Old 06-02-2010, 04:30 AM   #101
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
Originally Posted by danielportz View Post
Yeah, I lost my engine with 50k on it because of that stupid oil pickup. I never imagined that subarus had a problem with oil pickups. I learned the hard way.
Did you get this warrantied through SOA? Your powertrain warranty is 60k miles I believe...Unless I missed something?
Got mine today. @ 40k and not chancing it.
I dont think anyones done a detailed install on this w/ tons of pics etc. I've looked and found bits and pieces. Shouldnt be all that difficult, I just keep hearing the 4 rear pan bolts are a PITA. I'll be using an OEM gasket and some oil resistant sealant.
Any recommendations on good sealants?
cartoonlife is offline   Reply With Quote
Old 06-02-2010, 01:11 PM   #102
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The OEM gasket is liquid gasket.
KillerBMotorsport is offline   Reply With Quote
Old 06-02-2010, 01:54 PM   #103
FlashEngineer
Member#: 183923
'08 EJ257
I used Permatex Ultra Grey, it seems better than copper or red. No leaks so far. Bolts aren't hard if you jack up the motor, or even if you don't you can reach them easily but not as easy if you jacked it.
Hard part is getting the stock liquid gasket off....
FlashEngineer is offline   Reply With Quote
Old 06-03-2010, 02:47 AM   #104
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
I suppose subaru opted to use liquid gasket on the turbo applications due to... heat?
I know killer B motorsports doesnt supply a gasket w/ their pans... reason?
I bought a cork gasket anyway, and will use it in tandem with some liquid gasket material. I'm just looking for the best. Permatex is good enough I suppose, but what about three bond?
Once my oil pickup is installed I want absolutely no freakin leaks.
Suggestions?
Old 06-03-2010, 08:26 AM   #105
FlashEngineer
Member#: 183923
'08 EJ257
Cork is a very bad idea, it can and will break off into the oil pan and possibly clog up the oil pickup screen with the bits and pieces.
It seals from factory just with a liquid gasket like Permatex. I get no leaks with Permatex Ultra Grey.
Old 06-03-2010, 09:51 AM   #106
fistandauntilus
Member#: 145533
2004 STi
cork is the worst materiel ever to use as a gasket. it will break down and get into the oil pan. if you want your engine to last dont use it.
fistandauntilus is offline   Reply With Quote
Old 06-03-2010, 06:55 PM   #107
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
DO NOT USE CORK. If you don'r believe me search around and you'll find many oil pan leaking threads and most come back to a cork gasket being installed (even WITH liquid too).
The factory (and our pans) use liquid gasket for a reason, it works!
Old 06-03-2010, 10:50 PM   #108
simonella_virus
Member#: 183875
2007 WRX STi Stg2
oh i'm holding off on doing this cuz it'll cost me a pretty penny [in canada]... but i will eventually do this. sigh...
simonella_virus is offline   Reply With Quote
Old 06-15-2010, 12:23 AM   #109
Maxxim
Member#: 187380
2005 Impreza STi
Just ordered Killer B's pickup, this thread was the "final straw" for me, and just felt it was worth the extra expense.
Maxxim is offline   Reply With Quote
Old 06-15-2010, 01:50 AM   #110
SupersayianNeo
Member#: 49804
2222 WRXSpecV-Type-R
DICK
SupersayianNeo is online now   Reply With Quote
Old 06-15-2010, 07:46 AM   #111
Guy on the corner
Member#: 169591
05 LGT
Originally Posted by KillerBMotorsport View Post
Yes. Any model from 2006-current that has an EJ25 motor (Impreza WRX & STi, Legacy GT, Forester XT) has the same pickup.
Your statement is 6 months old... just want to make sure it still stands. So.. an '05 LGT doesn't use this pickup?? And isn't susceptible to this fault??
Guy on the corner is offline   Reply With Quote
Old 06-15-2010, 09:06 AM   #112
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
There'se any easy way to know if your car/model is known to have failures. If it has an EJ series motor in it. So yes, your Legacy is included. If you go to Legacygt.com you'll find failures and guys that have installed our pickup.
