Old 01-26-2010, 04:15 PM   #51
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
Are you going to do any wheel to wheel club races or just TT?
mug23 is offline   Reply With Quote
Old 01-26-2010, 05:17 PM   #52
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Originally Posted by MasterKwan View Post
Damn, I need an airbag harness and maybe controller for my 03. You didn't toss all that out did you?
Nope I still have all the airbag stuff except for the driver's side airbag, PM me if you're interested in it.
Originally Posted by IAG Performance View Post
How embarrassing! I had the strangest feeling that I forgot something in that car...
Rick
Sorry, guess I let that one slip
Oh, and while I'm here, just wanted to express how excited we are to be a part of Dan's new project. We are looking forward to getting this beast together and on the track!
Rick
You can only imagine how excited I am! You know I wouldn't trust it in anyone else's hands
boost junkie is offline   Reply With Quote
Old 01-26-2010, 05:19 PM   #53
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Yes I'm planning to do some NASA ST2 races this season, I just have to complete comp school. I may even try to rent a spec miata or something and do comp school earlier in the season so I have my license when the car is done. I'd also like to do an enduro or 2 later in the season, we'll see how things go though.
Old 01-26-2010, 06:01 PM   #54
MSP608
Member#: 149631
04 STi
I'm pretty sure you have to do comp school in the car you intend on racing.
MSP608 is offline   Reply With Quote
Old 01-26-2010, 06:44 PM   #55
cooleyjb
Member#: 55727
#533 Spec Racer Ford
Nope, not true.
cooleyjb is offline   Reply With Quote
Old 01-26-2010, 06:49 PM   #56
ESmooth
Member#: 118082
Have you decided on the airbrushed mural for the hood yet?
Im thinking this would look pretty tough:
The new aero package should be sick too, put this to shame:
ESmooth is online now   Reply With Quote
Old 01-26-2010, 07:13 PM   #57
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Nah, pretty sure it just has to be in a car that passes NASA tech.
I think the bald eagle we discussed earlier is a definite possibility, but that tiger just screams "dont **** with me." The aero package on the van is pretty solid, he must have spent a lot of time in the wind tunnel refining it.
Old 01-26-2010, 07:14 PM   #58
Hokie-wrx wagon
Member#: 87194
2008 Impreza WRX STI
Spark Silver Metallic
Sorry to hear about the crash!
Good luck with the new build. I look forward to reading about it!
Hokie-wrx wagon is offline   Reply With Quote
Old 01-26-2010, 08:28 PM   #59
MSP608
Member#: 149631
04 STi
Originally Posted by cooleyjb View Post
Nope, not true.
Guess I shouldn't believe everything NASA officials tell me.
Old 01-26-2010, 08:48 PM   #60
sti4rs
Member#: 211057
2006 STI
Matte Black
cant wait to see this car when its done.
sti4rs is offline   Reply With Quote
Old 01-26-2010, 09:43 PM   #61
misterwaterfallin
Member#: 101091
this.
misterwaterfallin is online now   Reply With Quote
Old 01-26-2010, 09:52 PM   #62
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
I'm doing something similar but not on the same time scale and budget as you ....I will be happy to be done somewhere in 2011. I will follow you're build very carefully.
Kosmic is offline   Reply With Quote
Old 01-26-2010, 10:01 PM   #63
MasterKwan
Member#: 98961
2003 WRX
PM'd you.
Old 01-27-2010, 07:46 AM   #64
MSI
NASIOC Manufacturer
Member#: 95419
Kosmic ... did you install that cage, or you purchased the car like that?
There are a few SERIOUS issues i suggest you address before continuing:
1) footings on the main hoop need to be at the lowest floor panel possible. In the case of the subaru, if you mount were you are, a rollover could deform the panel enough to actually puncture the fuel tank....
2) Main Hoop and A-pillar support need to be installed, mandatory in ALL series as of 2008.
3) Front Upper windscreen supports, again, I believe the majority of series are mandatory now to prevent INWARD collapse towards occupants.
