Old 01-27-2010, 04:12 PM   #1
spulbi
Member#: 190378
2008 Dinan 335i
Default **** Transmission problems... again! !!!!SOLVED!!!!
Sooo I have rebuilt my transmission twice. NOT looking forward to doing it again.
Everything has been going great after the last rebuild, until I decided to switch gear oil and went with Redline Shockproof (3 qts) and Motul Gear 300 (less than 1 qt).
At the same time I went with Redline Diff oil in the rear.
As soon as I changed the fluid, my car started making weird noises such as the ones you will see in the video. I don't even know how to describe them! I tried contacting the creators of the videos, but I haven't found anything out yet.
What could it be???
To me it seems like it is coming from the front right, but I am not sure. The sound is kind of like metal scraping together, and sometimes it sounds like its bumping around.
Axle?
Wheel bearing?
Center diff?
Rear diff?
Ahhh help me out guys
spulbi is offline   Reply With Quote
Old 01-28-2010, 02:05 AM   #2
aaron04
Member#: 146569
2009 A4
almost sounds like my PPG's lol, hrmm i would guess a center diff or front diff. it is speed dependent right? ie the faster you go the louder? or is it rpm dependant?
my guesses would be center diff, front diff or a wheel bearing. its really hard to tell. hope its something easy i guess. if it still makes the noise in neutral its definitely not your gears.
but the front and center diff will still make noise.
the best way to find out would be to put in on a lift and drive it and listen under the car for the source.
hope this helps ed
aaron04 is offline   Reply With Quote
Old 01-28-2010, 09:29 AM   #3
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Those videos have pretty good sound quality!Is the noise speed related only? It doesnt mater if your in gear or not, it still makes the same noise and seems to follow speed???
Andrew
AndrewtechAutomotive is offline   Reply With Quote
Old 01-28-2010, 12:18 PM   #4
arminyack
Member#: 211671
Sounds all too familiar...my 04 FXT is making the same damn noise. I'm getting the dealership to look at it tomorrow.
arminyack is offline   Reply With Quote
Old 01-28-2010, 04:36 PM   #5
spulbi
Member#: 190378
2008 Dinan 335i
Well after hours of reading and pouring through old threads (01+) I FOUND THE PROBLEM!
I believe in the original WRX deceleration noise thread somebody mentioned the rear subframe brackets that they used to jack up the car. It turns out, when I changed my transmission and rear diff oil, I used that bracket to jack up the rear, and I bent the bracket. I thought I had messed up something in the transmission.
What ended up happening, was whenever I would decelerate in gear, ~40 mph in fourth gear, the vibration from the rear diff and propeller shaft was traveling through the chassis, because that bracket was touching the rear subframe.
Sooo for all the people out there like me, it wasn't a clutch problem, it wasn't a tranny problem, and it wasn't a diff problem. It was a stupid metal bracket that took me ten minutes to bend back.
Case closed.
Old 01-28-2010, 07:32 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you dont know how many of those that I have had to hammer back into shape after loonies have bent them like that
All your diet problems are solved! thrashvr6 Off-Topic 0 06-15-2004 12:53 PM
Real world math/logic problem. Needs solved. Keenan Off-Topic 7 08-27-2003 03:13 PM
Attempting to solve transmission problems dragcar Transmission (AT/MT) & Driveline 1 02-21-2003 05:14 PM
Vishnu problems not solved with EMI BlackWagon Engine Management & Tuning 25 02-10-2003 08:15 AM
CE light- Problem hopefully solved JayGold Mid West Subaru Owners Club Forum -- MWSOC 5 02-15-2002 12:21 PM
