Old 01-24-2010, 02:01 PM   #1
mudbug
Member#: 218867
1999 impreza brighto
white
Default V7 vs V8 dyno chart
Hi,
Does somebody has stock comparison of V7 and V8 dyno charts. Preferably same dyno, same day.
Thanks
Pascal
mudbug is offline   Reply With Quote
Old 01-25-2010, 11:55 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
not too many overseas folks chime in here.
a v7 vs v8 on the dyno on the same day in the US has probably never happened.
Old 01-25-2010, 12:43 PM   #3
mudbug
Member#: 218867
white
Oh!!! Thanks for the info. I think the JDM market in stronger in Canada.
Old 01-25-2010, 01:02 PM   #4
fourmicah
Member#: 128760
2015 STI
Ya, sorry, but it sounds like a needle in a haystack search for the US
fourmicah is offline   Reply With Quote
Old 01-25-2010, 01:49 PM   #5
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
You might be able to find some information over at ScoobyNet
kayen is offline   Reply With Quote
Old 01-25-2010, 02:02 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
I have logs of a stock s203 and a stock s204 i think......
i could plot them up and give you a road dyno comparison. if i can find them. not sure if s203 = v7 and s204 = v8 though.
Old 01-25-2010, 02:19 PM   #7
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
S203 = v8 Blob Eye and S204 = v9 Hawk Eye
S202 = v7 Bugeye
I almost think he wants to see the difference between the Single Scroll vs. Twin Scroll, but I could be wrong.
Old 01-25-2010, 05:58 PM   #8
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
i can post a dyno plot of a stock v8 motor tuned to about 18lbs of boost, its really nothing to write home about. just search my name, i started a thread on this in proven power forum i think. From all the vf39 and vf34 plots i've seen, my car does not spool quicker, and i believe that is pretty much the general consensus here on nasioc. This is with functional avcs btw.
scoobystas is offline   Reply With Quote
Old 01-25-2010, 06:08 PM   #9
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Isn't the v8 single scroll, while the v7 was twin scroll?
Fierysun is offline   Reply With Quote
Old 01-25-2010, 06:10 PM   #10
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
other way around
Old 01-25-2010, 07:17 PM   #11
mudbug
Member#: 218867
white
From what I heard since the V8 twinscroll came out, the V7 is stronger than the V8 at high rpm. I only want to confirm or not this fact. Also if it's true I would like to find out why since the V8 has better heads and is almost the same as the V7 everywhere else except for the compression ratio...
Stock charts would be easier to compare than modded cars since all the parameters need to be the same.
thanks guys
Old 01-25-2010, 08:02 PM   #12
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
might be that the twinscroll is outflowed up top by a single scroll turbo. From what i've noticed of dyno plots between twinscroll and single scroll turbos, is that a twinscroll drops alot more torque to redline than a single scroll turbo.
the engines have no real differences other than the v8 runs a tid bit more compression and cast pistons vs. forged on the v7 motor.
most of the differences will be with the turbo and tune.
http://forums.nasioc.com/forums/show...highlight=vf39 this is a v39 that looks really good up top and doesn't drop much torque.
http://forums.nasioc.com/forums/show....php?t=1848754 this is my setup.
the dynos are the same but could be using different correction factors and obviously the atmospheric conditions are different
now that i look at it, my car does spool quicker. i'm at 175lbs of torque by 3480 while the other car is at about 130lbs. But, the runs could have started at different rpm speeds and thus the load could have been different.
anyways i know this isn't exactly what your looking for but hopefully it helps, somehow
Old 01-26-2010, 08:18 AM   #13
Mecka20000
Member#: 176162
MY02 Jesus Once Told
Me, "Numbers Sell"......
IDK if this will help but, heres my old setup info.... A 2002 WRX v6 Ra gears 4th gear pull on my stock MY02 EJ207DW4CR V7 i made 280whp @ 18psi w/ PE1818 (modified VF-22 turbo) at Harmen Motive in 2007 Mustang Dyno (Dyno Cell). HyperflowFMIC, 850cc Inj (Modified inj), Walbro FP, Ecutek tuned. Helix Ver1 DP, Cutout Open, 91Octane, 11 AFR, 65degree dyno temps. I have the dyno chart on paper, but no scanner.
