Old 01-26-2010, 02:10 AM   #26
MasterKwan
Member#: 98961
2003 WRX
It's $.99/lb at my local grocery stores.
I'm sure that's cheaper. I'll have to check availability.
Old 01-26-2010, 05:08 AM   #27
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
wow this is going to turn out even better than your last build. SUBSCRIBED! start seam welding that biotch and chop/lower the roof like this
wrxtremeWGN is online now   Reply With Quote
Old 01-26-2010, 07:12 AM   #28
MSI
Member#: 95419
Over the next few months we hope to help Dan out with a few proto parts too. We will make some posts in the vendor announcement section as the parts become available. MSI wishes all competitors the very best for the 2010 season.
Regards,
Mark
www.mooresport.com
MSI is offline   Reply With Quote
Old 01-26-2010, 08:20 AM   #29
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
I know this will be a great build. Looking forward to the updates!!
coolblue05 is offline   Reply With Quote
Old 01-26-2010, 08:24 AM   #30
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Originally Posted by cooleyjb View Post
There aren't as many carbon bodied cars out there as you'd think so for the most part it hasn't been an issue. Most common cars I've heard of issues from are some Lotus guys.
There are a couple of fixes.
1. Run a regular GPS module and use that antenna that can be mounted externally.
2. Wait for them to add the GPS antenna to the SmartyCam. They've talked a lot about it so I am pretty sure it will happen. Just a matter of when.
3. Mount the SmartyCam on the outside of the car. There was a prototype for an aero mount over the camera last Nov/Dec. Again not sure on timeframe.
Yeah my first thought was about running an external GPS antenna so hopefully they make one. I'll ask AIM about it.
Originally Posted by MasterKwan View Post
I use dry ice. The tar basically falls off once you get it cold enough. Torch will work but, it's a slow drawn out process in comparison. I get my dry ice at the local welding supply.
So that works for undercoating as well as the interior sound deadening? To be honest I'm not sure how they got off the nasty interior stuff but couldn't get off the wheel well junk.
Originally Posted by subyguy21 View Post
Were those airducts custom made???
No they are from Kaminari.
Originally Posted by growling_boxer View Post
for all the posts i've read from you on various forums, i never saw anything about the unfortunate season ender. good luck with your new build, and I can't wait to see what you do with it from the ground up.
then i hope to see you come up for a NASA NE event, so I can see this thing in person. plus, then you can run with the EFI boys in ST2.
I'd definitely like to do a couple NE events, been meaning to drive at NJMP.
Originally Posted by Kosmic View Post
Good luck with the new build.
Q: Are you cutting the roof down for a lower Cx?
Thanks, no chop top or anything crazy like that
That would be cool, but way too much work Can't spend the whole budget at the body shop!
Regards,
Mark
www.mooresport.com
Thanks again for your support Mark, I'm already impressed with what you have available and I can't wait to see what you come up with in the future!
boost junkie is offline   Reply With Quote
Old 01-26-2010, 08:53 AM   #31
Daishi00
Member#: 78952
2005 WRX
CGM
About time you got this started slacker
It's a good thing you got the bare chassis as I really didn't want to rip off the deadening off the firewall again
Daishi00 is offline   Reply With Quote
Old 01-26-2010, 09:16 AM   #32
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
I actually had the pleasure of doing that again, only this time there was no heater core or anything in the way so it was a whole lot easier The car actually had a fair amount of stuff in it, 2 of us spent about 3 hours removing all the junk, useless brackets/trim pieces, leaves, dead hookers, etc. from the car before we took it over to the media blaster.
Old 01-26-2010, 09:30 AM   #33
Daishi00
Member#: 78952
2005 WRX
CGM
Nice!
Old 01-26-2010, 09:30 AM   #34
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
This definitely seems like an 'all out' race car build this go round. Is this going to be for TTS/ST-2 as well?
MSP608 is offline   Reply With Quote
Old 01-26-2010, 10:32 AM   #35
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Yes that will be the main focus. It will also be legal for NASA's ES enduro class. I'd like the car to be eligible for SCCA STO but a lot of compromises would have to be made and I'm not sure it would be competitive against former WCGT cars.
Old 01-26-2010, 11:28 AM   #36
urabus555
Member#: 102091
1994 1.8l Impreza L
Open Class Build w/110hp
That wheel well junk is 100% worse than the interior sound deadening tar sheets. Crimped wire wheel on an angle grinder takes about an hour a wheel well. It will be very clean at the end of an hour, you can use brake cleaner to get rid of the leftover streaks.
urabus555 is offline   Reply With Quote
Old 01-26-2010, 11:42 AM   #37
Daishi00
Member#: 78952
2005 WRX
CGM
Dan, if it was soda blasted that would explain why they couldn't get through the wheel well stuff. It's rubberized. They should have broken out the media for that section.
Old 01-26-2010, 11:57 AM   #38
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Thanks, I'll give that a try first.
It was blasted with garnet, which is more abrasive than soda. I guess not strong enough though
Old 01-26-2010, 12:06 PM   #39
coolblue05
Member#: 39169
2008 Cayman S, C63
Tuned Perfection
Dan- Also--let me know if you need any oem STi parts along the way...
Old 01-26-2010, 12:24 PM   #40
MasterKwan
Member#: 98961
2003 WRX
The wheel well stuff isn't tar or the sound deadening sheets, it's body sealer they troweled onto the car at the factory. I agree, dry ice won't touch it. I used a heavy wire brush on a drill to pull that stuff off.
Old 01-26-2010, 12:25 PM   #41
MSI
Member#: 95419
we use a wire paint stripping brush (it has hooks on the ends) to remove this. After we have removed the majority, we have a guy come by that blast dry ice on everything. ALL GONE!
Old 01-26-2010, 01:13 PM   #42
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Thanks, I think I have pretty much all of the OEM parts I'm going to use but I'll let you know if I come across anything I forgot.
Are you talking about an attachment for an angle grinder or something hand held?
Old 01-26-2010, 01:19 PM   #43
MSI
Member#: 95419
Old 01-26-2010, 01:43 PM   #44
urabus555
Member#: 102091
1994 1.8l Impreza L
Will one of those attachments work on a regular angle grinder, or do you need one of those ~$500 CrudBusters ?
Old 01-26-2010, 01:55 PM   #45
scprs
Member#: 172359
2005 STi
Wow this is going to be insane. Looks like a great project. I saw your car at IAG when i was getting re-tuned you actually were taking out the motor that day haha
scprs is offline   Reply With Quote
Old 01-26-2010, 02:05 PM   #46
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Thanks Mark! I'll stop by the hardware store this week to find one.
Yep, got pretty much everything out of the old chassis now that can be reused, now it's just sitting there looking sad
Old 01-26-2010, 02:46 PM   #47
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Is there something we need to know about Rick, JJ, and the IAG crew?
Old 01-26-2010, 03:55 PM   #48
MasterKwan
Member#: 98961
2003 WRX
Damn, I need an airbag harness and maybe controller for my 03. You didn't toss all that out did you?
Old 01-26-2010, 04:00 PM   #49
IAG Performance
Member#: 158123
How embarrassing! I had the strangest feeling that I forgot something in that car...
Rick
IAG Performance is offline   Reply With Quote
Old 01-26-2010, 04:03 PM   #50
IAG Performance
Member#: 158123
Oh, and while I'm here, just wanted to express how excited we are to be a part of Dan's new project. We are looking forward to getting this beast together and on the track!
Rick
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 372 03-21-2012 10:48 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
