Old 01-22-2010, 09:32 PM   #1
miked001
Member#: 91980
2005 WRX STi
Default Datalog
Attempted my first datalog today, had the access port ready to log, pushed the button to start logging and did a 3rd gear pull to 6500 rpm. I then shifted to 4th and let the car slow down, then pushed the button to stop logging. When I downloaded the log, it only shows 3 seconds worth of data. Am I missing something?
miked001 is offline   Reply With Quote
Old 01-23-2010, 11:02 AM   #2
Praet0rian
Member#: 175172
2006 STI
AW
This thread looks like your problem, there's a bunch of us having the same issue:
http://forums.nasioc.com/forums/show....php?t=1880592
Praet0rian is offline   Reply With Quote
Old 01-23-2010, 12:31 PM   #3
miked001
Member#: 91980
2005 WRX STi
I'm not losing the connection.
Old 01-25-2010, 05:32 PM   #4
Cobb Tuning
Member#: 4803
There are several different reasons why this happens. The first is that your AccessPORT may be physically losing connection, even though it is still plugged into the port. You can unclip the port from the dash and then tape/rubber band, the dongle to the OBD port.
The second issue can be electronic noise. You can get barrel magnets from radio shack that will cancel noise from the cable that can cause connectivity issues.
If this does not work, you have updated your AccessPORT etc, then we can try replacing the dongle. I take it this is a dongle-style AccessPORT with the silver and red OBDII port?
Travis
COBB Tuning
datalogging, can someone help me? datdudedennis Texas Impreza Club Forum -- TXIC 4 09-17-2002 12:03 AM
datalogging a '94L/EJ20 swap? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-18-2002 04:50 AM
Obd-2.com scanner and datalogging? gossamer_monster New England Impreza Club Forum -- NESIC 2 04-23-2002 11:41 AM
Datalogging and Fuel Control Crzykdd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-19-2002 03:25 AM
('93-'01) If I do an ECU reset will it erase the datalogging? aarneson Impreza Forum 7 06-26-2001 10:47 PM