Old 07-01-2010, 10:27 PM   #113
justchillax808
Member#: 177287
Chapter/Region: HIIC
2006 STi
steel gray
Just ordered the tube, Thanks KillerB for providing a fix to the problem. If it's cracked i'll post it up.
justchillax808 is offline   Reply With Quote
Old 07-01-2010, 10:41 PM   #114
streetking
Member#: 244036
I got my car for 100k miles on it and the oil tube broke. It's an 06 sti and if mine broke then all ejs will break period. I was skeptical at first and thought it could be a marketing gimmick and only a fer percent of tubes would break... Turned out the only one that matters to me broke! Dun take any chances ppl!
streetking is offline   Reply With Quote
Old 07-01-2010, 10:46 PM   #115
GroceryGetter06
Member#: 200092
2006 Stg.2 WRX Wagon
My oil pickup cracked. Created a nice 5300 (including 425 for clutch the rest parts and labor for a short block) Awesome. 06 WRX
GroceryGetter06 is offline   Reply With Quote
Old 07-03-2010, 11:23 PM   #116
simonella_virus
Member#: 183875
2007 WRX STi Stg2
just did the swap today. the OE oil pickup tube was fine. just wanted to post that, as people only post when something is terribly wrong. but, that's not to say that the OE tube wasn't on the verge of assploding. i guess we'll never know
Old 07-07-2010, 04:22 AM   #117
turbofied
Member#: 239813
I was inspecting the pickup of my now removed 06 140K kms wrx engine.
I was feeling around the inside of the tube for hairline cracks and the whole thing cracked. More brittle then a potato chip how can subaru not do any sort of recall on this. This car has never been tracked.
If the motor was still in the car id say a few more bumps and it would if been a new engine.
turbofied is offline   Reply With Quote
Old 07-07-2010, 04:36 AM   #118
turbofied
Member#: 239813
Old 07-07-2010, 09:07 AM   #119
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Wow, that was a close call!!
Here's the jist of what I got when I asked my higher up contact at Subaru...
As far as engineering changes go, the only say we have here in the US is what options and trim levels should be offered/changed to help sell more cars to the US market. The design/engineering is done in the motherland (Japan) and because of the way the tax and emissions structure is over there nearly all cars are sold and/or the engine is entirely replaced at ~30-40K miles, so over there this is a non existent problem.
While my personal experience with what goes on in Japan is limited, I have heard/read that thier tax structure on vehicles is backwards from ours, with taxes increasing on a cars the older it gets, and the emissions standars are extremely stringent and carry hefty fines. Maybe some one with some real experience here can clarify or correct my statements if they are not entirely accurate?
Old 07-07-2010, 09:20 AM   #120
White GDA
Member#: 128905
2005 Impreza WRX
^^That's correct.
It encourages "growth" of the JDM new car market apparently. Owners are encouraged to sell their cars quickly, as in most cases, cars beyond 5 years old have hefty taxes and the like.
It also makes for a good used car market to export to other countries -that's actually how most of the GDA's and GDB's find their way into the country I'm from
White GDA is offline   Reply With Quote
Old 07-07-2010, 11:12 AM   #121
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Just got a look at the killer B website...very impressive stuff. You guys make some really quality and innovative parts. Ordering a pickup and pan for my bugeye build ASAP.
Have a question though, i know the pickup tube will fit our 08 STI, but nothing else on your site lists applications past 07. The pan should fit the 08 as well, corect? As should the Alternator shroud? If it wil fit the 08, any way i could order an alternator shroud in raw aluminum? We might want to do a custm anodized color to match the other pink items on the car.
Sorry so many questions.
Squidz is offline   Reply With Quote
Old 07-07-2010, 11:20 AM   #122
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the kind words! Our pickup fits ALL STi motors and any EJ series motor as long as it has an 04+ STi pan or 06+ ANY Impreza pan.
PM sent on the shrouds.
Old 07-07-2010, 11:31 AM   #123
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
KillerB, is the install any harder on a 2010 WRX for your oil pickup with the chassis change and all?
jay25RS is offline   Reply With Quote
Old 07-07-2010, 12:16 PM   #124
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Nope, same deal
Old 07-07-2010, 12:17 PM   #125
Squidz
Member#: 142608
2003 Sonic Yellow
Sorry, i wasn't very clear...i was asking if your pan (I said the pan...LOL) would fit the 08. I'm sure it will, as the differences in manifolds is very slight, but i want to be sure before i order them for the cars.
oil pickup tube failure thread unclemat Warranty Issues & SOA Problems 851 04-12-2016 10:37 AM
FS: Engine mounts, Killer B Oil Pickup BRAND NEW, plus stock STi parts! uncle lewie wrx Tri-State Area Private Classifieds 1 12-14-2009 05:50 PM
Oil pickup tube torque spec? LeeC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-11-2008 12:15 PM
Oil pickup tube torque spec? LeeC Built Motor Discussion 0 07-24-2008 05:54 PM
oil pickup tube, need help asap please ihadmail Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-10-2008 11:25 PM
