Old 01-21-2010, 10:21 AM   #1
stitchbad
Member#: 177527
2004 STI
Default 04-06 STI short block= 08 STI short block
I've been trying to find out if the 08STI short block is the same as the 04-06 STI short block but I haven't found anything. So does anybody know if they are or what the diffrence is between them. Any info would great.
Thanks
stitchbad is offline   Reply With Quote
Old 01-21-2010, 11:47 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The short block casting, or the full assembly? As far as I know the casting is the same, but the full assembly isn't. I believe the pistons and rods are the same, the crank is nitrided (or was that the 09? I forget), and the oil pump is larger for the dual AVCS.
Old 01-21-2010, 12:34 PM   #3
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
i think the nitrided crank started in 09.
Danomite is offline   Reply With Quote
Old 01-21-2010, 01:35 PM   #4
stitchbad
Member#: 177527
2004 STI
Complete short block, I'm building a new motor for 04 STI and want know if the 08 block will work and if there's an advantage to using it.
Old 01-21-2010, 02:25 PM   #5
Danomite
Member#: 190449
it will work fine but at least do some drop in pistons.
know what i'm sayin.
Old 01-21-2010, 02:36 PM   #6
Prevent
Member#: 149114
09 sti block cylinder walls a slightly thicker.. I think by 1mm.
When i measured 04-07 it was about 9mm thick, 09 i thnk is 10mm. (should have wrote this **** down)
obviously as above 09 crank is nitrided because subaru either stopped or decreased using lead in some bearings (environmental speel)
Prevent is offline   Reply With Quote
Old 01-21-2010, 02:40 PM   #7
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Subaru also changed the casting process in 2007. Went from the 702 to the 703.
The 703 Castings are allot smoother inside the passages, making them more efficient to fluid flow internally.
RallySport Direct is offline   Reply With Quote
Old 01-21-2010, 03:39 PM   #8
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
also you will have to decide on which oil pump to use because it does not come on a new shortblock.
john 1badSTI is offline   Reply With Quote
Old 01-21-2010, 03:40 PM   #9
stitchbad
Member#: 177527
2004 STI
So then the 08 sti block will work in any 04 sti with 04 sti heads.
Old 01-21-2010, 03:49 PM   #10
john 1badSTI
Member#: 77470
yes it will work fine
Old 01-22-2010, 06:08 AM   #11
AlexTRD
Member#: 135627
2005 WRX td06-20g
ej207/02 wrx/s4/C32 AMG
+1 on the 07+ motors having smoother castings. They is a very noticeable difference when comparing to older motors, much less burrs and sharp little edges. Theoretically those things can lead to the beginning of a stress spot, and are often where failures/breakage happens if it does.
AlexTRD is offline   Reply With Quote
Old 01-22-2010, 10:43 AM   #12
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Oh really, Interesting?
rexworx is offline   Reply With Quote
Old 01-22-2010, 10:49 AM   #13
rexworx
Member#: 103232
GTX 3071R'd 11WRX
Edit: Bad info on my part sorry...
Old 01-22-2010, 10:52 AM   #14
Member#: 51961
2005 STi
2012 WRX
07+ 2.5 turbo blocks also have two crankcase breather ports. The primary one next to the turbo for the PCV system, and a second on the block is below the throttlebody.
As I understand the 04-06 only has the primary PCV breather.
Edit: opps double post...
All of them have the 2nd breather, it's just the 2.0 that only has one.
Old 01-22-2010, 11:21 AM   #15
rexworx
Member#: 103232
GTX 3071R'd 11WRX
They do? Well Im a dumbass sorry...
07 STi Limited or 08 STi? Manvir General Community 67 08-22-2009 10:23 PM
WTB: Spearco STI Tmic or 08+ STI stock Tmic unclemat Private 'Wanted' Classifieds 3 03-04-2009 05:03 PM
trading in my 06 wrx for an 08 sti? DCsubieSTI Newbies & FAQs 16 01-13-2009 07:18 PM
Can you swap 07 sti seats with 08 sti seats? subaru110 Interior & Exterior Modification 5 07-18-2008 02:08 AM
AP V2 for 04-06 2.5l and 07 STI V8This Engine/Power/Exhaust 3 11-15-2007 10:24 PM
