Old 01-23-2010, 01:02 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Rear Diff axle seal ... is this normal?
Both sides look like this so I was wondering if it's good?
Bad Noodle is offline   Reply With Quote
Old 01-23-2010, 01:04 PM   #2
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Its look like that inside part is bent up a little. Can you see the spring if its still there?
Personal seals are cheap $10 or so each I would allows replace them regardless. I have learned the hardway and its just not worth it for a small amount of money.
talvai is offline   Reply With Quote
Old 01-23-2010, 01:05 PM   #3
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Sounds good to me. Do the new seals come with springs or do I need to order those separately?
Old 01-23-2010, 04:30 PM   #4
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Nope new seals come with them. I actually just got them for mine. If you can wait order from subarugeniuneparts.com I think its $8 each or something there or if you need them quick get local dealership, but they charged me $11 something each. Again small price to pay to save yourself a headace.
Old 01-23-2010, 05:10 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
My dealer carries them for <$5.
Actually, they've matched or beat SGP on nearly everything so far... and with no shipping.
But yeah, replace them now or regret it later.
Old 02-10-2010, 08:26 PM   #6
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
just make sure when you put the axles back in not to hit the seal those things are wimpy
shift0246 is offline   Reply With Quote
Old 02-10-2010, 08:36 PM   #7
iht
Member#: 196742
2000 Impreza 2.5rs
It's called cheap insurance. Replace it and don't worry about it.
Don't replace it and you worry that someday it'd leak, causing you to blow a $$$$ part.
iht is offline   Reply With Quote
Old 02-10-2010, 09:28 PM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
looks strange... at any rate, don't you need a seal driver to install it properly?
Old 02-11-2010, 09:08 PM   #9
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
put some lube on the new seals...
04stigeorge is offline   Reply With Quote
Old 02-11-2010, 09:12 PM   #10
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I actually pulled out the old seal, put new seal over hole, put old seal on top of new seal, and lightly tapped the seal in with a hammer by beating on the old seal. The old seal took the beating and pushed the new seal perfectly into place.
That went well.
But when I was pulling the seals I though one was stuck, turns out the puller was just caught on the side.
05 STi rear diff axle seal part Number? joe r Private 'Wanted' Classifieds 1 04-05-2010 07:16 AM
BC Racing Coilovers changed the axle angle a lot in the rear is this normal? spoolinsti05 Brakes, Steering & Suspension 10 06-04-2008 05:13 PM
rear sti axles, is this normal dan avoN7 Transmission (AT/MT) & Driveline 10 12-31-2005 08:58 PM
Is this normal? Grease looking stuff around my axle & tranny cky211 Transmission (AT/MT) & Driveline 25 10-09-2003 10:05 AM
How many have had rear diff axle seals replaced under warranty?? donjuan Normally Aspirated Powertrain 2 07-18-2001 09:33 PM
