Old 01-25-2010, 10:43 PM   #1
Aleksey
Member#: 23445
2007 STI
Default CEL flashes under light load and goes away when load increases. No code.
Hey guys, I searched around, but couldn't find a similar issue. As the subject says, I get CEL flashing under light load. The problem isn't realted to speed - I see it sporatically in all gears. The CEL would flash until I give the engine more gas. Then it stops and everything is back to norm - no steady CEL. The car drives normally at this point, doesn't buck or make strange noises.
I have an OBD2 scanner from Autozone and it says that there is no codes.
Apart from this problem I'm having occasional misfire at cylinder 4 (P0304) and the car's idle is rough, even when the engine is warm. The misfire code shows up mostly when car idles too. I replaced all 4 spark plugs and so far it didn't change anything. I'm in the process of dealing with the misfire, but the blinking CEL puzzles me. What that could be and why there is no code left in the system when it happenes?
Aleksey is offline   Reply With Quote
Old 01-25-2010, 11:21 PM   #2
sg_halvorsen
Member#: 201924
98 Forester with a
full wrx drivetrain swap
Most likely the knock sensor. Do you have any engine management? (i.e. TSX UTEC) Utec is the most sensitive to sensing knock.
The light blinks when a knock/detonation is detected, the car retards timing a little to prevent detonation.
A list of any mods done to the car will help figure it out.
sg_halvorsen is online now   Reply With Quote
Old 01-25-2010, 11:30 PM   #3
Aleksey
Member#: 23445
2007 STI
I have AccessPort Stage 2 and a catted downpipe. The rest is stock.
Old 01-26-2010, 10:01 AM   #4
ktmrider
Member#: 125687
2005 Legacy GT - 6MT
Check the "Pending Codes" if your scanner has this function. Flashing CEL, not solid, stores the code in Pending.
Likely it's the same P0304. Since you already did the plug(s) swap the coil with #2. Code stays then the injector is the possible culprit. Can't remember if the 07 has top or side feed, if side then swap with #2.
After all that and no change to the P0304 code worse news is bad piston or valve. Do a compression AND leakdown test. LD is gonna tell you more about rings and valve seal.
ktmrider is offline   Reply With Quote
Old 01-26-2010, 03:36 PM   #5
Aleksey
Member#: 23445
2007 STI
Will see if the pending codes are there and do plugs etc. Thank you.
Old 01-27-2010, 01:26 PM   #6
Aleksey
Member#: 23445
2007 STI
so, at this point the idle is pretty rough, I smell gas from exhaust when it idles, 2nd and 4th cylinder misfire at low rpm. CEL flashes at low rpm and the car shakes roughly, but if I give it some gas it smoothens out and drives ok. So called a nearby Suby dealer to set an appointment and drop the car off to:
Check the wires and coils
Compression test
Leakdown test
I chose this route as the dealer gives a loaner car and I have no vacation time left = can't sit and wait there. But the appointment is on Wednesday next week (earliest they can have the loaner avail). Given the symptoms described, what am I risking driving the car ~30 miles every day? What is the chance that I'll damage the car even more by Wed provided that I baby it.
Old 01-30-2010, 03:40 AM   #7
Jimmy168
Member#: 173614
2007 STI
there are many 06 and 07's having the misfire issue and replace the cam sensor works for most of my freind they acost about 90 in the subaru dealer and you just have to replace the on control cylinder four. hope it can work for you too buddy! Let me know^_^
Jimmy168 is offline   Reply With Quote
Old 01-30-2010, 11:47 AM   #8
sidewayz
Member#: 5810
2001 S366 2.5RS
compression test... 100% dead #4 and possibly #2
sidewayz is offline   Reply With Quote
Old 02-01-2010, 12:16 PM   #9
Aleksey
Member#: 23445
2007 STI
that's what it is, #4 is dead - zero compression. I reeeally want to know what caused it.
Old 02-01-2010, 12:28 PM   #10
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
From what i've read before, I believe its a fuel problem, coutersy of the subaru fuel system layout.
#4 is the last cylinder to get gas, casuing a lean condition and ends up eventually burning out the ring on #4. I've seen this a bunch of times and each time this was usually the generation concensus of the board.
Try upgrading the pressure regulator and/or fuel rails? I think that might have helped.
Hope this helps
sexyyrex is offline   Reply With Quote
Old 02-01-2010, 12:33 PM   #11
Aleksey
Member#: 23445
2007 STI
Would a better pump solve the problem? With this particular car I'd like to stay as stock as I can for financial reasons.
Old 02-01-2010, 01:55 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
the pistons are junk. its not a fueling issue.. its a junk design for pistons :/
Wheels squeak when I drive, goes away when I press brake nitr0x99 Brakes, Steering & Suspension 11 12-13-2010 12:34 AM
Unknown Squeal when NOT braking and goes away when lightly braked Gorge Brakes, Steering & Suspension 1 04-05-2008 02:57 AM
CEL Flashing P0301 Rough Idle and NO Power WRXerist Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-05-2008 11:33 PM
weird sound but goes away when pushing the clutch x12oyx316x Transmission (AT/MT) & Driveline 23 06-22-2004 12:18 PM
Squeeky Rear Suspension when Cold, goes away when warm. nhalterman Brakes, Steering & Suspension 2 12-12-2001 03:31 PM
