Old 01-24-2010, 01:22 PM   #1
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
1980 Porsche 911SC 3.6L
Default Dyno Tune: 2.0L + TD04 makes 242whp 263WTQ (Epic Motorsports)
Event: dyno pull/ tuning
Ambient Temp: 60-70 degrees Fahrenheit
Elevation: N/A
Car: 2005 WRX
Tuner: Robbie
Dyno Info: Mustang
Peak HP at RPM: 242whp @ 5700
Peak Torque at RPM: 263wtq @ 4200
Baseline hp/tq for a stock on same dyno: Approximately 240whp/ 240wtq for stock sti
Target Boost: 20psi
Target AFR: 11:1
Fuel: 93
Engine/Power Modifications:
CSS FMIC
Grimmspeed 44mm EWG kit (coated)
Grimmspeed EBCS
Grimmspeed ported Intake manifold (coated)
Grimmspeed ported APS TGV deletes (coated)
Grimmspeed 8mm Phenolic Spacers
Grimmspeed Exhaust Manifold Crosspipe (coated)
Ported Exhaust Manifold (coated)
Cobb Intake
APS Turbo Inlet
Witchhunter modified injectors (800cc)
Megan Racing Downpipe
HKS Carbon TI Catback
Driveline Modifications: ACT heavy duty clutch kit and ACT streetlite flywheel
Suspension Modifications: Mach V springs, Whiteline sways, karboy endlinks, TiC fender braces, Unabombers Sexy rear end
blue line is tq
red line is hp
green line is boost
fl4tsc is offline   Reply With Quote
Old 01-24-2010, 04:29 PM   #2
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
Great torque numbers! but isn't the FMIC wayyyy overkill on the td04? the torque peaks pretty late for such a small turbo. I would think you stuck with the stock turbo for its streetability because your parts list definitely says you had $ for a new turbo.
pearljam11 is offline   Reply With Quote
Old 01-24-2010, 04:48 PM   #3
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
ya the fmic and ewg are kinda overkill but i am actually planning on going to either a evo3 16g, 18g or hta68 down the road and then seeing where the cars reliability takes me from there.
also the wastegate seems to be partially opening earlier than it should because i bought the wastegate used and i think the spring in there is not the one i though/the seller told me it was. which may be why the boost comes on relatively late for a td04.
as for the money part I've been slooowly piecing this together i could've purchased a bigger turbo a long time ago instead of some of the other stuff but i figured I'd do everything possible before getting the new turbo to make it really worth it.
Old 01-24-2010, 04:56 PM   #4
WRX_Kidd
Member#: 26305
18g FTW! Love mine for a daily driver. Not sure about the HTA68
WRX_Kidd is offline   Reply With Quote
Old 01-24-2010, 05:12 PM   #5
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
I've been looking at some numbers of the 3 turbos I'm looking at and it seems all of them are going to make only slightly higher tq numbers (i know plenty more hp) than i am now unless i run e85 or higher octane gas. anyone have any comments on that? it almost seems like it might be worth it to go with a 20g or hell why not a rotated 30r instead until the motor/tranny blows so that there is actually a real increase in the tq department? or will the fact that it carries all the way to redline on the evo3/18g/hta68 make it worth it anyway?
Old 01-24-2010, 07:55 PM   #6
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Your car is a fun car. The 20g would make a very fun, very useable powerband. search and se if C4ninja has posted any dyno sheets on here his car on a stock 2.5 block. top mount and supporting mods made 347/354 tq at 20psi
robbieshonda is offline   Reply With Quote
Old 01-25-2010, 10:17 PM   #7
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
ya i really don't know right now...
i'll probably end up sticking with the evo3 or the hta68 since they're both a good bit cheaper than the 18g and 20g. also i'd like to keep the stock motor/tranny for as long as possible. then again if that last statement was true i wouldn't be moding it
oh and robbie i ended up getting the LC patch to work. i had to transfer over all the tables to a newer revision map which sucked but it was worth it.
