Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 05-24-2002, 02:02 PM   #1
Member#: 8679
2010 The most hated
vehicle on the internets
Default What gauge wire do I need?
I'm wiring in two switches to my WRX, one switch for the ABS, and one switch for the ignition(crude anti-theft device). I don't have my owner's manual with me now, but I know that both the fuses for the ABS and the ignition are under 30 amps. The two switches I will be using are rated at 30 amps, so I am ok there.
When I went to the hardware store to buy wire, I bought 12 gauge. Can 12 gauge handle 30 amps at ~ 12V?
Thanks for your time guys.
Corn-Picker is offline   Reply With Quote
Old 05-27-2002, 05:21 AM   #2
Member#: 4116
2002 Impreza TS
12 gauge should be fine, from what I remember... there are technical ways to figure this out, but basically, I know I've got spools of 14 or 16 gauge (all different colors, but I forget what gauge, and the labels are gone) and it's fatter than just about all the wiring in any car (or motorcycle) that I've ever seen.
Rule of thumb: replace/splice in wire that's at least as fat as the wiring that you're splicing into. So if the ABS and ignition wires aren't fatter than what you've bought to wire in your switches, you're fine. If your new wire is much fatter... then you've added several unnecessary grams of weight to your car and wasted several cents on buying overkill wire... no big deal.
Bimmer is offline   Reply With Quote
What wiring do i need? wawawrx Car Audio, Video & Security 4 05-04-2009 10:23 AM
What gauge wire do I need to hook up a gauge? boosted06 Electrical & Lighting 1 10-06-2007 06:50 PM
what gauge pod do i need ?? boostedsti06 Interior & Exterior Modification 2 03-05-2007 12:10 PM
What RCA wires do i need to connect my Basslink Sub? 2 or 4 channel? WRXakaBooSTi Car Audio, Video & Security 3 12-06-2004 09:23 PM
What wiring do i need? Timdog82001 Car Audio, Video & Security 2 06-16-2004 06:09 PM
