![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 218280
NESIC
Vehicle:2002 WRX Wagon Blue |
I recently went to sears in the Berkshire mall in Lanesboro Mass, to have my snows put on my stock wheels, and they stripped one of my driver side rear wheel studs, couple days later my buddy went there with his sti, same exact thing happened, somebody out to get us? or do they just suck? I know wheel studs are a bitch to get out on WRX's and STi's. Any advise? Has this happen to you?
Is it safe to run only 4 lugs instead of 5?
#2 |
Member#: 139955
NESIC
Vehicle:# OneBoston |
Sears sucks.
Wheel studs arent horrible to do. While it isnt the end of the world, I wouldnt run 4 lugs, either. |
#3 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
overtorque FTMFL
#4 |
Member#: 235910
NESIC
Vehicle:1999 2.5 RS blue |
I've stripped a wheel stud before.... it sucks.
But why can't they just fix it? |
#5 |
Member#: 128115
South East
Vehicle:2004 4EAT Wagon PSM enginuity is cool |
Ummm. The wheel studs take about 10 minutes to get out.
1) Jack up car 2) Remove wheel 3)Remove brake caliper and rotor 4) Hammer out old stud from hub 5) Replace wheel stud 6) Use large deep socket and lug nut (maybe a couple of washers too) to pull stud into place in hub. 7) Replace rotor, caliper, then wheel all done. You can buy studs at Autozone. |
#6 |
Member#: 218280
NESIC
#7 | |
Member#: 218280
NESIC
#8 |
Member#: 129231
Vehicle:2005 wrx cgm |
there is not enough room to just punch out the stud on our cars, you have to remove the hub. And btw, when you remove the hub the bearing just falls aparts, so you need to change the bearing as well. have fun.
#9 | |
Member#: 16200
no....no you dont have to remove the hub you just have to know what the **** you are doing |
#10 |
Member#: 218280
NESIC
going to sears tomorrow to complain, cant wait
#11 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
wheel bearing doesn't just die when you remove the knuckle.
#12 |
Member#: 235910
NESIC
#13 |
Member#: 218280
NESIC
I don't want to do any of the work or pay to fix it because i did nothing to strip it. At the time i didn't think much of it, just replace it myself or something, i didn't know it would be as complicated as it turned out to be.
#14 |
Member#: 229023
BAIC
Vehicle:06 STi obp |
exactly.turn the rotor until theres room behind the stud,hit with BMF hammer,insert new stud.now for the love of god dont use your lugs to seat the stud.find fender washers and a nut to do this.if you have been seating it with your lug nuts it is your fault.
#15 | |
Member#: 229023
BAIC
just man up and handle it and never go back to sears |
#16 |
Member#: 44034
NESIC
Vehicle:2006 Global Cooler Black |
yes as many said. Wheel stud installation is easy. I have damaged studs and installed extend-o studs and it did not take long except for the rear. Those I had to remove the hub but only because they were ARP and are reallly long.
STI or WRX is the same story. |
#17 | |
Member#: 218280
NESIC
#18 | |
Member#: 229023
BAIC
fyi-replaced mine in a total of 30 minutes.that included running to kragen for the stud,jacking up the car,removing wheel,clocking hub,1 wack with the BMF and R&R stud,wheel back on and car on the ground. stop listening to the assclowns at sears.they want your money.maybe you should go back with your mommy and have her yell at them to fix your car or go to kragen)here you go- http://www.kragen.com/ProductDetail....pe=183&PTSet=A i know the next part is a stretch but you can jack up your car and remove the wheel correct. ok,so do that and spin the hub around until the bad stud is were the open area is.using manly arms hit it once(if you have girl arms you may need to hit it more than once) wiggle it out of place and slide the new one in.using flat washers and a nut suck it down nice and tight so it seats correctly.tada,fixed. Last edited by subynation; 01-23-2010 at 10:26 PM. Reason: the OP needs extra special help-short bus help |
#19 |
Member#: 90539
South East
Vehicle:95 L with ej20k powa, Raven R6 |
Sometimes the studs just wear to a point that allows a bad pattern to start and they crossthread, its not always from over torquing. I recently had to remove a broken stud that crossthreaded when a friend was taking the wheel off. I torqued the remaining four correctly when putting the wheel back on, and when I got the new stud to replace the broken one... another broke lol. Good thing I bought several. I tried removing the abs ring screws to allow the stud to clear and it would not work no matter which way I spun the ring or the hub. Since my car has no abs, I just cut the ring and pulled it out. My rear hubs are from an abs equipped impreza.
#20 |
Member#: 144906
sears is a joke.....i went there to get new tires and they put one tire on backwards!!!!!they suck!!!!
#21 | |
Member#: 78952
Vehicle:2005 WRX CGM |
Fronts are easy, rears are not nearly at simple. |
#22 |
Member#: 90539
South East
Exactly /\
#23 |
Member#: 229023
BAIC
#24 |
Member#: 60894
Vehicle:2004 WRX WR blue |
honestly....its not that hard....we literally took off the wheel....caliper...and wheel studs (3 to be exact) on MY04 WRX in about 30min (to get everything off) ....all you need is the studs....a deadblow hammer...and the proper wrenches to get the wheels and calipers off of the car...do the reverse...and shazaaam back in driving condition...although i do understand on STIs its all lil more tedious considering you have to deal with ABS sensors
#25 |
Member#: 168857
SCIC
Vehicle:05 WRX STi PSM |
Cant wait to see the video! I ended up with this problem today too
the tire shop broke the rear stud :/ Im running 4 for now until Wednesday (2 days from now) |
| Thread Tools | |
| Display Modes | |
| Stripped my wheel lock - need help! | stryfewrx | Tri-State Area Forum | 23 | 04-08-2006 12:02 AM |
| Quick help on replacing stripped wheel stud | Cabal | Tire & Wheel | 8 | 08-08-2005 07:35 PM |
| Stripped Wheel Stud, Where to go? | S-1 | Mid Atlantic Impreza Club -- MAIC | 6 | 04-08-2004 01:07 PM |
| stripped rear wheel stud problems | eastbaysubaru | Service & Maintenance | 7 | 08-16-2002 01:52 PM |
| Help! Stripped a wheel stud. How hard is it to replace? | all4wheels | Brakes, Steering & Suspension | 4 | 05-31-2002 08:30 AM |
