Old 01-24-2010, 10:57 PM   #1
lavid2002
Member#: 226864
Default I wana take my brake calipers off to paint them.....
I want to take my brake calipers off my car when I paint them My question is....What to I do with the brake line when I take the calipers off? Can I use a pair of hemostats to clip the line so no fluid drains out while im painting the calipers? Im doing a fluid flush later...so a TINY bubble isnt a big deal. But Im afraid of the air bubble traveling up my line or something....What should I do to take my calipers off? In terms of the brake line
lavid2002 is offline   Reply With Quote
Old 01-24-2010, 11:04 PM   #2
bjohn21
Member#: 224394
2003 mbp WRX
dented and scratched
I really dont think its necessary to take them off. I bought a kit that was cheap and all I had to do was remove the rims and tires. I just painted the part people can see, not the inside part. It looks real good.
bjohn21 is offline   Reply With Quote
Old 01-24-2010, 11:06 PM   #3
lavid2002
Member#: 226864
my car has 53k miles on it and Im afraid that if I dont prep the surface really well the paint will chip I think if I get em off I can scrub em better....no?
Old 01-24-2010, 11:15 PM   #4
bjohn21
Member#: 224394
2003 mbp WRX
The kit I bought came with prepping stuff as well. Like some prepping spray and a little tooth-brush like thing to help apply. It was really easy...and my car had 86k lol
EDIT- I mean, if you really want to be safe, you could take them off. But I have had no problems so far and I was able to prep them just fine.
Old 01-24-2010, 11:17 PM   #5
Vehicle336
Member#: 220973
You can buy the brake dust remover in a can and buy the brake-specific paint in a can and paint your brakes just fine, no need to sand or even take them off, just mask them well and make sure you don't spray the rotor and it will stick fine. I painted mine last spring and it's been about 10 months and 12k miles since, no fadage, no peelage so far.
I went to a local autozone and just picked up the two cans for like 13-14 bucks.
Vehicle336 is offline   Reply With Quote
Old 01-24-2010, 11:22 PM   #6
lavid2002
Member#: 226864
Sick! OK I bought some Hawk HPS pads, and paint, and im getting new rotors soon. Then ill do the install : )!!!!
Old 01-25-2010, 04:43 AM   #7
pittsburghscoobie
Member#: 221812
2003 WRX
MBP
i just bought a tiny can of automotive paint, took off wheels and tires, taped up my rotors, and everything around them, painted em, two coats, no clear, 6k later, looks good.
doesnt neet to be perfect
pittsburghscoobie is offline   Reply With Quote
Old 01-25-2010, 10:59 AM   #8
Whoa!ShutItDown
Member#: 191700
04 WRX
I bought a can of Dupli-Color caliper paint with ceramic. The paint was put on like a day after I washed it, there was some dirt and brake dust on the calipers and rotors when it was applied (only one quick coat too). That was last summer, the calipers still look great but a few spots on the rotors are showing rust. If I would have put two coats on there would be no rust. Btw, I'm on the cheapest rotors Advanced Auto had, cheapest rear pads they had, and Hawk HPS pads on the front since the cheap ones deformed and made a really loud bang when braking (not related to paint, just a few 100+mph to 0mph stops)
Whoa!ShutItDown is offline   Reply With Quote
Old 01-25-2010, 02:14 PM   #9
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Big fat NO to the hemostats.
Use a clean golf tee.. shove it in the end of the hose
Old 01-25-2010, 02:30 PM   #10
s42k1
Member#: 95702
I painted my calipers a few years back when the car had about 60,000 miles on it. I used the G2 mustang caliper paint kit with amazing results. I didnt fully remove the calipers, just pulled the wheels and masked what I could on the rotors etc. Still to this day they look the same as they did when I coated them, no chipping or cracking.
http://www.g2usa.com/
by the way this kit comes with brake cleaner and everything you will need. It will also hold up much better than spray paint.
s42k1 is offline   Reply With Quote
Old 01-25-2010, 02:48 PM   #11
charlesdixon
Member#: 161345
2005 AW STi
Stage Poo
For me personally, I would definitely bleed the system if I removed the calipers even if I used something to plug the hose. Better safe than sorry.
charlesdixon is offline   Reply With Quote
Old 01-25-2010, 02:58 PM   #12
lavid2002
Member#: 226864
Im bleeding the system anyways...so I figured it would be OK to take the calipers off....New rotors, pads, painted calipers, and fresh fluid. My baby should be G2G!!!
: D
Old 01-25-2010, 05:28 PM   #13
Aspen700
Member#: 109259
2004 WRX
they make clamps that are designed for rubber brake lines. you should be able to find them at any auto parts store that has a decent tool section.
Aspen700 is offline   Reply With Quote
Old 01-25-2010, 06:58 PM   #14
polish man
Member#: 200087
01 IS 300
99 cbr f4
needle nose vice grips work fine if you dont have hose crimpers i prefer vice grips for brake lines anyway cause they stay locked down, just dont go crazy when you crimp down
polish man is offline   Reply With Quote
Old 01-25-2010, 07:50 PM   #15
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Nothing wrong with the cheapest rotors Autozone has.
chazly413 is offline   Reply With Quote
Old 01-25-2010, 07:55 PM   #16
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
unless you are powdercoating your calipers, theres really no need to remove your lines or your calipers from your hub.
some simple green and a rough brush will take off any serious surface contaminants from brake dust and road grime. then simply mask off your rotors. if a little paint gets on, it's not critical. just make sure everything is dry before you apply paint.
topguneagle1 is offline   Reply With Quote
To paint the rear calipers or not to paint them pulser9 Interior & Exterior Modification 25 04-29-2007 04:51 PM
should I paint my brake calipers red or black? alexs001 Vancouver Impreza Club Forum -- VIC 10 04-22-2007 01:01 AM
Just Painted My Brake Calipers SoDealer Tribeca Forum 12 11-18-2006 02:09 AM
Painting my brake calipers itWoRX Interior & Exterior Modification 17 10-20-2002 03:44 PM
I Want to Paint my Brake Calipers - Tips? Suggestions? Mike C Technical Forum Archive 7 10-08-2000 02:24 PM
