Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 01-20-2010, 10:43 PM   #1
McRussellPants
Member#: 234144
Default Drift STi Build: Cut Knuckles Post 179
Hey Guys, so heres my old car. I drove it all year in D1GP USA, finished 7th, it was cool. its done me well.
http://motormavens.com/2010/01/carsp...ker-texas-s13/
So, chanced on to a GDB shell for cheap, pretty sure it was an 04 STi at one point. and I'm building this car to bring the heat.
480ish RWHP
460ish Tq
350Z Gearbox
Z32 Differential
17x9.5+30 Front 18x10+25 Rear with 255/275 stagger
Cage when it just got back from install.
Fender Tubs, which are cut up trailer fenders, work so perfect for 60$
Roll Cage/Interior After Paint, ABM from the 10+ Camaro
Surge Tank setup, still need to clean it up with the wire wheel, but started fabbing the hardlines (shoot me in the face). Aeromotive Filter to a Bosch 044 Inline. we've done up to 650 or so on a single 044 through Porsches -4 fuel line so I don't think I'll have any issues with a single pump. Wish I still had my fuel rail insulator stash from the SR/KA, those would be really good for mounting it with some isolation.
Fuel Sender: Walbro 255 in the cradle, AQP socketless hose to a bulkhead fitting, the Return is a -6 welded on top of the stock return so that the OE fuel crossover siphon should still work.
Bill got me some pics of things I should be doing to Diff front support, so that's taken care of, besides waiting on some fancy Stance Solid Bushings and the cutting to get the R200 to bolt up to it.
Then on the rear sub-frame I knocked out all the eccentric bolt holders and welded washers over the slot, those things always ended up slipping on the 240SX and I hate them. None of the photos of what I did to fit the diff came out well, but I basically just enlarged the area that the 5H R200 Stubs fit into and then reinforced it onto itself.
Then I got some ARP Ben Hurr chopper studs pressed into the front, they're like 3.5in long with quick starts. I was about to just go ahead and cut the steering arm but decided to hold off until the car was rolling.
McRussellPants is offline   Reply With Quote
Old 01-20-2010, 10:44 PM   #2
McRussellPants
Member#: 234144
SPL Parts Prototype Lateral Links.
How to make a 350Z gearbox work on an EJ257
Hooker Harnesses came in the mail a few days ago.
Other Points of Interest:
I'll be using Driveshaft Shop level 5 axles. the big kids ones with the 930 CV Joints custom made to adapt to the R200.
I'm trying to spec out a small housing 35R, Im used to a 30R on a 2.0L in the 240SX, so I figure a E-Cover .63 Housing 35R should spool about the same.
I'm working with Warren from Sparco about getting some Circuit Pro's in there, good seat for people with birth giving hips like me.
Picking up the motor this weekend and it'll go straight to the builder to get some Mahle Pistons and Eagle Rods and all the other goodies for a stable 480whp.
So Far Sponsors Include:
Stance USA: Mike at Stance has been nice enough to supply a set of GR+3s for the car. Hopefully they'll be here soon, as they're in the process of custom building them specifically for my needs.
Hooker Harness: Scott at Hooker sent me those two beauties you see there. I won't ever buy anything other than Hooker, just because the quality and options ruins everyone else's, for a price that's competitive with the Euro 4 Point Harnesses.
SPL Parts: Kuah is in the process of producing Lateral Links, Trailing Links and Adjustable tie rod ends that will be available, I've used them for years on my 240SX and wouldn't trust anything else on the Subaru.
Old 01-20-2010, 10:45 PM   #3
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Subscribed!
Cusson is offline   Reply With Quote
Old 01-20-2010, 10:49 PM   #4
mpsti05
Member#: 86741
05 STi.. Built
twinscroll35r Love/Hate
ohhhh cant wait to see the final product, Best of luck!
mpsti05 is offline   Reply With Quote
Old 01-20-2010, 10:52 PM   #5
NickDHdfc
Member#: 203250
2011 Bmw 135i
Alpine White
ohhh gooodness...subscribed!!!!
NickDHdfc is offline   Reply With Quote
Old 01-20-2010, 10:58 PM   #6
itsmyturn
Member#: 225554
1999 Impreza 2.5WRSX
omg subscribed i remember seeing you and your car at D1GP in Miami....
why are you using a 350Z tranny and a z32 diff?
itsmyturn is offline   Reply With Quote
Old 01-20-2010, 11:03 PM   #7
McRussellPants
Member#: 234144
I can get 350Z transmissions for free, so even if I spend 3500$ making it work, I can break it as many times as I want and still come out cheaper than the non DCCD Legacy Spec B trans I'd have to buy otherwise.
The R200 is alot stronger than the R180, and even the R200 is kinda at its limits for the power I want to run. so I figured I'd throw it in from the get go.
