Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-24-2002, 02:40 AM   #1
Avenger
Member#: 1234
Default Solid deck sleeve
Does anyone know if they make Solid deck sleeve for the EJ25? I found a site that make solid deck sleeve but they don't have any subaru kits. I think this might help with headgasket problems.
http://www.darton-international.com/
Avenger is offline   Reply With Quote
Old 05-24-2002, 02:59 AM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
Do you mean cylinder sleeves? Or insterts to make the deck a semi-closed deck?
RawCode
RawCode is offline   Reply With Quote
Old 05-24-2002, 03:00 AM   #3
Avenger
Member#: 1234
Open deck to close deck.
Old 05-24-2002, 03:39 AM   #4
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
I'm also interested in some inserts. I know somebody makes them!!
LVSUBARU is offline   Reply With Quote
Old 05-24-2002, 06:35 AM   #5
RawCode
Member#: 3115
2002 Impreza 2.5RS
From what I have heard the inserts can sometimes cause more harm than good. The best thing to do is to weld some into the block but that takes time and the monies!
The inserts if not welded in can actually walk inside the block cause stress in areas that would have been fine before. And you will just cause more problems...
RawCode
Old 05-24-2002, 08:45 PM   #6
Z1 Performance
Member#: 9327
We will be doing a block gaurd (lie offered for the Hondas) in the near future for you GC8'ers. This will strictly be a weld in unit for the guy building up a powerful Ej25 motor.
The first one will be done off a motor we are about to start building, and once completed (mid summer), we'll give you the full deal!
adam
Z-1 Performance
Z1 Performance is offline   Reply With Quote
Old 05-25-2002, 12:31 AM   #7
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Thumbs up
Adam...
I'm looking forward to hearing about it!
Evan J. Kelly is offline   Reply With Quote
Old 05-25-2002, 11:42 PM   #8
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
from the pictures cobbtuning.com has on there web site , they look to do a good job on converting an open to a closed, i think they said 1000$ on your own block, 2000$ with a new block..
bobjr94 is offline   Reply With Quote
Old 05-26-2002, 01:54 AM   #9
XT6Wagon
Member#: 524
04 STi
I am SO not a fan of the stupid inserts. I know plenty of people who blew thier civic motors by going that route.
Also If closed deck is so perfect, why did GM's race program for thier 4cyl stick with the open deck? They tried closing the deck but ended up with MORE sealing problems. I'd think a team of factory engineers could convert a block to closed deck w/o any bad side affects otehr than whats inherent to the closed deck blocks.
XT6Wagon is offline   Reply With Quote
Old 05-26-2002, 03:05 PM   #10
Evan J. Kelly
Member#: 11172
2000 GC8 RS Coupe'
Exclamation
Because the stock heads were flexing... are stock heads aren't nearly as crappy.
Old 05-26-2002, 05:02 PM   #11
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
GM's
Theres the problem!
Old 05-26-2002, 06:51 PM   #12
inpreza kid
Member#: 3334
i'm building up a 300hp phase 2 ej25 right now. i'm probably going to leave it open deck. if you close the deck the cylinder walls might build up too much heat. unless your after 500+hp i don't think you need closed deck.
inpreza kid is offline   Reply With Quote
Old 05-28-2002, 05:10 AM   #13
XT6Wagon
Member#: 524
04 STi
Point is that they are making 800HP on a motor with a MUCH taller cyl bore than our EJ-20's, and they are still using open deck. I'd only assume they tested ther improved head retention on a solid deck motor in addition to the open deck motor.
Old 06-12-2002, 08:50 PM   #14
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
when you "close the deck," what exactly is happening? Are you adding bits of metal in the water jacket between the cylinder wall and the outer block? Or am I completely off?
Thanks a lot!
Chuck
Chuck is offline   Reply With Quote
Old 06-12-2002, 11:51 PM   #15
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Default Closed Deck
Here's a link the shows the difference between the two visually. I don't know anything beyond that, but I'd love to know.
-Rich
http://www.wrx.org.au/tech/
seven881 is offline   Reply With Quote
Old 06-13-2002, 01:11 AM   #16
T-WRX450
Member#: 18105
1995 95/99 Cst Wagon
93 Turbo Sedan
Default Sleeves and Semi closed deck
First, I wanted to say that after 3 months Darton still has not finished the sleeves and sent the block back for the 100mm pistons, when they initially said "Subaru sleeves...No problem. The turn around time is 3 weeks." Excuse after excuse, no returned calls just to hear the status, 50% payment asked for when they had already cashed the check for the Entire amount. Just over 6 weeks ago they said it was on it's way back, asked for the tracking number 2 weeks later and "oh it is still being worked on and would be shipped in a week" Well that week passed and now calls are being placed twice a week with no resolve. I told them we could keep them busy with Subarus from referrals and now I have an EJ25 block that is being sent out to Mahle instead of another to Darton for sleeves and pistons. Mahle produces some of the best quality products I have ever seen and I guess the Formula One engine builders would concur since they do quite a few of those as well as just about every type of motorsport. Darton was recommended by some V8 racing guys but I guess since the piston moves in a horizontal motion instead of a 60 degree angle or vertically and it's not an "H" car. . . Just frustrated but when you own a custom Subaru and your shooting for big numbers on the dyno and low ETs you have to be patient. I just think a little professionalism and some integrity were (is) in order.
