Old 01-26-2010, 12:46 AM   #1
ShushUpNancy
Member#: 234280
2002 WRX Wagon
Default Launch Control
Does anyone actually use the "launch control" feature on their v2 AP's? Is it a useful feature or something that sounds nice as a feature?
ShushUpNancy is offline   Reply With Quote
Old 01-26-2010, 01:56 AM   #2
Tut4u2
Member#: 40424
05 STi
It works well and its nice in auto-x and if you're drag race.
Allows you to build boost and take off the line faster.
Tut4u2 is offline   Reply With Quote
Old 01-26-2010, 02:12 AM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
Agreed! but the 5spd won't put up with it for very long!
Sounds awesome, and builds boost before you start moving.
ProdriveDreams is offline   Reply With Quote
Old 01-26-2010, 02:35 AM   #4
Farnk
Member#: 91093
2002 Wrx
I've had LC for a couple of years, open source but its the same thing. I use it every once in a while, mostly just for fun when I'm bored PPG's tho.
Farnk is offline   Reply With Quote
Old 01-26-2010, 03:34 AM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
If you know how to launch it correctly, it'll be fine. But if you're like me, I don't know how to so I don't want my tranny to explode
Jubert69 is offline   Reply With Quote
Old 01-26-2010, 06:27 PM   #6
poormansporsche
Member#: 79798
I have it on ECUTek. It's pretty awesome. It's not that bad on your gears as long as you slip the clutch a bit. I mostly use it to scare off Civics and Integras at stop lights. I rarely need to take off that fast.
cheers
poorman
poormansporsche is offline   Reply With Quote
Old 01-27-2010, 06:00 PM   #7
Sukebe_UrAbUs
Member#: 232063
06 Mitsubishi
Imprezza
i put mine on 4000 the tranny seems to put up with it
Sukebe_UrAbUs is offline   Reply With Quote
Old 01-31-2010, 01:00 AM   #8
quick4dr
Member#: 229938
2005 Legacy 2.5GT
Default what rpm?
for an 04 STi running full TBE, uppipe, and intake. what rpm would result in the best launch for launch control?
quick4dr is offline   Reply With Quote
Old 01-31-2010, 11:23 AM   #9
f1speeder
Member#: 138854
2011 WRX
No problems here (06 WRX). The main time I use it is during an Autocross race. As long as you don't have the factory clutch it will be fine.
I launch mine at 5600 RPM and flat foot shift set at 5900 RPM. This also keeps the boost up.
f1speeder is offline   Reply With Quote
Old 01-31-2010, 10:56 PM   #10
JbibWrx
Member#: 203162
2005 Wrx
CGM
this feature only works on dbw correct?
JbibWrx is offline   Reply With Quote
Old 02-01-2010, 09:51 PM   #11
wantsti
Member#: 134764
04 sti
java black pearl
I've used mine hundreds of times from 4000 to 5500 Never had a problem. Just stage 2 sti though.
wantsti is offline   Reply With Quote
launch control removal for 02-03...FIGURED IT OUT..But need a good tiny LC patch 2ez4me Open Source Reflashes 4 06-05-2010 08:25 PM
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 09:16 PM
Utec launch control tried out on my 03 wagon IA Performance Engine Management & Tuning 20 03-19-2003 08:07 PM
UTEC Launch control rev limiter? Typhoon Engine Management & Tuning 6 01-28-2003 10:08 PM
Launch control and flat shift...what do you think? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 10-23-2002 07:40 PM