Old 01-25-2010, 10:55 PM   #8
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
800 cc injectors for the td04...wow. i see youre looking to upgrade to a evo III though...but still
WREX88 is offline   Reply With Quote
Old 01-26-2010, 08:10 AM   #9
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
On the 2.0L it's hard to beat a properly setup 18g/EvoIII 16g. I ran 11's all day long on that setup. On pump gas I made 305hp and 291 tq. Get it drunk on alky and it wakes up.
You don't look at the peak numbers....you look a the entire area under the curve to see how it reacts.
Congrats on the numbers. Solid for a td04.
CoolRex is offline   Reply With Quote
Old 01-26-2010, 08:13 AM   #10
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Holy crap!! That's awesome. We had a local kid trying to yank as much power as he could out of the stock 2.0L. Aside from the ported intake manifold, tgv deletes, larger EWG you guys had an identical parts list. Last I knew he was somewhere in the 230hp/lb-ft area on a dyno where a typical stage 2 WRX makes 210hp and a stage 2 STi makes 245hp. Unfortunately he had a rather close encounter with a guard rail on the freeway .
Anywhoo...looks like a whole lot of fun!
Scooby921 is offline   Reply With Quote
Old 01-26-2010, 08:45 PM   #11
fl4tsc
Member#: 177247
2005 WRX 16G-XT+EWG
ya that sounds like what i want to do. except instead of alky i'll probably get a separate tune for e85 since the evo3 and hta68 seem to respond really really well to it.
those are some good numbers... what kinda dyno?
Old 01-26-2010, 08:57 PM   #12
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
It was a dynojet but this tells you more.....set the record at 11.7 @ 122 mph.
Old 01-31-2010, 07:51 PM   #13
WrxErik
Member#: 195822
2003 Impreza WRX
I have a 2003 wrx with tbe uppipe and cai. It seems we have a similar tune since we are both running 20psi. I will have to dig up my dyno sheet but it was also on a mustang dyno and I put down 240hp and 270trq. It was about 100F in the dyno room. I will post back up when I find my dyno sheet and get it scanned.
WrxErik is offline   Reply With Quote
Old 01-31-2010, 10:53 PM   #14
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
some cars are natural freaks
scoobystas is offline   Reply With Quote
Old 02-01-2010, 12:24 AM   #15
speedin
Member#: 79858
nice numbers
speedin is offline   Reply With Quote
Old 02-01-2010, 12:25 AM   #16
trick_subie
Member#: 175001
2006 WRX TR
If I can find it, I'll post my sheet from 6200ft on my old td04. 263whp corrected and 351ft/lbs of wtq on E85.
trick_subie is offline   Reply With Quote
Old 02-01-2010, 12:33 AM   #17
speedin
Member#: 79858
Wow that .5L really jumps the TQ! I have a 02 stock block Td04 on E85 that made 275whp and 300wtq on a Dyno Dynamics
http://forums.nasioc.com/forums/show....php?t=1924123
Old 02-05-2010, 03:31 AM   #18
Batman wrx!
Member#: 191046
05 wrx
well my car is kinda a freak..my stage 2 protune on a mustang was 253whp and 253 wtrq
Batman wrx! is offline   Reply With Quote
Dyno Tune: 2.0L + VF43 makes 285 whp dsolis Proven Power Bragging 54 04-05-2010 06:34 AM
Dyno Tune: 2.0L + Blouch Evo lll 16G makes 302 WHP burtonrider3889 Proven Power Bragging 33 03-26-2010 12:00 AM
Dyno Tune: 2.5L, GT35R, makes 439whp apexslider Proven Power Bragging 6 02-09-2010 10:29 AM
Dyno Tune: 2.0L + VF39 = 289.5HP ('04 WRX) dLo R6 Proven Power Bragging 18 11-04-2009 09:21 PM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 08:32 AM