T-WRX450 is offline   Reply With Quote
Old 06-13-2002, 01:23 AM   #17
T-WRX450
Member#: 18105
93 Turbo Sedan
Default A continuation
Anyway, sleeving is not really necessary unless you are boosting more than 15 psi (w/ low compression pistons) after sonic testing an EJ25 block we found it was about a tenth of an inch at the narrowest point and just shy of an eighth. The stock head gasket is the weak point as well as inadequate stock valve spring pressure. The JunAuto racing GC8 uses a special custom webbing on the stock block EJ25 to maintain stability and they are putting down 550+ hp on the circuit spec car. I believe Cobb Tuning has a great program to weld the deck closed and for the $1000 approx. it is a great insurance policy against the sleeve walking. The physical thickness of the sleeve was the limiting factor in our situation since we are looking for reliable boost levels between 25-30 psi. An EJ25 block at 300 hp is no sweat and a safe reliable motor. The EJ20 WRX motor and the EJ22 Legacy Turbo use a semi-closed deck block for added strength and reliability. Byron's EJ22 pumps out about 600 hp, so that is a pretty healthy testimonial.
By the way, GM used a thicker sleeve while running an open-deck and a different design of head gasket which allowed better cooling system efficiency while maintaining high cylinder pressure.
And I'm spent - Troy (w/ Austin Powers undertones)
Old 06-13-2002, 02:11 AM   #18
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
I just got a primo EJ25 for my turbo project and want to build the bottom end so I never have to worry about it being the weak link. Closing the deck seems like a great way to handle more stress. It looks like all you need to do in order to close the deck is weld some 7/16's aluminum in the same pattern as the head gasket around the tops of the cylinders. I havn't visited any shops yet, but this seems like something that can be done for much less than $1000.
Old 06-13-2002, 04:28 AM   #19
suberboy
Member#: 1531
2008 GRB
Red
Sorry to jump in here and possibly be off the subject but I'm interested in the closed, open deck definition.
I recently bought a '90-'93 (best guess) EJ20 turbo engine and have been wondering if it is considered a closed deck or partially closed deck (see pictures below)?
On a side note, while I was looking for new head gaskets I compared the ones that came off this motor with the ones that came off the '98RS, and the WRX and surprisingly both head gaskets were almost identical to the ones off of my motor. So I was wondering if the '98RS has a closed, or semi closed, deck? If not why does it have almost exactly the same head gasket as my EJ20 turbo motor (besides the pistons being bigger)?
suberboy is offline   Reply With Quote
Old 06-13-2002, 04:29 AM   #20
suberboy
Member#: 1531
2008 GRB
Red
A closer photo of the EJ20 turbo motor.
Old 06-13-2002, 09:05 AM   #21
Carlos Fandango
Member#: 16206
That block you have there is closed deck!
No question.
Cobbs method is in place for a reason. They heat cycle the wwhole block adding on layers of weld each time and allowing it to cool. In the process this assures that no stress is placed on the bores.
If you just weld in a piece of metal to the bores, as it cools it contracts.
If it was that easy, dont you think cobb would make it a cheaper mod?
Carlos Fandango is offline   Reply With Quote
Old 06-13-2002, 03:59 PM   #22
Strider
#Blessed
Member#: 2197
an inconvenience,
properly considered.
One more point for GM using an open deck on the drag car.
Those racing engines are torn down constantly, and I'm sure the team has an extra engine on hand if one blows at a race. They don't need the extra durability of a closed deck like a daily driver does if he wants to push 400+ hp...
I'd rather close the deck and not worry, I mean, if you have the $$$ to do a 400+ hp Impreza, why cut corners?
Jim
Strider is offline   Reply With Quote
Old 06-13-2002, 10:21 PM   #23
XT6Wagon
Member#: 524
04 STi
I really doubt that relaiblity is a secondary concern. That level of racing is such that the motor must make it the whole weekend w/o a problem or needing a replacement. If you puke a motor in qualifing you might not make the show, if you puke during the show, there goes any chance of a win.
I think people are missing the point. Stresses on the Cyl wall are fairly minor from the piston, and often the lower stresses from the greater and more even cooling from the open deck block can make up for that.
Sleeves cast v solid steel stock col5555 Built Motor Discussion 0 11-12-2009 06:58 AM
Sleeved or closed deck project_skyline Built Motor Discussion 22 06-22-2008 08:59 PM
Can closed deck 2.0 be sleeved to 2.2 ? bugeyes Built Motor Discussion 3 03-30-2007 04:15 PM
solid deck motor, just bottom end is fine motorswapsleeper Private 'Wanted' Classifieds 0 05-24-2006 04:12 PM
$1400 95 STi-RA version 2 engine, $900 heads, $500 ej20g solid deck shortblock forged supermoose Private 'For Sale' Classifieds 1 09-06-2005 04:41 PM
