 12
3. 10
4. 8
5. 7
6. 6
7. 5
8. 4
9. 3
10. 2
Both the Drag and Miller have a possible 15 points. For show it will be based off of Cleanliness, Wow factor, etc... have 3 or so classes worth 5 pts in each class that people can circle for each car.
Total pts possible is 45 assuming you win both racing and get 5's all around on the "show." we tally the points and declare the top scoobs in Utah.
CnC or TT would be cool would be good for the "show". Depending on when the Mark miller park-n-cruise is, we might be able to do the final points and show then!?
Old 01-18-2010, 11:30 PM   #16
Touge86
Member#: 166498
2013 M3
Mint Green
This is what I am talking about!
Touge86 is offline   Reply With Quote
Old 01-18-2010, 11:48 PM   #17
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
hahahahahah i totally see this failing. but i really hope it goes through
801_STi is offline   Reply With Quote
Old 01-18-2010, 11:49 PM   #18
Touge86
Member#: 166498
2013 M3
Mint Green
^haha me too, but really lets get people in on this! I will come to the track and watch it all!
Old 01-18-2010, 11:55 PM   #19
Stames_wiltz
Member#: 143264
2006 WRX TR
If nobody signs up, then I guess we have our top 3
Seriously though, it is this kind of stuff that brings the car community together. Allows us to get to know each other and ultimately we will want to help each other out. Plus, we get to check out some cool cars in the process.
Old 01-19-2010, 12:01 AM   #20
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
What about the rareness(sp?) of the car, the uniquenss of the parts (everyone has a invidia dp, but who has a JIC DE-Type II full Ti cat back).
Its not the size of your parts list, but its also about how unique the parts are.
So what do i win?
To bad the STi is gone, would have cleaned house on the MMP alone
snowman4us is offline   Reply With Quote
Old 01-19-2010, 12:07 AM   #21
Stames_wiltz
Member#: 143264
2006 WRX TR
so what do I win?
You have a legacy now. You can still compete. Just because you would be fast at MMP doesn't mean you would win it all. I know several cars that were faster than yours at RMR.
The "car show" will have a uniqueness to it, not just money spent.
You win nothing but the respect of your fellow Utahn-RMIC members.
Old 01-19-2010, 12:09 AM   #22
tphskab
Member#: 114466
Bowl of
white rice
I dont need to compete in this to know I am still way cooler than all of you
tphskab is offline   Reply With Quote
Old 01-19-2010, 12:18 AM   #23
Lil' Biggie
Member#: 93992
'06 EVO MR,
My suggestion would be to make each test's value be more inline with all the attributes necessary to achieve good results. Ideally, a number of tests should be run to show all aspects of the car's build and performance. These would include 0-60 mph acceleration, 60-0 braking, 0-100-0 acceleration/braking, slalom, 1/4 mile, dyno results, MMP lap time and overall appearance.
Unfortunately, accurately performing all of these tests will be almost impossible. So instead, the tests that are readily available should be graded accordingly.
Time Attack(Acceleration, Handling and Braking) = 60%
Drag Race(Acceleration) = 20%
Car Show(Visual Aesthetics and Popularity Contest) = 20%
Old 01-19-2010, 12:20 AM   #24
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Unhappy
Fastest DD at the time , on slicks and on street tires. ( <--still living in the past )
Leggy is the dd. Got other cars for toys.
Mod list to small to win this competition
Old 01-19-2010, 12:24 AM   #25
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Originally Posted by Lil' Biggie View Post
Time Attack(Acceleration, Handling and Braking) = 50%
Drag Race(Acceleration) = 30%
My .02
And for time Attack, is that for DOT's or Race tires. As some ppl only run in the DOT class, how would that work out if they are lets say 4th overall but 1st in class?
Drag racing, is that on slicks or DOT's and also with pure 91 or with 91+meth/corn/C16?
MUST BUY FOR STAMES WILTZ or anyone else wanting to instantly winThe Un-biased Best! Subr-man Rocky Mountains Impreza Club Forum -- RMIC 19 03-04-2010 10:30 AM
Best price on subarus in the tristate area? Wheels Tri-State Area Forum 18 01-31-2005 06:22 AM
Gun Control: How would you feel if the UN decided its fate in the U.S. Opie Political Playground 26 11-28-2003 12:47 PM
