Old 01-24-2010, 12:49 AM   #1
blacktrail
Member#: 154841
2002 white
johnny tran
Default My "rogue" vf39 protune results
Car:
2007 WRX Wagon
Power Mods:
K&N Short Ram Intake
Samco Turbo Inlet
Stock sti VF39 Turbo
Stock sti TMIC
NGK One-step colder plugs
Gtspec UEL Gen II Header
IAG Uppipe with 38mm Tial V-band EWG
Injen 3" DP
Invidia N1 Race 3" CBE
Walbro 255lph FP
Grimmspeed 3-port EBCS
Cobb Accessport V2
And the best part:
Tuned by Jorge of P&L Motorsports
Weather corrected 338awhp & 346awtq @ 14.78 psi (ewg pressure)
Gas was BP pump 93 octane
Dyno was IAG Performance's in house DynoJet
Stock Injectors are at 94% for those curious
Overall, just a few hours later and I'm still scratching my head. I know they're just numbers but even Jorge himself seemed surprised and had to ask me a couple times if I was sure it was a vf39. He basically said he watered it down as much as he could but couldn't go under 14.78 psi because of the ewg. And to think all I asked him was to get as much out of it as he felt comfortable with. I was in no way expecting anywhere near this much power.
Here is the plot, sorry bout the fuzziness my camera's kinda blah.
And heres one of the finishing runs on the dyno.
Big thanks to the IAG Team for their support and the best customer service I've experienced yet, and huge thanks to Jorge for one hell of a tune. Driveability & Power get an A++, smooth as butter.
I highly recommend both parties and will do business with them again.
blacktrail is offline   Reply With Quote
Old 01-24-2010, 01:22 AM   #2
radial
Member#: 236183
not bad, good job
radial is offline   Reply With Quote
Old 01-24-2010, 01:45 AM   #3
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
those are great numbers but why do an ewg setup(all that added cost) and only run 15psi?
wrxtremeWGN is offline   Reply With Quote
Old 01-24-2010, 01:50 AM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
So, a turbo that doesn't flow enough air to make 300+ on pump, and at less than 15 psi, making 338????
Ya, uhhh, I'm sure it's fun, but you do not have a 340whp car realistically. No offense to the tuner, but with that setup, an EvoIII 16G with a good TMIC or FMIC would be putting down upwards of 375whp on pump gas and 20ish psi, and that's absolutely ridiculous.
Audiosavvy is offline   Reply With Quote
Old 01-24-2010, 09:19 AM   #5
blacktrail
Member#: 154841
2002 white
johnny tran
This is the odd part, nobody expected it to make this much "supposable" power so we weren't expecting to leave it that low. I figured it'd be just like every other vf39 and I'd be able to run closer to 19 or 20.
Thats what the dyno told us, yes, as you can see in the printout. I don't really believe its a true 340whp car either but I still think its pretty interesting it came out that way. I can't really compare it myself because this is my first car i've owned with this much power. I just gotta wait until the local strip opens up so I can see what it'll run or hit a dyno day or something of the like.
Old 01-24-2010, 09:44 AM   #6
paul_p1
Member#: 77372
2005 Spec C
WR Blue
These figures look like crank figures we would get for this turbo setup in the UK.
paul_p1 is offline   Reply With Quote
Old 01-24-2010, 10:52 AM   #7
pisymbol
Member#: 174448
Correction factors are off on the dyno....or that's not a VF39....I thought the stock boost was ~15 pounds! LOL.
pisymbol is offline   Reply With Quote
Old 01-24-2010, 11:05 AM   #8
MattPersman
Member#: 139385
there dyno reads high normally but they must have just got it recalibrated for this run
MattPersman is offline   Reply With Quote
Old 01-24-2010, 11:11 AM   #9
bgod
Member#: 100274
Numbers aside I'm sure the car feels great.
Realistically can you achieve those kind of numbers with your set-up on that boost, no way. Dyno error, perhaps.
In any case, crank that sucker up to 20psi because you're leaving a lot on the table. If you think it's great now, get back on the dyno at get that 5psi.
bgod is offline   Reply With Quote
Old 01-24-2010, 12:08 PM   #10
vusalterego
Member#: 198082
2009 tsx
forever dirty
dyno sheet says the numbers are uncorrected... so no correction factor was used, and it should read similar to any other uncorrected dynojet.. corrected numbers may go down if it was done in a cold environment.
typical VF39 setup should see 275-300whp on an uncorrected dynojet. But on the other hand, the OP doesn't have the typical VF39 bare minimum setup done on the cheap as many people do. that header/EWG combo isn't something you see posts about very often, and can very well contribute to the higher-than-norm numbers.
but even still, those numbers are bananas.. at 15psi?
vusalterego is offline   Reply With Quote
Old 01-24-2010, 12:12 PM   #11
RdiggA
Member#: 152945
2007 LGT
unless i missed it somewhere but your not even running larger injectors. If your still on stock injectors your seeing mid 290's MAYBE slightly more because the car just cant flow anymore fuel. With injectors you would be able to pull out a little more power but nothing close to what you have there. Those are E85 numbers for a 39. Car probably feel great though, im lookin into getting a 39 for my legacy. Enjoy.
