Old 05-24-2002, 03:44 AM   #1
SoLiDbReAkZ
Member#: 13736
Default Torque Wrench for Suspension work--what size?
I'm planning on purchasing a pretty decent torque wrench for use primarily in installing suspension parts (springs, struts, strut tops, strutbars, swaybars, endlinks).
From what I understand from the manual I'm going to need a torquer that ranges from approx. 14 to 180 ft-lbs .
What would you suggest: a 3/8" drive or larger 1/2" drive??
I'm on a budget and have been looking at Craftsman Digitorks.
PART #--------DRIVE--------INCREMENT---------MEASURE
44597----------1/2"---------2.0 ft. lbs.-------25 to 250 ft. lbs.
44596----------3/8"---------0.5 ft. lbs.--------5 to 80 ft. lbs.
which one would be better fit to suit my needs?? Of course, at first glance it may seem the 1/2" drive is better--but would it be too large for cramped situations..like installing the front sway bar??
let me know. Thanks
SoLiDbReAkZ is offline   Reply With Quote
Old 05-24-2002, 10:10 AM   #2
Ginseng
Member#: 3800
2002 WRB WRX Sedan
2011 Sky Blue Forester Pr
I have a Craftsman 3/8" 15-150 ft-lb and it serves me quite well. There are only a few spots and nuts you need more than 150 ft-lb for and for those, I'd just as soon have the service station do it in case something snaps or strips. Even the crank pulley nut needs less than 100 ft-lb.
Wilkey
Ginseng is offline   Reply With Quote
Old 05-24-2002, 12:18 PM   #3
chmoorewrx
Member#: 17546
2002 WRX Wagon
WR Blue
Yeah, you don't really need the 150 ft-lbs. If you're only buying one, it's really nice to have those lower torque settings. I have two - a half inch monster and a 3/8 bar type that is really nice for those low settings. I don't think I've ever gone above 80 or 90 on the big one - maybe once. My little one tops out at like 45 so I definitely need the other one. Plus, a lot of parts stores (Checker and Auto Zone for sure) have loaner programs that will let you use a torque wrench for free if you buy the little one, then run into fasteners with torque specs above 80.
chmoorewrx is offline   Reply With Quote
Old 06-06-2002, 12:25 PM   #4
cmaj7
Member#: 12677
2002 Subaru WRX
WR Blue
Default Get Twp
Torque Wrenches are most accurate within 10% of either limit of their range.
So, a wrench that has a range of 5 to 80 actual has a 75ft lb range. 10% of 75=7.5 so the wrench is accurate from about 12.5 to 62.5
I have two, one is a Norbar SL1 it range is 5 - 40 or 8.5 to 36.5
I use it for all the small stuff exhause work, spark plugs etc....
I have a second that is 20 - 150 or 34 - 136
My advice buy two, one for the smaller numbers, avoid torque wrenches with very large ranges. I wouldn't touch one at 25 - 250 it actual accuracy is 47.5 - 227.5. There is lots of stuff below 47.5 that needs torqued.
Finally store your wrenches set to zero or they will losse calibration and you'll have to send it off to be recalabrated!
cmaj7 is offline   Reply With Quote
Old 06-11-2002, 01:13 AM   #5
BluSuby
Member#: 12154
04 Sti
99 Outback
I own a craftmen 1/2" digitork wrench. I am very happy with it. However, it is quite large. Most 1/2" are. I would recommend buying 2 if you need to accurately tighten a wide range of items.You'll need the larger for very few things, but it's also nice to have.
One final thing. If you are buying a craftsmen. Join the Craftsmen club. You immediatly get 10% off the purchase of tools,and you get special prices periodically during craftsmen club sales. I used it and saved $10 on the 1/2" torque wrench, and I saved $100 a couple months later on a tool set during a sale
Bryan
BluSuby is offline   Reply With Quote
what size torque wrench/socket? keepclam Service & Maintenance 5 06-06-2010 02:03 AM
Using gear wrench in conjunction w/ torque wrench for top strut nut BIGSKYWRX Brakes, Steering & Suspension 10 01-07-2005 08:44 AM
What size allen wrench is needed for the FORGE BOV? waitandbleed92 Factory 2.0L Turbo Powertrain 2 08-04-2004 05:10 PM
What size torque wrench for STi wheels and lug nuts essogas Tire & Wheel 3 10-14-2003 02:33 PM
What size allen wrench for top strut shaft and hex wrench to hold the shaft?? please GregBolby General Forum Archive 3 02-13-2001 03:29 PM
Message Board Statistics All times are GMT -4. The time now is 12:12 PM.