I have attached the schematics of an international spec design to help guide you. Nothing is worse than having to re-do parts of a cage once the car is finished! Best of luck
MSI is offline   Reply With Quote
Old 01-27-2010, 08:48 AM   #65
Kosmic
Member#: 99140
GD Racing chassis
Let's talk about this via PMs, I don't want to hj BJ's thread.
I just want to say, there's no oem fuel tank in that chassi.....I have a fuel cell. The car ran in the Speed World Challenge not too long ago.
Old 01-28-2010, 12:16 AM   #66
kcook
Member#: 78074
2005 STi
w00t! This is going to be an awesome build! Can't wait to see what you do with it.
kcook is offline   Reply With Quote
Old 01-28-2010, 05:34 PM   #67
IAG Performance
Member#: 158123
IAG Performance is online now   Reply With Quote
Old 01-28-2010, 05:42 PM   #68
vision.dynamix
Member#: 139955
# OneBoston
How will you be finish welding the top parts of the tubes on the upper half of the cage thats against the roof now that youve already welded in your floor plates?
vision.dynamix is online now   Reply With Quote
Old 01-28-2010, 05:47 PM   #69
IAG Performance
Member#: 158123
We normally double layer the floor plates in the rear. What you see is the first layer. We would drill a hole in the first layer in the rear and drop the cage down to weld it. After welding the top, you raise the cage back up and weld in the second layer of floor plate. After that, we box in the rear as well to tie it into the side frame rail. In this, case, we may be able to weld the top without dropping the cage, because we will be cutting the center of the roof out to install the carbon fiber panel.
Regards,
JJ
Old 01-28-2010, 06:03 PM   #70
vision.dynamix
Member#: 139955
# OneBoston
Yeah Im used to seeing it done with the hole in the floor method, so I was confused when I saw the plates welded in.
And I forgot this car will be a convertible for at least a few days of it's life.
Old 01-28-2010, 06:17 PM   #71
rexworx
Member#: 103232
MY05 GDA, MY04 FXTI
2.5ltr,PPG,Front LSD,4.44
Hey I was standing next to both of your cars new and old this past sunday when I was getting tuned last sunday... Sorry to hear about your old car. Good luck with the new build...
rexworx is online now   Reply With Quote
Old 01-28-2010, 07:17 PM   #72
IAG Performance
Member#: 158123
Again, that is normally how we do it... example:
You will notice that in this picture, that there is an additional plate welded in once the cage was raised back up....
Here is a picture after the rear boxing is complete:
Hopefully that does a better job of explaining how it is normally done. Again, our plan is to try to weld the tops while the roof is off. We shall see.
Old 01-28-2010, 07:20 PM   #73
vision.dynamix
Member#: 139955
# OneBoston
Completely understood now. Thanks
I believe I have the urge to cage my car now.
Old 01-28-2010, 07:37 PM   #74
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Thanks for posting those pics, looks like the cage is off to a great start. The front plinth boxes are a work of art
Old 01-28-2010, 07:41 PM   #75
Spoolin16PSI
Member#: 51463
06 Forester
CGM
Good luck on the build, I saw you there pulling parts out of the old car when we were up for my tune last month. It's came a long way since then.
Spoolin16PSI is offline   Reply With Quote
Turn in Concepts 2010 Track Car Build Turn in Concepts Press Releases 372 03-21-2012 10:48 PM
My GC Race car build rrsettgast Member's Car Gallery 3 04-27-2010 12:19 PM
Came out to my car... belt on the ground and this (pic). Padge Factory 2.0L Turbo Powertrain 3 03-11-2009 10:36 PM
Getting my car closer to the ground BluScopion Vancouver Impreza Club Forum -- VIC 12 02-02-2007 02:30 AM
got car back from the shop, now lights are messed up X2.5RS01X New England Impreza Club Forum -- NESIC 1 02-21-2005 09:41 PM
Message Board Statistics All times are GMT -4. The time now is 06:08 PM.