RdiggA is offline   Reply With Quote
Old 01-24-2010, 07:09 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
why were the dyno brakes hit before the run started?
sidewayz is offline   Reply With Quote
Old 01-24-2010, 07:31 PM   #13
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Why did you tune the car at only wastegate pressure?
C J is offline   Reply With Quote
Old 01-24-2010, 07:47 PM   #14
jonfrow
Member#: 190239
2002 impreza
psm
subscribed. it might be a little before we see track times and answers here.
jonfrow is offline   Reply With Quote
Old 01-24-2010, 08:04 PM   #15
Remnex
Member#: 83790
Who gives a ****? Dude is happy with his car, the dyno is a tool, numbers mean ****... how many times do we have to do this with you weenies?
Remnex is offline   Reply With Quote
Old 01-24-2010, 08:34 PM   #16
blacktrail
Member#: 154841
2002 white
johnny tran
Meh, he told me it was corrected from the original run so I just took it with a grain of salt.
Thats really all I was expecting. I was just hoping to break 300. But go for it, its worth it.
I'm assuming to just get the revs down to start the pull.
He didn't want to go higher because of the reading the dyno was presenting us with.
I believe the local track opens the 1st of March? Somebody might have to remind me but I'll try an head up there sometime shortly after it opens. That and/or I'll hit a local dyno day and see what that gives me.
Thank you, lol. I am extremely pleased with the car. Its a world's difference from the cobb stage 3 ots map and makes stage 2 feel like I was standing still. And no matter what the power actually is I'm completely satisfied with everything its giving me.
Old 01-24-2010, 10:37 PM   #17
cireturbo
Member#: 119777
2013 BRZ
Stock injectors most likely...
cireturbo is offline   Reply With Quote
Old 01-24-2010, 10:46 PM   #18
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Question has been answered already.
And I have run 19 psi on a vf39 on stock injectors.
Newer wrx injectors are bigger than pinks I believe.
godforbid67 is offline   Reply With Quote
Old 01-24-2010, 11:02 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You guys are all talking out of your asses about this and you dont understand how things work.
Turning the boost up to peak at 20psi will gain alot of lowend torque but will in no way effect the boost after 5500rpm, it wont effect max IDC's, and wont effect peak hp.
Max boost, peak hp, and max IDC's all occur at different RPM. Turning the wgdc to 100% and maxing the turbo would only change the boost before 5500rpm and increase the tq.....the peak hp wouldnt change and the max idc wouldnt change.
I bet jorge left the midrange boost down to keep the Torque below 350 ft*lbs......many tuners use 350 ft*lbs as a max torque they will put on a customers car on the stock 5 speed.
Wow.......i just looked at jorge's last couple tuning sessions at IAG.....vf turbos were making 300hp. gt52 did 350 on pump...., gt35 360whp on pump....18g 330whp on pump.
sounds like either the dyno was messed up or that thing has a 20g wheel
Old 01-24-2010, 11:46 PM   #20
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
I am inclined to agree.
It's totally reasonable for a wastegate spring to stop you from going under some level of boost - wastegate springs just do that. It sounds to me like he was trying to tell you that he couldn't taper to less than 14.78. Your peak boost is certainly higher than that.
338whp on a VF39 on straight pump is incredible. That's all I have to say about that.
Old 01-25-2010, 02:13 AM   #21
socalLGT
Member#: 89752
08 STI
+1 In fact even though the pic of the dyno sheet is blurry as hell you can see that midrange boost was indeed higher. There is no physical way for a VF39 346wtq on less than 15 psi on pump gas. If boost was at least a couple psi higher then it makes sense. The peak power is completely believable to me. I've done over 330whp on 91 octane pump gas on an EWG stock turbo STI. That was admittedly a stronger than average car as I'm sure is also the case with the OP's car.
socalLGT is offline   Reply With Quote
Old 01-25-2010, 02:27 AM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
pretty sure the peak boost number on the graph is 16.94.
Old 01-25-2010, 04:51 AM   #23
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
phatron is correct, and it tapers 14.9psi @ redline. still lower than expected boost for the numbers but thats more like it...
Old 01-25-2010, 03:47 PM   #24
blacktrail
Member#: 154841
2002 white
johnny tran
Yes, I noticed that as well, but was told it was a spike.
Old 01-25-2010, 04:03 PM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
Default Re: My "rogue" vf39 protune results
How can u look at a line that's striaght at 17psi for 2000 rpm and call it a spike?
06 WRX VF39 Protune results from Jorge sluflyer06 Proven Power Bragging 31 06-19-2007 10:17 PM
05 STi VF39 Protuned Results sfe Proven Power Bragging 10 02-19-2007 04:04 PM
my 06 STi protuned result Nactos Proven Power Bragging 3 01-20-2007 01:02 AM
2006 wrx cobb vf39 protuned results random1 Proven Power Bragging 27 09-07-2006 11:21 PM
Cobb AP Protune results STi Crazy Proven Power Bragging 9 02-22-2006 05:08 PM
