#1 |
Member#: 317893
Vehicle:2013 STI SE Orange |
So I'm installing a invidia downpipe on my wrx, and I bought a grimmspeed turbo heatshield. But what about the shield that is underneath on stock downpipe. It doesn't fit with my invidia downpipe. Does it for somehow or do I no need it?
#2 |
Member#: 267463
im not positive... but i think that needs to come off. did on my sti
#3 |
Member#: 317893
Any problems since its been removed?
#4 |
Member#: 305107
Vehicle:2012 wrx satin white pearl |
you dont reuse any of the heatshields from the factory downpipe. just wrap the dp in some DEI wrap, get a turbo blacket and use the gs heatshield, you will have better protection than oem..
#5 |
Member#: 95556
Vehicle:2012 WRX 5dr silver |
i had to remove all factory shields on the downpipe. i just ran the heat wrap all the way down to the end. proably better then the facotry metal ones any how.
#6 |
Member#: 166490
Vehicle:2011 WRX WRB |
You mean the existing turbo heat shield? You can trim it with shears or a dremel and make it fit, but a turbo blanket and that Grimmspeed heat shield should be enough in my opinion. Sorry if that's what what you're speaking of. I haven't gotten to the DP on my 2011 yet. Soon.
#7 |
Member#: 297565
Vehicle:2011 WRX hatch Silver |
I installed my dp on my 2011 without re using any shields. I do have my dp wrapped in heat wrap, but nothing is on my turbo at all currently. I am looking to heat wrap that as well however.
#8 | |
Member#: 301089
Vehicle:2011 WRX 5 door TP stage 2 |
You'll want to have that on because it gives you one attachment point on the left side lower part of the grimmspeed heatshield. Without it you risk rattling annoyance. |
#9 |
Member#: 317893
Yeah I figured it out last night when I actually got to the install. Thanks for the help though