Mecka20000 is offline   Reply With Quote
Old 02-03-2010, 02:49 AM   #14
mudbug
Member#: 218867
white
I found 3 graphs here in Quebec coming from the same dyno.
V7, Ecutek, 91 octane, headers stock, uppipe lachute, downpipe lachute, midpipe WRX 2004, axleback STI
V8, Ecutek, 94 octane, stock sti exhaust
V8, stock, 94 octane, 3 inch catback
What is strange here is the difference in spool up between the two V8 setup
thanks
Pascal
Old 02-03-2010, 02:55 AM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
the stock exhaust made more power than the other 2
Old 02-03-2010, 12:30 PM   #16
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Just thought of something else. The V7 Spec C heads have big ports, just like the V8, but the V8 not only has the big ports, but also the oversized valves...not sure if it'd make a big difference in stock form...but modified I'd imagine it shows up somehow.
zeropsi is offline   Reply With Quote
Old 02-03-2010, 01:20 PM   #17
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
actually ALL ej207 from JAPAN only had big port head castings, spec C's have a few extras as well as hand PNP (thanks to Clark for this information in the heads thread)
N8WRX is offline   Reply With Quote
Old 02-03-2010, 02:52 PM   #18
Clark Turner
Member#: 178047
02 WRX STI Spec C
I have tuned many many many V7s v8s and v8 twin scrolls. They make around the same power. The Twin scroll does have a slightly wider power band on the TRQ curve.
The Power difference in V7 and V8 single strong is simple. The V7 cams are weak. The V7 RA has the better cams and the V8's came with the V7 RA cam style. So off the bat, The V8 is going to be a bit better then the standard V7.
Clark
Clark Turner is offline   Reply With Quote
Old 02-03-2010, 02:59 PM   #19
N8WRX
Member#: 99395
2015 Impreza WRX
World Rally Blue
not to thread jack but Clark do you have any detailed info on the cams of the different versions? im looking for a cheap upgrade from my stock v7 cams and was thinking the v8 spec c's but i haven't been able to find much info on any of the jdm cam sets.
Old 02-03-2010, 03:13 PM   #20
Clark Turner
Member#: 178047
02 WRX STI Spec C
Its documented on Nasioc here. Search for the old CAM or JDM head threads. The specs of all of them are listed. Jeff even measured some of them.
Clark
Old 02-03-2010, 10:26 PM   #21
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
i am running a Ver8 VF37 on both my car and my friends, as compared to the VF39 I ran before the 37 seems to spool alot quicker, and seems to be such a smoother daily driver I can make 15psi by 3k in 3rd gear, I do have the complete Ver8 motor that i am rebuilding and will be putting all back together basicly stock except for it will be higher compression than stock, and have forged pistons
seanathanq83 is offline   Reply With Quote
Old 02-06-2010, 06:19 PM   #22
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
sean,
your making 15psi by 3k on the ver8 w/avcs or with an ej205 and no avcs? you got me beat by 200rpm, i'm making 12ish at 3k and 15 at 3200rpm. we're gonna have to discuss on how I can increase my spool by 200 rpm, lol.
Old 02-06-2010, 10:53 PM   #23
seanathanq83
Member#: 173241
this is on a stock ej205 with 120k, PM me and i can tell you what i got, and see if i can help you
Old 02-11-2010, 04:00 PM   #24
bhluv
Member#: 167488
'02 wrx v8 EJ207
aw
Clark
I have v8 ej207 w/ vf30, only got full boost 18psi @ 4200ish rpm in 2nd gear.
Is it a late spool?
bhluv is offline   Reply With Quote
Old 02-11-2010, 04:05 PM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ 5spd or 6?
most dynos on the 5 spd are done in 3rd gear.......4th gear for the 6 speed.
easier to compare if u know your spool in those gears.
Looking for 2008 STi STU vs. Stock Dynos Charts scorpokat3 Impreza Forum 2 07-10-2008 02:53 PM
V7 vs V8 questions?? 2000wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2004 07:51 AM
JDM V7 vs V8 Suspension Dong9mong Brakes, Steering & Suspension 7 07-08-2004 12:47 PM
JDM V7 vs. V8, AVCS hookup questions dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-25-2003 03:26 PM
RS-T vs RS/WRX Stock conversion Dyno Charts christoph1371 Normally Aspirated with bolt-on Forced Induction Powertrain 15 07-02-2002 02:57 AM
