Old 02-11-2010, 04:22 PM   #26
bhluv
Member#: 167488
'02 wrx v8 EJ207
aw
Originally Posted by Phatron View Post
^^ 5spd or 6?
most dynos on the 5 spd are done in 3rd gear.......4th gear for the 6 speed.
easier to compare if u know your spool in those gears.
usdm 5spd
bhluv is offline   Reply With Quote
Old 02-11-2010, 04:23 PM   #27
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
so i would guess ur 3rd gear to be right around ~3500rpm?
i've seen better.....i've seen worse. are u still on the stock bcs?
Old 02-11-2010, 04:26 PM   #28
bhluv
Member#: 167488
'02 wrx v8 EJ207
aw
GrimmSpeed EBCS
Old 02-11-2010, 04:48 PM   #29
Clark Turner
Member#: 178047
02 WRX STI Spec C
I would need to see a log but to me, That seems on the late side. Hard to say as to why.
C
Clark Turner is offline   Reply With Quote
Old 02-11-2010, 05:09 PM   #30
bhluv
Member#: 167488
'02 wrx v8 EJ207
aw
Are log different by different gear?
Which log do you need? rpm vs boost?
Old 02-11-2010, 05:13 PM   #31
Clark Turner
Member#: 178047
02 WRX STI Spec C
Email me. I will send you my log instructions. It will be easier for you to get the log I need. Then I will be happy to look at it.
C
Old 02-11-2010, 05:18 PM   #32
bhluv
Member#: 167488
'02 wrx v8 EJ207
aw
C
email'ed.
Old 02-11-2010, 06:01 PM   #33
Phatron
Member#: 36033
CEO PhatBottiTuning
Yes, you will hit peak boost differently in different gears.
1st is the laggiest.
5th is the quickest.
Old 02-11-2010, 06:05 PM   #34
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
^^ 5spd or 6?
3rd gear in stock 5speed 235/40/17 nitto NT05 if that matters
seanathanq83 is offline   Reply With Quote
Old 02-11-2010, 06:08 PM   #35
seanathanq83
Member#: 173241
i am hitting full boost 22psi before 3500 in 3rd
Old 02-11-2010, 09:06 PM   #36
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
and that's with a larger 20g compressor in the vf37?
scoobystas is offline   Reply With Quote
Old 02-11-2010, 09:32 PM   #37
seanathanq83
Member#: 173241
oh no 20g wheel was like 4100, if you have avcs i bet you could get it to like 3900, but it only made like 20-25whp more than the stock one, the compressor wheels just flows to much for the exhaust wheel, you could have to get a clipped exhaust wheel, i went over this for ever, and found out everything i could, and there is really no way around it, my suggestion is a 16g wheel they are a little bigger, and from what i have seen they have a little better efficiency, not like it will really be noticed, but if you really want to try more do a 18g wheel (40lbs) unless you want to finish the venture i began, and put a td05 wheel in the vf housing, but thats alot of work, and i just never got the money up to finish it
Looking for 2008 STi STU vs. Stock Dynos Charts scorpokat3 Impreza Forum 2 07-10-2008 02:53 PM
V7 vs V8 questions?? 2000wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2004 07:51 AM
JDM V7 vs V8 Suspension Dong9mong Brakes, Steering & Suspension 7 07-08-2004 12:47 PM
JDM V7 vs. V8, AVCS hookup questions dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-25-2003 03:26 PM
RS-T vs RS/WRX Stock conversion Dyno Charts christoph1371 Normally Aspirated with bolt-on Forced Induction Powertrain 15 07-02-2002 02:57 AM
