Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Closed Thread
Old 01-21-2010, 11:01 PM   #1
MAtwal
Member#: 125053
2004 Wrx Sedan
Default will 04 sti sway bars fit 04 wrx and is it considered an "upgrade"
Hey guys, im looking for a quick answer as im going tomorrow to buy some wrx parts and the seller also has an 04 sti sway bar (front and back) available. Ive looked for the answer to see if this will fit but I cant seem to find it clearly so I ask....
Will an 04 stil sway bar fit onto an 04 wrx and will this be an improvement. Are the sti sway bars thicker?
thanks guys.
MAtwal is offline
Old 01-22-2010, 12:06 AM   #2
MAtwal
Member#: 125053
2004 Wrx Sedan
Default found thread
Ok so I gots some time away from my kids right now and I found this thread
The "Will this suspension part fit my car?" thread. Im still not clear if the front and rear 04 sti sway bars will fit right onto my 04 wrx.
this is under the 04 wrx section
"Swaybars and Swaybar mounts/bushings
All rear swaybars for any 02-07 RS and WRX will fit. STi rear swaybars will mount on the outside of the endlinks and their effectiveness is reduced.
04+ RS, WRX, and STi rear swaybar bushings will not fit 02-03 swaybar mounts.
04+ RS, WRX, and STi rear swaybar mounts will fit are an upgrade but require 04+ swaybar bushings.
Front swaybars for 02-07 WRX will fit, except on RS models. Wagons are different, see notes below.
02-07 Impreza RS require a specific sway bar to clear the non-turbo headers. WRX and STi front swaybars will not fit an RS."
ok so by how much is the sti rear sway bar effectiveness reduced. Also its not noted on here weather the front 04 sti swaybar will bolt onto the 04 wrx
MAtwal is offline
Closed Thread
Will an 04 STI Intake Manifold fit 03 wrx EJ205? simon930 Built Motor Discussion 7 12-03-2009 10:23 PM
factory 04 STi sway bars front ant rear and spring qban32 Suspension/Brakes/Handling 0 03-22-2007 11:23 PM
02-03 sway bars fit 04-05 wrx? litlechina Brakes, Steering & Suspension 13 12-25-2005 05:20 PM
How do i make 04 STi sway bar fit a 04 WRX?? WRXakaBooSTi Brakes, Steering & Suspension 7 05-26-2005 03:27 PM
Will 04 STi strut bar fit GC8s? afstevie68 Brakes, Steering & Suspension 2 01-24-2005 02:05 PM
