Old 01-20-2010, 10:06 PM   #1
trbo_blu
Member#: 233853
2007 Subaru WRX
Default 2007 WRX - Idle Air Control Valve?
I just picked up a 2007 WRX last week. The car does have 68K miles on it, but supposedly they are all highway miles. But anyways, at times during idle, it will drop down below 500 RPM and then surge up past 1200 or so RPM. It does it maybe once or twice a day randomly while sitting at a stop.
I did a search on idle issues and came across several posts recommending that the Idle Air Control Valve be taken off and cleaned as dirt and oil buildup can occur inside and cause idle issues. I was going to order a gasket to make sure I could replace it after taking off the valve.
However, I found a post which I can't find it now that someone had said the 07 didn't have a IACV. Its dark outside and I don't have a flashlight here at my apartment to go out and take a look to see if I see it or not. So my question is, was that a legitimate post or does the 07 WRX have a IACV?
If it does not, what other recommendations do you have? It hasn't thrown a code and doesn't do it that often. When does Subaru recommend a plug change? I thought about doing that this weekend while I am home because I'm sure they haven't been replaced yet and thought that might help. So to compound the thread, what spark plugs does everyone run in these cars? I'm accustomed to NGK in the past, but doesn't mean I have to use them. I run TR-6s in my GTO and haven't had any issues yet.
TIA!
trbo_blu is offline   Reply With Quote
Old 01-21-2010, 03:59 AM   #2
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
If it is drive-by-wire, then there isn't one.
CKxx is offline   Reply With Quote
Old 01-21-2010, 10:32 AM   #3
arghx7
Member#: 232940
does the car have any mods?
arghx7 is offline   Reply With Quote
Old 01-21-2010, 04:12 PM   #4
trbo_blu
Member#: 233853
2007 Subaru WRX
No, it is completely stock. It did have an HKS blow-off valve on at for an unspecified amount of time (it came with the car).
And today I confirmed it is DBW and doesn't have an IACV...but still something is going on with the idling that I need to figure out. Its not something that is very frequent yet, but I'd still like to find the problem and fix it.
Old 01-22-2010, 02:12 AM   #5
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
Try cleaning the Mass Airflow Sensor first (and make sure the plug contacts are tight), and if you're up to it, pull the I/C off, and clean the gunk off the throttle body/ plate as well. Do a reset, allow a few key cycles to do a relearn, and (hopefully) all should be well. Also check to make sure all your vacuum lines are intact/ secure, as that willl cause it to 'hunt' at idle as well.
As for the plugs, if the car is still stock, or even with minimal mods (intake, etc.), stick with the NGK's; There's no need to start mucking about with heat ranges/ materials until you get into heavier mods. I have found however with my own car, it does wonders for driveability to actually close the gap a few thousandths, iirc spec is .035, mine are set at .032. Because of the crappy stock tune, the 06-07's tend to literally 'blow out' the spark under high boost/ hard acceleration, and it seems to make cruising much smoother. The recommended interval is 60K; if you are daring enough to try and change them yourself, be especially wary of #4 (driver's side, rear)...I've been there, broke that, while trying to tighten it
thunder_lizard_1976 is offline   Reply With Quote
Old 03-25-2010, 08:41 PM   #6
IH8PVMNT
Member#: 178254
2006 Wrx Limited BUG
2006 Wrx Limited Wagon
TIA!
haveing the same problem!!! surge in idle is drving me crazy, also have a 06 wrx.... did you find anything ?
IH8PVMNT is offline   Reply With Quote
Old 03-25-2010, 08:51 PM   #7
fast06wrxtr
Member#: 206590
TIA!
This sounds like what my car does after I reset the ECU. If the battery was pulled recently, it will do it for a hundred miles or so until the computer learns a bit.
fast06wrxtr is offline   Reply With Quote
WTB: Idle Air Control Valve IACV 02-05 wrx fastwec Private 'Wanted' Classifieds 0 09-07-2007 10:12 AM
wtb Idle air control valve for 02 wrx M.R.blue Private 'Wanted' Classifieds 0 08-23-2007 12:46 AM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
