Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 01-22-2010, 02:16 PM   #1
deadscooby
Member#: 167811
2005 Impreza WRB STI
Goldies, EWG & HTA Green
Default FP HTA Green 362WHP/360WTQ
Hey, just wanted to share my cars recent numbers she put down after making some modifications. Took a while to pull it all together but she's finally finished and I'm really happy with her. Robbie did a great job at Epic Motorsports in Fayetteville NC. The car runs awesome!
Car: 2005 Subaru WRX STI with 120,000 miles!
Tuner: Robbie @ Epic Motorsports in Fayetteville NC
Dyno Info: Mustang
Peak HP at RPM: 362.7 whp @ 5695 rpm
Peak WTQ at RPM: 360.4 wtq @ 4828 rpm
Baseline HP for a stock: 220-230 whp
Target Boost: 22 psi
Target AFR: 11:1
Fuel: 93
Engine/Power Modifications:
FP HTA Green pnp'd with 3" inlet
Tial 38mm EWG with uppipe (IAG)
APS DR725 FMIC
DW 850 CC injectors
Walbro 255 FP
TGV deletes
APS 70mm CAI
APS Turbo Inlet
Grimmspeed EBCS
Cobb AccessPort v2
Invidia Catless downpipe
Invidia Catback
Grimmspeed light weight crank pulley
deadscooby is offline   Reply With Quote
Old 01-22-2010, 02:24 PM   #2
fourmicah
Member#: 128760
2012 Ruckus/WRX
Red&White/Gray
Nice set up! I had almost the exact same thing on my 06 TR and loved it. The only difference was I had a Blouch Dom 3. Have fun with it.
fourmicah is offline   Reply With Quote
Old 01-22-2010, 02:27 PM   #3
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I would think you could get more from HTA Green and 2.5L.
They did almost the same horsepower on a 2.0L with an HTA68..
EDIT they made more hp: http://forums.nasioc.com/forums/show....php?t=1829283
djerickd is offline   Reply With Quote
Old 01-22-2010, 02:35 PM   #4
deadscooby
Member#: 167811
The WRX in this thread put down 224 WHP and 254 WTQ stock on the dyno they used in comparison to a stock STI on the Mustang dyno which puts down 220-230. Not sure what a stock WRX would put down on Robbie's Mustang Dyno at Epic Motorsports, but I'm pretty sure it would be well under 220WHP
Old 01-22-2010, 02:43 PM   #5
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
That must be a really low reading dyno.
Nice set up.
godforbid67 is offline   Reply With Quote
Old 01-22-2010, 03:43 PM   #6
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Nice set up.
35R on pump make something like 400whp
Old 01-22-2010, 07:17 PM   #7
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Those are great gains!! I'm sure it's a beast!
I've always been a fan of the green's and this thread gives me another reason Was this on the 8cm hotside?
fastwrx006 is offline   Reply With Quote
Old 01-22-2010, 08:13 PM   #8
nolag05
Member#: 146419
2005 Subaru WRX STi
World Rally Blue
thats a nice setup bro! that 725 is a monsterous fmic for the green! are you planning on upgrading the turbo? any hoot... still a got setup!
nolag05 is offline   Reply With Quote
Old 01-22-2010, 08:39 PM   #9
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
hey i am trying to compare a hta68 and green for which one i want to run in the future.
what rpm does the green spool at and when you get on it to see when it spools what rpm are you getting on it at.
i would appreciate this info so i can chose a new turbo correctly cause i autox my car
bswilmington is offline   Reply With Quote
Old 01-22-2010, 08:50 PM   #10
MattPersman
Member#: 139385
nice 360 whp on a mustang on pump is good stuff
MattPersman is offline   Reply With Quote
Old 01-22-2010, 10:23 PM   #11
deadscooby
Member#: 167811
Yeah it is. It's also been ceramic coated black and red. It's a sweet turbo!
Old 01-22-2010, 10:26 PM   #12
deadscooby
Member#: 167811
Loads of people have told me that the FMIC is overkill for almost every turbo, but in all honesty there's little to no lag at all and I picked it up for a really good price! Just need a tuner who knows what they're doing and you're good to go! If I ever do go bigger, then at least i know I have pretty much everything I need to drop that bad boy right in there!
Old 01-22-2010, 10:33 PM   #13
deadscooby
Member#: 167811
The Green spools up much earlier than we though it would do. Looking at the dyno graph, she seems to really kick in at around 3200-3500rpm and keeps building up to between 4700 and 5200rpm where she holds out pretty much to red line.