Old 01-20-2010, 11:24 PM   #8
constantino7491
Member#: 187358
08 BMW 328
subscribed, sick build btw
constantino7491 is offline   Reply With Quote
Old 01-20-2010, 11:31 PM   #9
grippy monkey
Member#: 131067
your "stance"
sucks
The S13 was sick. I'm excited to see your STI complete! please keep us posted!
grippy monkey is offline   Reply With Quote
Old 01-25-2010, 08:46 AM   #10
itsmyturn
Member#: 225554
oh ok makes sense...GL
Old 01-25-2010, 08:51 AM   #11
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
I LOVE MCRUSSELLPANTS!
Long time no see buddy!
FriedIceCream is offline   Reply With Quote
Old 01-25-2010, 11:27 AM   #12
captain spaulding
Member#: 104639
'06 WRX Wagon
Red
BadA$$!
captain spaulding is offline   Reply With Quote
Old 01-25-2010, 11:28 AM   #13
White out
Member#: 46277
** LP640
996TT
very cool build.
Nick
White out is offline   Reply With Quote
Old 01-25-2010, 11:32 AM   #14
hayate_gekko
Member#: 148837
subscribed. Interesting build. Looking forward to the finished product.
hayate_gekko is offline   Reply With Quote
Old 01-25-2010, 11:38 AM   #15
minhha2006
Member#: 154914
2005 WRX
UGM
subscribed!
minhha2006 is offline   Reply With Quote
Old 01-25-2010, 11:50 AM   #16
themarxist
Member#: 104555
1996 VW Passat Wagon
TDi White
Cool stuff, but those bent x-brace members and the cold, goopy welds on the cage are really bothering me.
themarxist is offline   Reply With Quote
Old 01-25-2010, 11:58 AM   #17
racer555
Member#: 98895
2013 Frs
Raven black
Nice start on your drift build. Hope you let us know how you chop up the spindles for steering angle and how that affects other areas of your alignment (like ackerman and stuff) since I am getting ready to do mine on my bugeye. Have you ever driven a rwd scuby before? Just curious cause the handling is waaaaaay different from a 240, at least it seemed that way to me when I started drfting in my wrx. Maybe its just my alignment and suspension setting and stuff but our cars seem to push harder into corners and are more prone to a snap oversteer. Then again my car is way too low to the ground so that could be part of my problem Good luck with this thing and keep us updated!!!
Subscribed
racer555 is offline   Reply With Quote
Old 01-25-2010, 12:13 PM   #18
Sato_unit
Member#: 230417
YEAAH RUSSELL!!!! this **** is gonna be beast!
this is abbitt by the way. haha
Sato_unit is offline   Reply With Quote
Old 01-25-2010, 12:30 PM   #19
McRussellPants
Member#: 234144
I kinda dig the door bar style.
But I know what you mean on the welding, That's probably the worst section though, The rear section and main 6pt structure of the cage look alot better.
Doors got painted last night
Engine/Rack/Column/Dashboard/Console are all sitting in the garage now. hopefully it'll be fully painted by Feb 1st.
Old 01-25-2010, 12:30 PM   #20
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
sick build
shadowmd is offline   Reply With Quote
Old 01-25-2010, 01:04 PM   #21
dub c
Member#: 145069
Keep It Sleazy
well this is a sick build.
i will be checking in periodically haha.
coupe > sedan gc style chassis though if your doing a full build like this...IMO.
dub c is offline   Reply With Quote
Old 01-25-2010, 01:08 PM   #22
strungoutt
Member#: 37353
i am a fan of your work.
strungoutt is offline   Reply With Quote
Old 01-25-2010, 01:11 PM   #23
bnguyen
Member#: 172714
'06 LGT
built goodies
Sick build! I've seen your S13 many times out in Mineral Wells, can't wait to see this!
bnguyen is offline   Reply With Quote
Old 01-25-2010, 01:18 PM   #24
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
holy crap.
subscribed
blakkboxer is online now   Reply With Quote
Old 01-25-2010, 01:51 PM   #25
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
oh wow. Props! This is going to be ridiculous
D Money is offline   Reply With Quote
Samuel Hubinette's Still-Born Mopar Challenger 850hp Formula Drift Car xknowonex Member's Car Gallery 50 12-25-2009 05:50 PM
Formula Drift Car Show THIS WEEKEND Las Vegas krnkimche2 Southern California Impreza Club Forum -- SCIC 7 07-07-2009 07:30 PM
Gruppe-S/ Hankook Tires 2008 Formula Drift Cars Gruppe-S Member's Car Gallery 23 07-25-2008 02:43 PM
Hou: Formula D Drift / Car Show - June 11th, ...who's going? glilly Texas Impreza Club Forum -- TXIC 40 06-11-2005 03:00 AM
Formula D Drift boricuajr Tri-State Area Forum 4 03-23-2005 06:03 PM