I've read some good reviews on the HTA 68, but this Green produces much more power, and I'm told it'll reach it's sweet spot between 25 and 27psi. I'm only running on 22 max as I have a stock block.
I use my car for auto-x too and can't wait to get her out there and see what she can run. I just added some Whiteline 24mm front/rear sway bars too to help out a little more!
Good luck with whatever you decide to do
Old 01-22-2010, 10:34 PM   #14
Mooneyes13
Member#: 113666
60' all over you
numbers look pretty solid. the curve looks typical for a 20g. should put this car into the 11's no prob as long as their is a driver mod and not a TON of weight in the car
Mooneyes13 is offline   Reply With Quote
Old 01-22-2010, 10:39 PM   #15
deadscooby
Member#: 167811
Not too sure my drag experience will get her in the 11's quite yet. I only took her out once before when she was stock and that was over 3 years ago!
Only weight in the back will be my sons car seat! Minus my son of course
Old 01-23-2010, 12:02 AM   #16
subynation
Member#: 229023
06 STi
obp
those are great numbers for a 120k motor.did you do a pressure and leak down before hand?
subynation is offline   Reply With Quote
Old 01-23-2010, 07:43 AM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Nice set up.
How much do people expect pump gas turbos to make now days?
I remember when anything ~350whp was almost unbelievable.
Heres one of the pulls i got from my HTA Green on the sti. I had to run 2psi and 3* of timing more to hit these numbers on the OG Green
Old 01-23-2010, 08:35 AM   #18
deadscooby
Member#: 167811
Sure have done, no problems at all. I do have to say that I don't drive the car like i stole it. I do plan to put a built block in there next summer though.
Old 01-23-2010, 08:47 AM   #19
wjfawb0
Member#: 122526
05 Subaru STI
Very nice. Enjoy it, and have fun.
wjfawb0 is offline   Reply With Quote
Old 01-23-2010, 09:39 AM   #20
bswilmington
Member#: 217563
YEAH I HATE TO SAY IT BUT I THINK THAT TURBO IS GOING TO BE A BIT TO LAGGY FOR AUTOX, BUT THAT IS MY 0PTION.
THE VF39 CAN BE A LITTLE BIT LAGGY AT AUTOX'S AROUND HERE WHEN WE HAVE TIGHT TRACKS
THATS JUST MY .02
WHEN DO YOU RUN YOUR FIRST AUTOX FOR THE SEASON? WHEN YOU DO POST BACK HOW IT FEELS COMPARED TO STOCK TURBO
Old 01-23-2010, 09:41 AM   #21
bswilmington
Member#: 217563
Oh Yeah What Area Do You Autox In?
Old 01-23-2010, 10:46 AM   #22
SVT_WRX
Member#: 164830
G61 III OVE 58e
That's a higher reading dyno bud.
For the record, Dyno Dynamics is the LOWEST reading dyno out there. I'm guessing it would put down 333 on DD. Mustang dyno is right above DD. Those are some great numbers on a Mustang dyno. On a Dyno Jet, he would probably be in the range of 400-414.
If you ever get bored of all that power, look into getting a Cosworth intake manifold!
SVT_WRX is offline   Reply With Quote
Old 01-23-2010, 11:25 AM   #23
deadscooby
Member#: 167811
I usually run with the Triad Sports Car Club. Don't get chance to do it much because I coach soccer for a living and from feb through Nov my weekends are packed out with soccer.
I'll let you know how i do though once i get out there
Old 01-23-2010, 11:26 AM   #24
deadscooby
Member#: 167811
That'll be next thing on the shopping list along with a Header and built block............ I;m happy with it right now but it seems like you always wanna go faster! it's like a disease!
Old 01-23-2010, 11:51 AM   #25
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
THATS JUST MY .02
I believe you have found your Billy Mays key sir.
cucamelsmd15 is offline   Reply With Quote
FS: (WI) FP hta green MX3ze@7psi Engine/Power/Exhaust 6 06-17-2010 03:09 PM
FS: PA - FP HTA Green - 3" Inlet 8cm Hotside w/ Extras Mycues1982 Engine/Power/Exhaust 7 11-17-2009 10:05 AM
FS: Feeler: PA , FP HTA Green 3" Anti-Surge 8cm^2 EWG Turbo < 500 miles Merp Engine/Power/Exhaust 26 05-13-2009 07:51 PM
FP HTA Green tested. AZScoobie Proven Power Bragging 216 11-10-2008 02:00 PM
FS: PA - FP HTA Green 3" inlet Mycues1982 Engine/Power/Exhaust 32 09-24-2008 03:41 PM
